[PATCH] smpstrongapa01: Improve readability
Richi Dubey
richidubey at gmail.com
Tue Jun 30 05:56:01 UTC 2020
Sorry, I did the -v3 while doing format-patch but not while sending it.
I've sent in the new patch after running it on LEON3 bsp. Please check it
out.
Thanks,
Richi.
On Mon, Jun 29, 2020 at 8:53 PM Gedare Bloom <gedare at rtems.org> wrote:
> Please resend this with the -v3 as previously discussed, and be sure
> to fully test your patches before sending them.
> On Mon, Jun 29, 2020 at 12:19 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Hi,
> > This is the 3rd version of the patch. I realised that the previous
> version had a syntax error after I ran 'make' on the testsuite.
> > Please review this patch.
> Did you run it also?
> > Thanks,
> > Richi.
> > On Mon, Jun 29, 2020 at 11:47 AM Richi Dubey <richidubey at gmail.com>
> wrote:
> >> testsuites/smptests/smpstrongapa01/init.c | 60 ++++++++++++++---------
> >> 1 file changed, 38 insertions(+), 22 deletions(-)
> >> diff --git a/testsuites/smptests/smpstrongapa01/init.c
> b/testsuites/smptests/smpstrongapa01/init.c
> >> index bf8bc05231..d067f2b5b9 100644
> >> --- a/testsuites/smptests/smpstrongapa01/init.c
> >> +++ b/testsuites/smptests/smpstrongapa01/init.c
> >> @@ -16,7 +16,7 @@
> >> #include "config.h"
> >> #endif
> >> -#include "tmacros.h"
> >> +#include <tmacros.h>
> >> #include <rtems.h>
> >> @@ -30,9 +30,22 @@ const char rtems_test_name[] = "SMPSTRONGAPA 1";
> >> #define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
> >> -#define IDLE UINT8_C(255)
> >> +typedef enum {
> >> + T0,
> >> + T1,
> >> + T2,
> >> + T3,
> >> + T4,
> >> + T5,
> >> + T6,
> >> + T7,
> >> + T8,
> >> + T9,
> >> + T10,
> >> + T11,
> >> + IDLE
> >> +} task_index;
> >> -#define NAME rtems_build_name('S', 'A', 'P', 'A')
> >> typedef struct {
> >> enum {
> >> @@ -43,7 +56,7 @@ typedef struct {
> >> KIND_UNBLOCK
> >> } kind;
> >> - size_t index;
> >> + task_index index;
> >> struct {
> >> rtems_task_priority priority;
> >> @@ -102,17 +115,17 @@ typedef struct {
> >> static const test_action test_actions[] = {
> >> RESET,
> >> - UNBLOCK( 0, 0, IDLE, IDLE, IDLE),
> >> - UNBLOCK( 1, 0, 1, IDLE, IDLE),
> >> - UNBLOCK( 2, 0, 1, 2, IDLE),
> >> - UNBLOCK( 3, 0, 1, 2, 3),
> >> - UNBLOCK( 5, 0, 1, 2, 3),
> >> - SET_PRIORITY( 3, P(4), 0, 1, 2, 3),
> >> - SET_PRIORITY( 5, P(3), 0, 1, 2, 5),
> >> - BLOCK( 5, 0, 1, 2, 3),
> >> - SET_AFFINITY( 5, ALL, 0, 1, 2, 3),
> >> + UNBLOCK( T0, T0, IDLE, IDLE, IDLE),
> >> + UNBLOCK( T1, T0, T1, IDLE, IDLE),
> >> + UNBLOCK( T2, T0, T1, T2, IDLE),
> >> + UNBLOCK( T3, T0, T1, T2, T3),
> >> + UNBLOCK( T5, T0, T1, T2, T3),
> >> + SET_PRIORITY( T3, P(4), T0, T1, T2, T3),
> >> + SET_PRIORITY( T5, P(3), T0, T1, T2, T5),
> >> + BLOCK( T5, T0, T1, T2, T3),
> >> + SET_AFFINITY( T5, ALL, T0, T1, T2, T3),
> >> RESET,
> >> RESET
> >> @@ -130,7 +143,7 @@ static void set_affinity(rtems_id id, uint32_t
> cpu_set_32)
> >> rtems_status_code sc;
> >> cpu_set_t cpu_set;
> >> - size_t i;
> >> + task_index i;
> >> CPU_ZERO(&cpu_set);
> >> @@ -147,7 +160,7 @@ static void set_affinity(rtems_id id, uint32_t
> cpu_set_32)
> >> static void reset(test_context *ctx)
> >> - size_t i;
> >> + task_index i;
> >> for (i = CPU_COUNT; i < TASK_COUNT; ++i) {
> >> set_priority(ctx->task_ids[i], P(i));
> >> @@ -179,10 +192,10 @@ static void reset(test_context *ctx)
> >> static void check_cpu_allocations(test_context *ctx, const test_action
> *action)
> >> - size_t i;
> >> + task_index i;
> >> for (i = 0; i < CPU_COUNT; ++i) {
> >> - size_t e;
> >> + task_index e;
> >> const Per_CPU_Control *c;
> >> const Thread_Control *h;
> >> @@ -206,7 +219,7 @@ static void timer(rtems_id id, void *arg)
> >> test_context *ctx;
> >> - size_t i;
> >> + task_index i;
> >> ctx = arg;
> >> i = ctx->action_index;
> >> @@ -271,7 +284,7 @@ static void test(void)
> >> test_context *ctx;
> >> - size_t i;
> >> + task_index i;
> >> ctx = &test_instance;
> >> @@ -279,7 +292,7 @@ static void test(void)
> >> for (i = 0; i < TASK_COUNT; ++i) {
> >> sc = rtems_task_create(
> >> - NAME,
> >> + rtems_build_name(' ', ' ', 'T', '0' + i),
> >> P(i),
> >> RTEMS_MINIMUM_STACK_SIZE,
> >> RTEMS_DEFAULT_MODES,
> >> @@ -292,7 +305,10 @@ static void test(void)
> >> rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> >> - sc = rtems_timer_create(NAME, &ctx->timer_id);
> >> + sc = rtems_timer_create(
> >> + rtems_build_name('S', 'A', 'P', 'A'),
> >> + &ctx->timer_id
> >> sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
> >> 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200630/03b77f83/attachment-0001.html>
