[PATCH] smpstrongapa01: Improve readability
Richi Dubey richidubey at gmail.com
Mon Jun 29 06:17:07 UTC 2020
 testsuites/smptests/smpstrongapa01/init.c | 60 ++++++++++++++---------
 1 file changed, 38 insertions(+), 22 deletions(-)
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index bf8bc05231..d067f2b5b9 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -16,7 +16,7 @@
 #include "config.h"
 #endif
-#include "tmacros.h"
+#include <tmacros.h>
@@ -30,9 +30,22 @@ const char rtems_test_name[] = "SMPSTRONGAPA 1";
 #define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
-#define IDLE UINT8_C(255)
+typedef enum {
+  T0,
+  T1,
+  T2,
+  T3,
+  T4,
+  T5,
+  T6,
+  T7,
+  T8,
+  T9,
+  T10,
+  T11,
+  IDLE
+} task_index;
-#define NAME rtems_build_name('S', 'A', 'P', 'A')
 typedef struct {
   enum {
@@ -43,7 +56,7 @@ typedef struct {
     KIND_UNBLOCK
   } kind;
-  size_t index;
+  task_index index;
   struct {
     rtems_task_priority priority;
@@ -102,17 +115,17 @@ typedef struct {
 static const test_action test_actions[] = {
   RESET,
-  UNBLOCK(      0,           0, IDLE, IDLE, IDLE),
-  UNBLOCK(      1,           0,    1, IDLE, IDLE),
-  UNBLOCK(      2,           0,    1,    2, IDLE),
-  UNBLOCK(      3,           0,    1,    2,    3),
-  UNBLOCK(      5,           0,    1,    2,    3),
-  SET_PRIORITY( 3,  P(4),    0,    1,    2,    3),
-  SET_PRIORITY( 5,  P(3),    0,    1,    2,    5),
-  BLOCK(        5,           0,    1,    2,    3),
-  SET_AFFINITY( 5,   ALL,    0,    1,    2,    3),
+  UNBLOCK(      T0,           T0,  IDLE,  IDLE,  IDLE),
+  UNBLOCK(      T1,           T0,    T1,  IDLE,  IDLE),
+  UNBLOCK(      T2,           T0,    T1,    T2,  IDLE),
+  UNBLOCK(      T3,           T0,    T1,    T2,    T3),
+  UNBLOCK(      T5,           T0,    T1,    T2,    T3),
+  SET_PRIORITY( T3,  P(4),    T0,    T1,    T2,    T3),
+  SET_PRIORITY( T5,  P(3),    T0,    T1,    T2,    T5),
+  BLOCK(        T5,           T0,    T1,    T2,    T3),
+  SET_AFFINITY( T5,   ALL,    T0,    T1,    T2,    T3),
   RESET,
   RESET
@@ -130,7 +143,7 @@ static void set_affinity(rtems_id id, uint32_t cpu_set_32)
   rtems_status_code sc;
   cpu_set_t cpu_set;
-  size_t i;
+  task_index i;
   CPU_ZERO(&cpu_set);
@@ -147,7 +160,7 @@ static void set_affinity(rtems_id id, uint32_t cpu_set_32)
 static void reset(test_context *ctx)
-  size_t i;
+  task_index i;
   for (i = CPU_COUNT; i < TASK_COUNT; ++i) {
     set_priority(ctx->task_ids[i], P(i));
@@ -179,10 +192,10 @@ static void reset(test_context *ctx)
 static void check_cpu_allocations(test_context *ctx, const test_action *action)
-  size_t i;
+  task_index i;
   for (i = 0; i < CPU_COUNT; ++i) {
-    size_t e;
+    task_index e;
     const Per_CPU_Control *c;
     const Thread_Control *h;
@@ -206,7 +219,7 @@ static void timer(rtems_id id, void *arg)
   test_context *ctx;
-  size_t i;
+  task_index i;
   ctx = arg;
   i = ctx->action_index;
@@ -271,7 +284,7 @@ static void test(void)
   test_context *ctx;
-  size_t i;
+  task_index i;
   ctx = &test_instance;
@@ -279,7 +292,7 @@ static void test(void)
   for (i = 0; i < TASK_COUNT; ++i) {
     sc = rtems_task_create(
-      NAME,
+      rtems_build_name(' ', ' ', 'T', '0' + i),
       P(i),
       RTEMS_MINIMUM_STACK_SIZE,
       RTEMS_DEFAULT_MODES,
@@ -292,7 +305,10 @@ static void test(void)
     rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  sc = rtems_timer_create(NAME, &ctx->timer_id);
+  sc = rtems_timer_create(
+  rtems_build_name('S', 'A', 'P', 'A'),
+   &ctx->timer_id
   sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
2.17.1
