[PATCH 08/26] leon, can: introduce common CAN baud-rate calculation function
Daniel Hellstrom daniel at gaisler.com
Mon Jun 29 11:27:55 UTC 2020
Reimplemented the baud-rate algorithm from scratch to cope with
GRCAN, GRCANFD and OC_CAN devices.
 bsps/headers.am                 |   1 +
 bsps/include/grlib/canbtrs.h    |  62 +++++++++++++++++++++
 bsps/shared/grlib-sources.am    |   1 +
 bsps/shared/grlib/can/canbtrs.c | 116 ++++++++++++++++++++++++++++++++++++++++
 4 files changed, 180 insertions(+)
 create mode 100644 bsps/include/grlib/canbtrs.h
 create mode 100644 bsps/shared/grlib/can/canbtrs.c
diff --git a/bsps/headers.am b/bsps/headers.am
index 5af7e43..2c9b31d 100644
--- a/bsps/headers.am
+++ b/bsps/headers.am
@@ -34,6 +34,7 @@ include_grlib_HEADERS += ../../bsps/include/grlib/apbuart_termios.h
 include_grlib_HEADERS += ../../bsps/include/grlib/b1553brm.h
 include_grlib_HEADERS += ../../bsps/include/grlib/b1553rt.h
 include_grlib_HEADERS += ../../bsps/include/grlib/bspcommon.h
+include_grlib_HEADERS += ../../bsps/include/grlib/canbtrs.h
 include_grlib_HEADERS += ../../bsps/include/grlib/canmux.h
 include_grlib_HEADERS += ../../bsps/include/grlib/cons.h
 include_grlib_HEADERS += ../../bsps/include/grlib/debug_defs.h
diff --git a/bsps/include/grlib/canbtrs.h b/bsps/include/grlib/canbtrs.h
new file mode 100644
index 0000000..1fbbbfc
--- /dev/null
+++ b/bsps/include/grlib/canbtrs.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup can
+ * @brief CAN baud-rate paramter operations for OCCAN/GRCAN/GRCANFD controllers
+ *  COPYRIGHT (c) 2019.
+ *  Cobham Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef __GRLIB_CANBTRS_H__
+#define __GRLIB_CANBTRS_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* CAN Baud-rate parameters, range of valid parameter values */
+struct grlib_canbtrs_ranges {
+	unsigned int max_scaler;
+	char has_bpr;
+	unsigned char divfactor;
+	unsigned char min_tseg1;
+	unsigned char max_tseg1;
+	unsigned char min_tseg2;
+	unsigned char max_tseg2;
+struct grlib_canbtrs_timing {
+	unsigned char scaler;
+	unsigned char ps1;
+	unsigned char ps2;
+	unsigned char rsj;
+	unsigned char bpr;
+/* Calculate CAN baud-rate generation parameters from requested baud-rate
+ * \param baud       The CAN baud rate requested
+ * \param core_hz    Input clock [Hz] to CAN core
+ * \param sampl_pt   CAN sample point in %, 80 means 80%
+ * \param br         CAN Baud-rate parameters limitations
+ * \param timing     result is placed here
+int grlib_canbtrs_calc_timing(
+	unsigned int baud,
+	unsigned int core_hz,
+	unsigned int sampl_pt,
+	struct grlib_canbtrs_ranges *br,
+	struct grlib_canbtrs_timing *timing
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/shared/grlib-sources.am b/bsps/shared/grlib-sources.am
index 512a48c..f2ad1bf 100644
--- a/bsps/shared/grlib-sources.am
+++ b/bsps/shared/grlib-sources.am
@@ -20,6 +20,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/ascs/grascs.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/btimer/gptimer.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/btimer/tlib.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/btimer/tlib_ckinit.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/canbtrs.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/canmux.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/grcan.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/occan.c
diff --git a/bsps/shared/grlib/can/canbtrs.c b/bsps/shared/grlib/can/canbtrs.c
index 0000000..8600e2b
--- /dev/null
+++ b/bsps/shared/grlib/can/canbtrs.c
@@ -0,0 +1,116 @@
+ *  GRLIB common CAN baud-rate to timing parameters conversion
+#include <grlib/canbtrs.h>
+/*#define GRLIB_CANBTRS_DEBUG*/
+/* Calculate CAN baud-rate generation parameters from requested baud-rate */
+	int best_error = 2000000000, best_tseg=0, best_scaler=0;
+	int tseg=0, tseg1=0, tseg2=0, sc, error;
+	/* Default to 80% sample point */
+	if ((sampl_pt < 50) || (sampl_pt > 99))
+		sampl_pt = 80;
+	/* step though all TSEG1+TSEG2 values possible */
+	for (tseg = (br->min_tseg1 + br->min_tseg2);
+	     tseg <= (br->max_tseg1 + br->max_tseg2);
+	     tseg++) {
+		/* calculate scaler */
+		sc = core_hz / ((br->divfactor + tseg) * baud);
+		if (sc <= 0 || sc > br->max_scaler)
+			continue;
+		if (br->has_bpr &&
+		    (((sc > 256 * 1) && (sc <= 256 * 2) && (sc & 0x1)) ||
+		    ((sc > 256 * 2) && (sc <= 256 * 4) && (sc & 0x3)) ||
+		    ((sc > 256 * 4) && (sc <= 256 * 8) && (sc & 0x7))))
+			continue;
+		error = baud - core_hz / (sc * (br->divfactor + tseg));
+#ifdef GRLIB_CANBTRS_DEBUG
+		printf("  baud=%d, tseg=%d, sc=%d, error=%d\n",
+		       baud, tseg, sc, error);
+#endif
+		if (error < 0)
+			error = -error;
+		/* tseg is increasing, so we accept higher tseg with the same
+		 * baudrate to get better sampling point.
+		if (error <= best_error) {
+			best_error = error;
+			best_tseg = tseg;
+			best_scaler = sc;
+			printf("  ! best baud=%d\n",
+			       core_hz/(sc * (br->divfactor + tseg)));
+#endif
+	/* return an error if 5% off baud-rate */
+	if (best_error && (baud / best_error <= 5)) {
+		return -2;
+	} else if (!timing) {
+		return 0; /* nothing to store result in, but a valid bitrate can be calculated */
+	tseg2 = (best_tseg + br->divfactor) -
+	        ((sampl_pt * (best_tseg + br->divfactor)) / 100);
+	if (tseg2 < br->min_tseg2) {
+		tseg2 = br->min_tseg2;
+	} else if (tseg2 > br->max_tseg2) {
+		tseg2 = br->max_tseg2;
+	tseg1 = best_tseg - tseg2;
+	if (tseg1 > br->max_tseg1) {
+		tseg1 = br->max_tseg1;
+		tseg2 = best_tseg - tseg1;
+	} else if (tseg1 < br->min_tseg1) {
+		tseg1 = br->min_tseg1;
+	/* Get scaler and BPR from pseudo SCALER clock */
+	if (best_scaler <= 256) {
+		timing->scaler = best_scaler - 1;
+		timing->bpr = 0;
+	} else if (best_scaler <= 256 * 2) {
+		timing->scaler = ((best_scaler + 1) >> 1) - 1;
+		timing->bpr = 1;
+	} else if (best_scaler <= 256 * 4) {
+		timing->scaler = ((best_scaler + 1) >> 2) - 1;
+		timing->bpr = 2;
+	} else {
+		timing->scaler = ((best_scaler + 1) >> 3) - 1;
+		timing->bpr = 3;
+	timing->ps1    = tseg1;
+	timing->ps2    = tseg2;
+	timing->rsj    = 1;
+	printf("  ! result: sc=%d,bpr=%d,ps1=%d,ps2=%d\n", timing->scaler, timing->bpr, timing->ps1, timing->ps2);
+#endif
+	return 0;
2.7.4
