[PATCH] test for fegetround and fesetround
Mon Mar 2 16:08:13 UTC 2020
On Tue, Feb 25, 2020 at 7:56 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>  testsuites/psxtests/psxfenv01/init.c | 42 +++++++++++++++++++++++++++-
>  1 file changed, 41 insertions(+), 1 deletion(-)
> diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
> index 05f3cdc880..4339139c58 100644
> --- a/testsuites/psxtests/psxfenv01/init.c
> +++ b/testsuites/psxtests/psxfenv01/init.c
> @@ -106,7 +106,47 @@ rtems_task Init(rtems_task_argument ignored)
>        printf("fesetexceptflag ==> 0x%x\n", r);
>      rtems_test_assert(r == 0);
>Similarly, the ability to trigger coverity scan on a
> +    /*test for fegetround() and fesetround()*/
add white space around text
> +    /*they have four main macros to be tested seperated by ifdef*/
typo: separated
> +    /* since all the architectures dont support them */
typo: don't
grammer: "since not all architectures support them" would be better.
"all the architectures don't support them" means there is no support
at all.
> +    /*the test cases gets and sets the rounding directions */
typo: case
> +#ifdef FE_TONEAREST
no blank line needed/wanted after #ifdef statements
> +    r=fegetround();
whitespace needed around =. Please review
https://docs.rtems.org/branches/master/eng/coding.html
> +    if(r)
whitespace needed, and brackets needed even for 1-line blocks.
> +       printf("fegetround ==> 0x%x\n", r);
> +    rtems_test_assert(r == FE_TONEAREST) ;
> +#endif
> +#ifdef FE_TOWARDZERO
The same errors from above repeat here and below. fix all.
> +  r=fesetround(FE_TOWARDZERO);
> +  if(r)
> +       printf("fesetround ==> 0x%x\n", r);
> +  rtems_test_assert(r == 0) ;
> +  rtems_test_assert(fegetround() == FE_TOWARDZERO) ;
> +#endif
> +#ifdef FE_DOWNWARD
> +  r=fesetround(FE_DOWNWARD);
> +  if(r)
> +  rtems_test_assert(fegetround() == FE_DOWNWARD) ;
> +#endif
> +#ifdef FE_UPWARD
> +  r=fesetround(FE_UPWARD);
> +  if(r)
> +  rtems_test_assert(fegetround() == FE_UPWARD) ;
> +#endif
> +  r=fesetround(FE_TONEAREST);
> +  if(r)
> +#endif
>  #ifdef FE_DIVBYZERO
> 2.17.1
> devel mailing list
> devel at rtems.org
