[PATCH 04/26] leon,gr1553b: set codec version
Daniel Hellstrom
daniel at gaisler.com
Mon Jun 29 11:27:51 UTC 2020
This is enables the updated codec for GR740 and is backwards compatible
with all other versions of the IP.
bsps/shared/grlib/1553/gr1553b.c | 4 ++++
1 file changed, 4 insertions(+)
diff --git a/bsps/shared/grlib/1553/gr1553b.c b/bsps/shared/grlib/1553/gr1553b.c
index 777b6dc..179f5e3 100644
--- a/bsps/shared/grlib/1553/gr1553b.c
+++ b/bsps/shared/grlib/1553/gr1553b.c
@@ -206,6 +206,10 @@ static int gr1553_init2(struct drvmgr_dev *dev)
GR1553B_WRITE_REG(®s->rt_cfg, 0x15530000);
/* Stop BM logging (just in case) */
GR1553B_WRITE_REG(®s->bm_ctrl, 0);
+ /* Set codec version. This is only supported by some devices, i.e. GR740.
+ * It will not have any effect on devices that does not support this bit.
+ GR1553B_WRITE_REG(®s->hwcfg, 1<<12);
return DRVMGR_OK;
2.7.4
