[PATCH] psim-device-tree: Rework so devices do not conflict with 256MB RAM
Joel Sherrill
joel at rtems.org
Thu Mar 5 23:56:29 UTC 2020
closes #3849.
tester/rtems/testing/bsps/psim-device-tree | 36 +++++++++++++++---------------
1 file changed, 18 insertions(+), 18 deletions(-)
diff --git a/tester/rtems/testing/bsps/psim-device-tree b/tester/rtems/testing/bsps/psim-device-tree
index d0b5f7c..f2feca4 100644
--- a/tester/rtems/testing/bsps/psim-device-tree
+++ b/tester/rtems/testing/bsps/psim-device-tree
@@ -4,24 +4,24 @@
/#address-cells 1
/openprom/init/register/pvr 0xfffe0000
/openprom/options/oea-memory-size 0x10000000
-##### EEPROM @ 0x0c000000 for 512K
-/eeprom at 0x0c000000/reg 0x0c000000 0x80000
-/eeprom at 0x0c000000/nr-sectors 8
-/eeprom at 0x0c000000/sector-size 0x10000
-/eeprom at 0x0c000000/byte-write-delay 1000
-/eeprom at 0x0c000000/sector-start-delay 100
-/eeprom at 0x0c000000/erase-delay 1000
-/eeprom at 0x0c000000/manufacture-code 0x01
-/eeprom at 0x0c000000/device-code 0xa4
+##### EEPROM @ 0xfc000000 for 512K
+/eeprom at 0xfc000000/reg 0xfc000000 0x80000
+/eeprom at 0xfc000000/nr-sectors 8
+/eeprom at 0xfc000000/sector-size 0x10000
+/eeprom at 0xfc000000/byte-write-delay 1000
+/eeprom at 0xfc000000/sector-start-delay 100
+/eeprom at 0xfc000000/erase-delay 1000
+/eeprom at 0xfc000000/manufacture-code 0x01
+/eeprom at 0xfc000000/device-code 0xa4
-##### NVRAM/RTC NVRAM Portion is 0x0c080000 for 512K
-##### NVRAM/RTC RTC Portion is 0x0c100000 for 12
-/nvram at 0x0c080000/reg 0x0c080000 524300
-/nvram at 0x0c080000/timezone -3600
+##### NVRAM/RTC NVRAM Portion is 0xfc080000 for 512K
+##### NVRAM/RTC RTC Portion is 0xfc100000 for 12
+/nvram at 0xfc080000/reg 0xfc080000 524300
+/nvram at 0xfc080000/timezone -3600
-##### OPENPIC @ 0x0c130000 - 0x0c170000 (512K)
-/opic at 0x0c130000/reg 0x0c130000 0 0x0c130000 0x40000
-/opic at 0x0c130000/interrupt-ranges 0 0 0 16
-/opic at 0x0c130000/device_type open-pic
+##### OPENPIC @ 0xfc130000 - 0xfc170000 (512K)
+/opic at 0xfc130000/reg 0xfc130000 0 0xfc130000 0x40000
+/opic at 0xfc130000/interrupt-ranges 0 0 0 16
+/opic at 0xfc130000/device_type open-pic
## interupt out -> CPU's interrupt pin
-/opic at 0x0c130000 > intr0 int /cpus/cpu at 0
+/opic at 0xfc130000 > intr0 int /cpus/cpu at 0
1.8.3.1
