[PATCH v4] tests for fenv.h functions
Eshan Dhawan eshandhawan51 at gmail.com
Fri Mar 6 05:04:51 UTC 2020
Ok,I will implement the changes and send the patch
Thanks
Eshan
> On 06-Mar-2020, at 3:12 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Getting there, see below.
>> On Thu, Mar 5, 2020 at 12:22 PM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>> testsuites/psxtests/psxfenv01/init.c | 68 +++++++++++++++++++++++++---
>> 1 file changed, 62 insertions(+), 6 deletions(-)
>> diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>> index cdb0fa596e..595d340983 100644
>> --- a/testsuites/psxtests/psxfenv01/init.c
>> +++ b/testsuites/psxtests/psxfenv01/init.c
>> @@ -46,6 +46,7 @@
>> #include <string.h>
>> #include <rtems/test.h>
>> #include <tmacros.h>
>> +#include <float.h>
>> const char rtems_test_name[] = "PSXFENV 01";
>> @@ -69,20 +70,23 @@ rtems_task Init(rtems_task_argument ignored)
>>   #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>>     puts( "fesetenv(FE_DFL_ENV)." );
>>     r = fesetenv(FE_DFL_ENV);
>> -    if (r)
>> +    if ( r ) {
>>       printf("fesetenv ==> %d\n", r);
>>     rtems_test_assert( r == 0 );
>>     /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>>     puts( "feclearexcept(FE_ALL_EXCEPT)." );
>>     r = feclearexcept(FE_ALL_EXCEPT);
>> -    if (r)
>> +    if ( r ) {
>>       printf("feclearexcept ==> 0x%x\n", r);
>>     r = fetestexcept( FE_ALL_EXCEPT );
>> -    if (r)
>> +    if (r){
> whitespace
>>       printf("fetestexcept ==> 0x%x\n", r);
>>     /* Test 'FE_DIVBYZERO' */
>> @@ -91,9 +95,59 @@ rtems_task Init(rtems_task_argument ignored)
>>     b = 1.0;
>>     c = b/a;
>>     (void) c;
>> -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>> +    /* Test 'fegetexceptflag()' and 'fesetexceptflag()' */
> no need for the single quotes here ' ' around the function names.
>> +    r = fegetexceptflag( &excepts ,FE_ALL_EXCEPT );
>> +    if ( r ) {
>> +      printf("fegetexceptflag ==> 0x%x\n", r);
>> +    rtems_test_assert(r == 0);
>> +    r = fesetexceptflag( &excepts ,FE_ALL_EXCEPT );
>> +    if ( r ) {
>> +      printf("fesetexceptflag ==> 0x%x\n", r);
> avoid 2 blank lines in a row
>> +    /* Test for 'fegetround()' and 'fesetround()'
>> +     * They have four main macros to be tested seperated by ifdef
> typo: separated
>> +     * Since not all architectures support them
>> +     * The test case gets and sets the rounding directions */
>> +#ifdef FE_TONEAREST
>> +    rtems_test_assert( fegetround() == FE_TONEAREST ) ;
>> +#endif
>> +#ifdef FE_TOWARDZERO
>> +  r = fesetround(FE_TOWARDZERO);
>> +  if( r ) {
> whitespace after if
>> +      printf("fesetround ==> 0x%x\n", r);
>> +  rtems_test_assert( r == 0 ) ;
>> +  rtems_test_assert( fegetround() == FE_TOWARDZERO ) ;
>> +#endif
>> +#ifdef FE_DOWNWARD
>> +  r = fesetround( FE_DOWNWARD );
>> +  if(r){
> ws
>> +  rtems_test_assert( fegetround() == FE_DOWNWARD ) ;
>> +#endif
>> +#ifdef FE_UPWARD
>> +  r = fesetround( FE_UPWARD );
>> +  if( r ) {
> ws
>> +  rtems_test_assert( fegetround() == FE_UPWARD ) ;
>> +#endif
>> +  r = fesetround( FE_TONEAREST );
>> +  if ( r ) {
>> +#endif
>> #ifdef FE_DIVBYZERO
>>     r = feraiseexcept(FE_DIVBYZERO);
>>     rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>> @@ -125,3 +179,5 @@ rtems_task Init(rtems_task_argument ignored)
>> #define CONFIGURE_INIT
>> #include <rtems/confdefs.h>
>> /* end of file */
> Don't add extra blank lines
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
