[PATCH 02/26] leon,gr1553rt: Fixed memory leak
Daniel Hellstrom
daniel at gaisler.com
Mon Jun 29 11:27:49 UTC 2020
bsps/shared/grlib/1553/gr1553rt.c | 16 +++++++++++-----
1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/bsps/shared/grlib/1553/gr1553rt.c b/bsps/shared/grlib/1553/gr1553rt.c
index 339e856..668a39e 100644
--- a/bsps/shared/grlib/1553/gr1553rt.c
+++ b/bsps/shared/grlib/1553/gr1553rt.c
@@ -147,7 +147,6 @@ static int gr1553rt_list_reg(struct gr1553rt_list *list)
return -1;
-#if 0 /* unused for now */
/* Unregister List from device */
static void gr1553rt_list_unreg(struct gr1553rt_list *list)
@@ -156,7 +155,6 @@ static void gr1553rt_list_unreg(struct gr1553rt_list *list)
priv->lists[list->listid] = NULL;
list->listid = -1;
-#endif
static int gr1553rt_bdid(void *rt, struct gr1553rt_sw_bd *bd)
@@ -240,7 +238,7 @@ int gr1553rt_list_init
struct gr1553rt_priv *priv = rt;
size_t size;
- int i;
+ int i, malloc_used;
struct gr1553rt_sw_bd *swbd;
unsigned short index;
struct gr1553rt_list *list;
@@ -251,6 +249,7 @@ int gr1553rt_list_init
* If the IN/OUT plist argument points to NULL a list
* dynamically allocated here.
+ malloc_used = 0;
list = *plist;
if ( list == NULL ) {
/* Dynamically allocate LIST */
@@ -258,20 +257,27 @@ int gr1553rt_list_init
(cfg->bd_cnt * sizeof(list->bds[0]));
list = grlib_malloc(size);
if ( list == NULL )
- return -1;
+ return -1; /* Out of Memory */
*plist = list;
+ malloc_used = 1;
list->rt = rt;
list->subadr = -1;
list->listid = gr1553rt_list_reg(list);
- if ( list->listid == -1 )
+ if ( list->listid == -1 ) {
+ if (malloc_used)
+ free(list);
return -2; /* Too many lists */
list->cfg = cfg;
list->bd_cnt = cfg->bd_cnt;
/* Allocate all BDs needed by list */
if ( gr1553rt_bd_alloc(rt, &swbd, list->bd_cnt) ) {
+ gr1553rt_list_unreg(list);
+ if (malloc_used)
+ free(list);
return -3; /* Too few descriptors */
2.7.4
