[PATCH v1] libcsupport: Address *tors FIXME
Kinsey Moore kinsey.moore at oarcorp.com
Mon Jun 29 15:30:27 UTC 2020
This introduces the CPU_USE_LIBC_XTORS define for use by CPU ports to
determine which global constructor and destructor methods are used
instead of placing architecture defines where they shouldn't be.
Close #4018
 cpukit/libcsupport/src/newlibc_exit.c            | 5 +----
 cpukit/score/cpu/arm/include/rtems/score/cpu.h   | 2 ++
 cpukit/score/cpu/or1k/include/rtems/score/cpu.h  | 2 ++
 cpukit/score/cpu/riscv/include/rtems/score/cpu.h | 2 ++
 cpukit/score/src/threadhandler.c                 | 3 +--
 5 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/cpukit/libcsupport/src/newlibc_exit.c b/cpukit/libcsupport/src/newlibc_exit.c
index 650b692c74..8e009da096 100644
--- a/cpukit/libcsupport/src/newlibc_exit.c
+++ b/cpukit/libcsupport/src/newlibc_exit.c
@@ -17,11 +17,8 @@
 #include <unistd.h>
-/* FIXME: These defines are a blatant hack */
   #if defined(__USE_INIT_FINI__)
-    #if defined(__ARM_EABI__) || defined(__riscv) \
-      || defined(__or1k__) || defined(__or1knd__)
+    #if defined(CPU_USE_LIBC_XTORS)
       #define FINI_SYMBOL __libc_fini_array
     #else
       #define FINI_SYMBOL _fini
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index b7b48a3ac3..634efe64b9 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -153,6 +153,8 @@
 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
+#define CPU_USE_LIBC_XTORS TRUE
 #define CPU_MAXIMUM_PROCESSORS 32
 #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index 39920bebc3..84f73e06ca 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -435,6 +435,8 @@ void _CPU_Context_Initialize(
 #endif /* ASM */
 #define CPU_SIZEOF_POINTER 4
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index e08307d372..08647e814f 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -219,6 +219,8 @@ extern void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN;
 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE
 typedef uint16_t Priority_bit_map_Word;
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index acbe186a53..091455b86c 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -29,8 +29,7 @@
  *  initialization this target and compiler version uses.
     #define INIT_NAME __libc_init_array
   #else
     #define INIT_NAME _init
2.20.1
