[PATCH v2 1/4] added fesetexeptflag() test to the psxfenv test
Eshan Dhawan eshandhawan51 at gmail.com
Wed Mar 4 17:41:57 UTC 2020
This is an old patch
> On 04-Mar-2020, at 10:11 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 3, 2020 at 12:50 PM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>> testsuites/psxtests/psxfenv01/init.c | 36 ++++++++++++++++++++++++----
>> 1 file changed, 31 insertions(+), 5 deletions(-)
>> diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>> index cdb0fa596e..8ffb9395b9 100644
>> --- a/testsuites/psxtests/psxfenv01/init.c
>> +++ b/testsuites/psxtests/psxfenv01/init.c
>> @@ -46,6 +46,9 @@
>> #include <string.h>
>> #include <rtems/test.h>
>> #include <tmacros.h>
>> +#include <assert.h>
>> +#define rtems_test_assert(x) assert(x)
> Why do you add this? It should be coming in from tmacros.h already.
>> const char rtems_test_name[] = "PSXFENV 01";
>> @@ -71,19 +74,19 @@ rtems_task Init(rtems_task_argument ignored)
>>     r = fesetenv(FE_DFL_ENV);
>>     if (r)
>>       printf("fesetenv ==> %d\n", r);
>> -    rtems_test_assert( r == 0 );
>> +    assert( r == 0 );
> Why do you change this?
>>     /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>>     puts( "feclearexcept(FE_ALL_EXCEPT)." );
>>     r = feclearexcept(FE_ALL_EXCEPT);
>>     if (r)
>>       printf("feclearexcept ==> 0x%x\n", r);
>> +    assert( r == 0 );
>>     r = fetestexcept( FE_ALL_EXCEPT );
>>     if (r)
>>       printf("fetestexcept ==> 0x%x\n", r);
>> +    assert( r == 0 );
>>     /* Test 'FE_DIVBYZERO' */
>>     puts( "Divide by zero and confirm fetestexcept()" );
>> @@ -91,12 +94,22 @@ rtems_task Init(rtems_task_argument ignored)
>>     b = 1.0;
>>     c = b/a;
>>     (void) c;
>> +    /* Test fegetexceptflag() and fesetexceptflag().*/
>> +    r=fegetexceptflag(&excepts,FE_ALL_EXCEPT);
> white space is still wrong. please reread the coding conventions, it
> should be more like
> r = fegetexceptflag( &excepts, FE_ALL_EXCEPT );
>> +    if(r)
>> +      printf("fegetexceptflag ==> 0x%x\n", r);
>> +    assert(r == 0);
>> +    r=fesetexceptflag(&excepts, FE_ALL_EXCEPT);
>> +    if(r)
>> +      printf("fesetexceptflag ==> 0x%x\n", r);
>> +    assert(r == 0);
>> -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>> #ifdef FE_DIVBYZERO
>>     r = feraiseexcept(FE_DIVBYZERO);
>> -    rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>> +    assert( fetestexcept( FE_DIVBYZERO ) );
>> #endif
>>     /* Test 'FE_INEXACT' */
>> @@ -125,3 +138,16 @@ rtems_task Init(rtems_task_argument ignored)
>> #define CONFIGURE_INIT
>> #include <rtems/confdefs.h>
>> /* end of file */
> Why is this added here?
> It is also odd to have stuff after a comment that says "end of file"?
>> +    fegetenv()
>> +    fegetround()
>> +    feholdexcept()
>> +    fesetexceptflag()
>> +    fesetround()
>> +    feupdateenv()
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
