[PATCH 4/5] console: Use IMFS_add_node() for simple console
Tue Mar 3 10:50:15 UTC 2020
Update #3894.
 cpukit/libcsupport/src/consolesimple.c | 55 +++++++++++++++++++++++-----------
 1 file changed, 38 insertions(+), 17 deletions(-)
diff --git a/cpukit/libcsupport/src/consolesimple.c b/cpukit/libcsupport/src/consolesimple.c
index 94aa40c9fd..4316fa321a 100644
--- a/cpukit/libcsupport/src/consolesimple.c
+++ b/cpukit/libcsupport/src/consolesimple.c
@@ -1,17 +1,34 @@
- * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ * Copyright (C) 2017, 2020 embedded brains GmbH (http://www.embedded-brains.de)
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
+ * are met:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
 #include <rtems/console.h>
 #include <rtems/bspIo.h>
 #include <rtems/imfs.h>
@@ -56,18 +73,22 @@ static const rtems_filesystem_file_handlers_r _Console_simple_Handlers = {
 static const IMFS_node_control
-_Console_simple_Node_control = IMFS_GENERIC_INITIALIZER(
+_Console_simple_Node_control = IMFS_NODE_CONTROL_INITIALIZER(
   &_Console_simple_Handlers,
   IMFS_node_initialize_default,
-  IMFS_node_destroy_default
+  IMFS_do_nothing_destroy
+static const char _Console_simple_Name[] = "console";
+static IMFS_jnode_t _Console_simple_Node = IMFS_NODE_INITIALIZER(
+  &_Console_simple_Node_control,
+  _Console_simple_Name,
+  sizeof( _Console_simple_Name ) - 1,
+  S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO
 void _Console_simple_Initialize( void )
-  IMFS_make_generic_node(
-    CONSOLE_DEVICE_NAME,
-    S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
-    &_Console_simple_Node_control,
-    NULL
+  IMFS_add_node( "/dev", &_Console_simple_Node, NULL );
2.16.4
