[PATCH 26/26] leon,tn-0018: work around GRLIB-TN-0018 errata
Daniel Hellstrom daniel at gaisler.com
Mon Jun 29 12:34:20 UTC 2020
On 2020-06-29 13:57, Sebastian Huber wrote:
> On 29/06/2020 13:28, Daniel Hellstrom wrote:
>> diff --git a/bsps/sparc/leon3/config/gr712rc.cfg
>> b/bsps/sparc/leon3/config/gr712rc.cfg
>> index 3852932..e8f0731 100644
>> --- a/bsps/sparc/leon3/config/gr712rc.cfg
>> +++ b/bsps/sparc/leon3/config/gr712rc.cfg
>> @@ -10,10 +10,11 @@ RTEMS_CPU=sparc
>>   #  and (hopefully) optimize for it.
>>   #  GCC and clang use different switches to select target:
>>   ifneq (,$(findstring clang,$(CC)))
>> -  CPU_CFLAGS = -mcpu=gr712rc
>> +  CPU_CFLAGS = -mcpu=gr712rc -D__FIX_LEON3FT_TN0018
>>   else
>> -  CPU_CFLAGS = -mcpu=leon3 -mfix-gr712rc
>> +  CPU_CFLAGS = -mcpu=leon3 -mfix-gr712rc -D__FIX_LEON3FT_TN0018
>>   endif
>> +# -D__FIX_LEON3FT_TN0018 enables kernel work around for
>>     # optimize flag: typically -O2
>>   CFLAGS_OPTIMIZE_V = -O2 -g
>> diff --git a/bsps/sparc/leon3/config/ut699.cfg
>> b/bsps/sparc/leon3/config/ut699.cfg
>> index a8fff49..ed70cf5 100644
>> --- a/bsps/sparc/leon3/config/ut699.cfg
>> +++ b/bsps/sparc/leon3/config/ut699.cfg
>> @@ -8,7 +8,8 @@ RTEMS_CPU=sparc
>>     #  This contains the compiler options necessary to select the CPU
>> model
>> -CPU_CFLAGS = -mcpu=leon -mfix-ut699
>> +CPU_CFLAGS = -mcpu=leon -mfix-ut699 -D__FIX_LEON3FT_TN0018
>> diff --git a/bsps/sparc/leon3/config/ut700.cfg
>> b/bsps/sparc/leon3/config/ut700.cfg
>> index bcca901..5c6fff8 100644
>> --- a/bsps/sparc/leon3/config/ut700.cfg
>> +++ b/bsps/sparc/leon3/config/ut700.cfg
>> model
>> -CPU_CFLAGS = -mcpu=leon3 -mfix-ut700
>> +CPU_CFLAGS = -mcpu=leon3 -mfix-ut700 -D__FIX_LEON3FT_TN0018
> Command line defines are discouraged and in cpukit only multilib
> defined defines should be used. Can't you the existing
> __FIX_LEON3FT_B2BST define to enable the errata workarounds?
For UT700, for example, it is true that B2BST also needs to be defined,
but in general a user may have TN0018 but not the B2BST since it was
fixed in HW several years ago. There is no fix needed to the compiler or
newlib affecting the multilibs, the workaround can be implemented purely
in the run-time time time which simplifies the impact on the user. When
building multiple BSPs this is very convenient too since the configure
line can remain the same regardless of the work around. The compiler
does not emit any information about TN0018 or UT700 for example.
