[PATCH] waf: Change the test configure check for libdebugger to it's lib
Chris Johns
chrisj at rtems.org
Thu Mar 5 23:09:02 UTC 2020
On 2020-03-06 00:58, Gedare Bloom wrote:
> On Thu, Mar 5, 2020 at 3:23 AM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>> - Add support for a 'test-if-library'
>> - Use rtems_waf's 'test_application()' fragment in the check_cc
>> call
>> Closes #3948
>> builder.py | 30 +++++++++++++++++++++++++++---
>> libbsd.py | 4 ++--
>> waf_libbsd.py | 28 +++++++++++++++++++++-------
>> 3 files changed, 50 insertions(+), 12 deletions(-)
>> diff --git a/builder.py b/builder.py
>> index 2921bab8..0eda461f 100755
>> --- a/builder.py
>> +++ b/builder.py
>> @@ -505,15 +505,17 @@ class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
>> class TestFragementComposer(BuildSystemFragmentComposer):
>> - def __init__(self, testName, fileFragments, runTest = True, netTest = False, extraLibs = []):
>> + def __init__(self, testName, fileFragments, configTest = None, runTest = True, netTest = False, extraLibs = []):
> I'm trying to pay more attention to the Python code. This method
> definition is overlong.
In isolation it is but I am only following what is used in this code
rather than changing it in small pieces. For example just above ...
https://git.rtems.org/rtems-libbsd/tree/builder.py#n508
