[PATCH v3] tests for fenv.h functions
Gedare Bloom
gedare at rtems.org
Thu Mar 5 13:39:06 UTC 2020
On Thu, Mar 5, 2020 at 12:17 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> If you want I would set the case in that manner.
> On Thu, Mar 5, 2020 at 12:46 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> On Thu, Mar 5, 2020 at 4:37 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 4, 2020 at 11:12 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>>> > testsuites/psxtests/psxfenv01/init.c | 72 ++++++++++++++++++++++++++--
>>> > 1 file changed, 68 insertions(+), 4 deletions(-)
>>> > diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>>> > index cdb0fa596e..40c29e4fac 100644
>>> > --- a/testsuites/psxtests/psxfenv01/init.c
>>> > +++ b/testsuites/psxtests/psxfenv01/init.c
>>> > @@ -46,6 +46,10 @@
>>> > #include <string.h>
>>> > #include <rtems/test.h>
>>> > #include <tmacros.h>
>>> > +#include <assert.h>
>>> I don't think this include is necessary?
>>> > +#include <float.h>
>>> Don't add extra vertical space unnecessarily. In general, there should
>>> never be more than 1 blank line consecutively anywhere.
>>> > const char rtems_test_name[] = "PSXFENV 01";
>>> > @@ -69,20 +73,23 @@ rtems_task Init(rtems_task_argument ignored)
>>> > #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>>> > puts( "fesetenv(FE_DFL_ENV)." );
>>> > r = fesetenv(FE_DFL_ENV);
>>> > - if (r)
>>> > + if (r){
>>> Almost, need some more spaces around 'r' and between '){', like this:
>>> "if ( r ) {"
>>> > printf("fesetenv ==> %d\n", r);
>>> > rtems_test_assert( r == 0 );
>>> > /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>>> > puts( "feclearexcept(FE_ALL_EXCEPT)." );
>>> > r = feclearexcept(FE_ALL_EXCEPT);
>>> > - if (r)
>>> > + if (r){
>>> > printf("feclearexcept ==> 0x%x\n", r);
>>> > r = fetestexcept( FE_ALL_EXCEPT );
>>> > - if (r)
>>> > + if (r){
>>> > printf("fetestexcept ==> 0x%x\n", r);
>>> > /* Test 'FE_DIVBYZERO' */
>>> > @@ -91,8 +98,63 @@ rtems_task Init(rtems_task_argument ignored)
>>> > b = 1.0;
>>> > c = b/a;
>>> > (void) c;
>>> > + /* Test 'fegetexceptflag()' and 'fesetexceptflag()' */
>>> > + r = fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>>> also need to add whitespace after commas.
>>> > + if(r){
>>> > + printf("fegetexceptflag ==> 0x%x\n", r);
>>> > + rtems_test_assert(r == 0);
>>> > + r = fesetexceptflag(&excepts, FE_ALL_EXCEPT);
>>> spaces between ( ).
>>> > + if(r){
>>> > + printf("fesetexceptflag ==> 0x%x\n", r);
>>> ditto
>>> 2 blanks
>>> > + /* Test for 'fegetround()' and 'fesetround()' */
>>> > + /* They have four main macros to be tested seperated by ifdef*/
>>> > + /* Since not all architectures support them */
>>> > + /* The test case gets and sets the rounding directions */
>>> Merge multiline comments with a single comment block
>>> /* Test for ...
>>> * They have ...
>>> * Since not ...
>>> * The test case ...
>>> > +#ifdef FE_TONEAREST
>>> > + r = fegetround();
>>> > + if(r){
>>> > + printf("fegetround ==> 0x%x\n", r);
>>> > + rtems_test_assert(r == FE_TONEAREST) ;
>>> Is FE_TONEAREST expected to be the default behavior without any calls
>>> to fesetround?
>> No, We have to define the rounding direction flag in the function call.
>> FE_TONEAREST is the default rounding direction if nothing is specified.
>>> Why not do something like you did below, with rtems_test_assert(
>>> fegetround() == FE_TONEAREST );?
>> I have used this way only in this test case because if there is an error with fegetround(),
>> we could get the error code.
>>> > +#endif
>>> > +#ifdef FE_TOWARDZERO
>>> > + r = fesetround(FE_TOWARDZERO);
>>> > + if(r){
>>> > + printf("fesetround ==> 0x%x\n", r);
>>> > + rtems_test_assert(r == 0) ;
>>> > + rtems_test_assert(fegetround() == FE_TOWARDZERO) ;
>>> This is a nice, concise way to test the rounding condition. Why not do
>>> the same above with FE_TONEAREST?
>> we wouldn't get any error code sent by the function in this method.
>> So, if there is an error in the default then I would want it to be displayed.
rtems_test_assert macro will print the condition that failed, so the
display would be redundant. You can just use the simpler, concise
version to make a smaller code.
>>> > +#endif
>>> > +#ifdef FE_DOWNWARD
>>> > + r = fesetround(FE_DOWNWARD);
>>> > + if(r){
>>> > + rtems_test_assert(fegetround() == FE_DOWNWARD) ;
>>> > +#endif
>>> > +#ifdef FE_UPWARD
>>> > + r = fesetround(FE_UPWARD);
>>> > + if(r){
>>> > + rtems_test_assert(fegetround() == FE_UPWARD) ;
>>> > +#endif
>>> > + r = fesetround(FE_TONEAREST);
>>> > + if(r){
>>> > +#endif
>>> > - fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>>> > #ifdef FE_DIVBYZERO
>>> > r = feraiseexcept(FE_DIVBYZERO);
>>> > @@ -125,3 +187,5 @@ rtems_task Init(rtems_task_argument ignored)
>>> > #define CONFIGURE_INIT
>>> > #include <rtems/confdefs.h>
>>> > /* end of file */
>>> Don't add blank lines randomly.
>>> > 2.17.1
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
