Improve Coverity Scan Integration: GSOC project details
Sebastian Huber
Mon Mar 2 17:16:41 UTC 2020
----- Am 2. Mrz 2020 um 17:02 schrieb Gedare Bloom gedare at rtems.org:
> On Sun, Mar 1, 2020 at 6:31 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Sun, Mar 1, 2020, 1:02 PM suyash singh <suyashsingh234 at gmail.com> wrote:
>>> This is regarding the project I would like to work in
>>> https://devel.rtems.org/ticket/3710
>>> FIRST POINT-
>>> I was thinking about implementing Coverity or clang analyzer as an offline
>>> analyzer. Would it be a suitable idea to make a separate repo just for testing
>>> purposes?
>>> This "testing repository" will have the updated rtems code as well the analyzer
>>> in it. If possible this repo will be updated automatically from the main repo.
>> I would have to see how the clang analyser is run against the RTEMS source. My
>> expectation would be that ultimately something would be added to rtems-tools to
>> run the analysis process and generate reports.
>> The reports could then be locally generated or run on an rtems.org server for
>> publication.
>> I don't see needing a private RTEMS repository. This should be an rtems-tools
>> project and you would only have a personal copy of that for the purposes of
>> getting reviews. Usually patches just get submitted and you don't need a public
>> facing repo at all.
> I have someone attempting to replicate the recent instructions how to
> use clang-analyzer. I will share results if we succeed.
> It is possible to run open-source analyzers (like clang, cppcheck) on
> a repo. For a GSoC, it would be fine to work on an RTEMS/RTEMS-Tools
> fork, with the intent to deliver upstream.
For GSoC I would focus on the open tools. For clang-analyzer there is also the Thread Safety Analysis.
https://clang.llvm.org/docs/ThreadSafetyAnalysis.html
It could be used for the SMP locks for example. There are also the LLVM sanitizers:
https://github.com/google/sanitizers
I expect that most bugs will be in RTEMS applications and the complex network and device driver frameworks, e.g. libbsd. Being able to use some of the sanitizers in RTEMS would be great. The question is if you need virtual memory for them.
> Unfortunately, you can't easily run Coverity offline or on your own
> repository. To use the free version you need to run it through their
> interface. At least, I don't know if you can download/run
> coverity-scan free version. That is something you could take a look
> at. Longer term, I don't think Coverity is the right tool for the
> community because of the restrictions on the open version. However, we
> should continue to improve how we use it. I'm becoming more convinced
> that we need to identify suitable open-source static analysis tools
> that help us to improve our products.
A big problem with Coverity is that the documentation is not open.
