[PATCH v2] libcsupport: Address *tors FIXME
Sebastian Huber
Mon Jun 29 17:37:17 UTC 2020
On 29/06/2020 18:52, Kinsey Moore wrote:
> + #if defined(CPU_USE_LIBC_INIT_FINI_ARRAY)
The test should be CPU_USE_LIBC_INIT_FINI_ARRAY == TRUE. There should be a
#define CPU_USE_LIBC_INIT_FINI_ARRAY FALSE
for all CPUs not having this stuff. There should be a documentation in
cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
Ideally, there should be also a static assertion that CPU_USE_LIBC_INIT_FINI_ARRAY is defined to TRUE or FALSE.
