[PATCH] c-user: Document task memory
Thu Mar 5 14:06:19 UTC 2020
On Thu, Mar 5, 2020 at 5:22 AM Sebastian Huber
> Close #3835.
>  c-user/task_manager.rst | 65 ++++++++++++++++++++++++++++++++++++++++---------
>  1 file changed, 53 insertions(+), 12 deletions(-)
> diff --git a/c-user/task_manager.rst b/c-user/task_manager.rst
> index fdbf41b..f3eba91 100644
> --- a/c-user/task_manager.rst
> +++ b/c-user/task_manager.rst
> @@ -1,5 +1,6 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
>  .. index:: tasks
> @@ -82,6 +83,8 @@ From RTEMS' perspective, a task is the smallest thread of execution which can
>  compete on its own for system resources.  A task is manifested by the existence
>  of a task control block (TCB).
> +.. _TaskControlBlock:
>  Task Control Block
> @@ -103,6 +106,35 @@ regains control of the processor, its context is restored from the TCB.  When a
>  task is restarted, the initial state of the task is restored from the starting
>  context area in the task's TCB.
> +.. index:: task memory
> +Task Memory
> +The system uses two separate memory areas to manage a task.  One memory area is
> +the :ref:`TaskControlBlock`.  The other memory area is allocated from the stack
> +space or provided by the user and contains
> +* the task stack,
> +* the thread-local storage (:term:`TLS`), and
> +* an optional architecture-specific floating-point context.
> +The size of the thread-local storage is determined at link time.  A
> +user-provided task stack must take the size of the thread-local storage into
> +account.
> +On architectures with a dedicated floating-point context, the application
> +configuration assumes that every task is a floating-point task.  However,
> +whether a task is actually a floating-point task or not, is determined at
> +runtime during task creation (see :ref:`TaskFloatingPointConsiderations`).  In
I think it can be unclear that the referred section will also clarify
about the arch fp context in case the reader is unclear. Maybe:
"On architectures with a dedicated floating-point context, the application
configuration assumes that every task is a floating-point task, but
whether or not a task is actually floating-point is determined at
runtime during task creation (see :ref:`TaskFloatingPointConsiderations`)."
Just to put both thoughts together along with the reference.
> +highly memory constraint systems this potential overestimate of the task stack
constraint -> constrained
Rest looks fine, thanks.
> +space can be mitigated through the :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`
> +configuration option and aligned task stack sizes for the tasks.  A
> +user-provided task stack must take the potential floating-point context into
> +account.
>  .. index:: task name
>  Task Name
> @@ -271,25 +303,31 @@ an index into an array of parameter blocks.
>  .. index:: floating point
> +.. _TaskFloatingPointConsiderations:
>  Floating Point Considerations
> +Please consult the *RTEMS CPU Architecture Supplement* if this section is
> +relevant on your architecture.  On some architectures the floating-point context
> +is contained in the normal task context and this section does not apply.
>  Creating a task with the ``RTEMS_FLOATING_POINT`` attribute flag results in
> -additional memory being allocated for the TCB to store the state of the numeric
> -coprocessor during task switches.  This additional memory is *NOT* allocated for
> -``RTEMS_NO_FLOATING_POINT`` tasks. Saving and restoring the context of a
> +additional memory being allocated for the task to store the state of the numeric
> +coprocessor during task switches.  This additional memory is **not** allocated
> +for ``RTEMS_NO_FLOATING_POINT`` tasks. Saving and restoring the context of a
>  ``RTEMS_FLOATING_POINT`` task takes longer than that of a
>  ``RTEMS_NO_FLOATING_POINT`` task because of the relatively large amount of time
> -required for the numeric coprocessor to save or restore its computational
> -state.
> +required for the numeric coprocessor to save or restore its computational state.
>  Since RTEMS was designed specifically for embedded military applications which
>  are floating point intensive, the executive is optimized to avoid unnecessarily
> -saving and restoring the state of the numeric coprocessor.  The state of the
> -numeric coprocessor is only saved when a ``RTEMS_FLOATING_POINT`` task is
> -dispatched and that task was not the last task to utilize the coprocessor.  In
> -a system with only one ``RTEMS_FLOATING_POINT`` task, the state of the numeric
> -coprocessor will never be saved or restored.
> +saving and restoring the state of the numeric coprocessor.  In uniprocessor
> +configurations, the state of the numeric coprocessor is only saved when a
> +``RTEMS_FLOATING_POINT`` task is dispatched and that task was not the last task
> +to utilize the coprocessor.  In a uniprocessor system with only one
> +``RTEMS_FLOATING_POINT`` task, the state of the numeric coprocessor will never
> +be saved or restored.
>  Although the overhead imposed by ``RTEMS_FLOATING_POINT`` tasks is minimal,
>  some applications may wish to completely avoid the overhead associated with
> @@ -299,10 +337,13 @@ point operations, a ``RTEMS_NO_FLOATING_POINT`` task can utilize the numeric
>  coprocessor without incurring the overhead of a ``RTEMS_FLOATING_POINT``
>  context switch.  This approach also avoids the allocation of a floating point
>  context area.  However, if this approach is taken by the application designer,
> -NO tasks should be created as ``RTEMS_FLOATING_POINT`` tasks.  Otherwise, the
> +**no** tasks should be created as ``RTEMS_FLOATING_POINT`` tasks.  Otherwise, the
>  floating point context will not be correctly maintained because RTEMS assumes
>  that the state of the numeric coprocessor will not be altered by
> +``RTEMS_NO_FLOATING_POINT`` tasks.  Some architectures with a dedicated
> +floating-point context raise a processor exception if a task with
> +``RTEMS_NO_FLOATING_POINT`` issues a floating-point instruction, so this
> +approach may not work at all.
>  If the supported processor type does not have hardware floating capabilities or
>  a standard numeric coprocessor, RTEMS will not provide built-in support for
> 2.16.4
> devel mailing list
> devel at rtems.org
