NEW BUILD SYSTEM: Error on waf install
Sebastian Huber
Mon Jun 29 15:42:39 UTC 2020
On 29/06/2020 15:31, Niteesh G. S. wrote:
> The new build system throws the following error while issuing the
> following cmd:
> ./waf install -v
> source not found: 'bsp.cfg' in bld(source=[], target='',
> meths=['process_install_task', 'process_rule', 'process_source'],
> features=['install_task'],
> path=/home/niteesh/development/rtems/kernel/rtems, idx=16,
> tg_idx_count=16,
> install_to='${PREFIX}/${ARCH}-rtems${__RTEMS_MAJOR__}/${BSP_NAME}/make',
> install_from='bsp.cfg',
> dest='${PREFIX}/${ARCH}-rtems${__RTEMS_MAJOR__}/${BSP_NAME}/make',
> type='install_files', posted=True, install_task=
> {task 140185824631496: inst -> }) in
This issue should be fixed now.
