[PATCH 00/26] leon: various fixes and TN0018 errata workaround
    Daniel Hellstrom
    daniel at gaisler.com
    Mon Jun 29 11:27:47 UTC 2020
Hi,
The GRLIB-TN-0018 errata (gaisler.com/notes) was recently published and
affecting the LEON3FT devices like UT699, UT700 and GR712RC. RTEMS SW
workarounds were released in May/June in the RCC dists so now I would
like to request to upstream that work and other differences between the
RTEMS5 code base for RCC-1.3.
Apart from fixes there is also driver support for the new CAN-FD in
GRLIB: GRCANFD. The restructuring of the CAN code is also an improvement
for GR712RC and GR740 by sharing more common code.
The patches are also found in the submit/20200629 branch of rcc.git:
  https://git.rtems.org/danielh/rcc.git/log/?h=submit/20200629
Please let me know if I should separate the patches in smaller chunks
and resend or any other comments. As most are fixes I didn't do that
initially.
I've just learn that RTEMS5 branched! It would be great if the patches
could go on both master and 5.
Kind Regards,
Daniel Hellstrom
 create mode 100644 bsps/include/grlib/canbtrs.h
 create mode 100644 bsps/shared/grlib/can/canbtrs.c
 create mode 100644 bsps/shared/grlib/can/grcan_internal.h
 create mode 100644 bsps/shared/grlib/can/grcanfd.c
 create mode 100644 bsps/shared/grlib/can/grcanstd.c
 create mode 100644 bsps/sparc/leon3/start/drvmgr_def_drivers.c
 create mode 100644 cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h
 bsps/headers.am                                    |   1 +
 bsps/include/grlib/ahbstat.h                       |   2 +
 bsps/include/grlib/ambapp_ids.h                    |  19 +
 bsps/include/grlib/canbtrs.h                       |  62 ++
 bsps/include/grlib/grcan.h                         | 129 +++-
 bsps/include/grlib/greth.h                         |   1 +
 bsps/include/grlib/grlib_impl.h                    |  10 +
 bsps/include/grlib/grspw_pkt.h                     |   4 +-
 bsps/include/grlib/grspw_router.h                  |   1 +
 bsps/shared/grlib-sources.am                       |   3 +
 bsps/shared/grlib/1553/gr1553b.c                   |   4 +
 bsps/shared/grlib/1553/gr1553bc.c                  |  76 ++-
 bsps/shared/grlib/1553/gr1553bm.c                  |  49 +-
 bsps/shared/grlib/1553/gr1553rt.c                  | 123 ++--
 bsps/shared/grlib/amba/ahbstat.c                   |   8 +
 bsps/shared/grlib/amba/ambapp_names.c              |  21 +-
 bsps/shared/grlib/btimer/tlib_ckinit.c             |   7 +-
 bsps/shared/grlib/can/canbtrs.c                    | 116 ++++
 bsps/shared/grlib/can/grcan.c                      | 719 +++------------------
 bsps/shared/grlib/can/grcan_internal.h             | 140 ++++
 bsps/shared/grlib/can/grcanfd.c                    | 535 +++++++++++++++
 bsps/shared/grlib/can/grcanstd.c                   | 435 +++++++++++++
 bsps/shared/grlib/can/occan.c                      | 151 ++---
 bsps/shared/grlib/l2c/l2c.c                        |   4 +-
 bsps/shared/grlib/net/greth.c                      |  22 +-
 bsps/shared/grlib/spw/grspw.c                      |   7 +
 bsps/shared/grlib/spw/grspw_router.c               |   5 +
 bsps/sparc/leon3/config/gr712rc.cfg                |   5 +-
 bsps/sparc/leon3/config/ut699.cfg                  |   3 +-
 bsps/sparc/leon3/config/ut700.cfg                  |   3 +-
 bsps/sparc/leon3/start/amba.c                      |  12 -
 bsps/sparc/leon3/start/cpucounter.c                |   5 +-
 bsps/sparc/leon3/start/drvmgr_def_drivers.c        |  28 +
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |   1 +
 cpukit/score/cpu/sparc/cpu_asm.S                   |  14 +-
 cpukit/score/cpu/sparc/headers.am                  |   1 +
 .../score/cpu/sparc/include/libcpu/grlib-tn-0018.h |  58 ++
 cpukit/score/cpu/sparc/include/rtems/score/sparc.h |   4 +
 cpukit/score/cpu/sparc/sparc-access.S              |   4 +-
 cpukit/score/cpu/sparc/sparc-counter-asm.S         |   7 +-
 cpukit/score/cpu/sparc/syscall.S                   |   3 +-
 cpukit/score/cpu/sparc/window.S                    |   9 +-
 42 files changed, 1927 insertions(+), 884 deletions(-)
2.7.4
