[PATCH 2/5] imfs: Constify imfs_memfile_bytes_per_block
Fri Mar 6 06:47:57 UTC 2020
The CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK value is validated by
<rtems/confdefs/libio.h>.  Changing this value during runtime could lead
to memory corruption.
Update #3894.
 cpukit/include/rtems/confdefs/libio.h  |  2 +-
 cpukit/include/rtems/imfs.h            |  3 +--
 cpukit/libfs/src/imfs/imfs_initsupp.c  | 35 ----------------------------------
 cpukit/libfs/src/imfs/imfs_stat_file.c |  2 --
 4 files changed, 2 insertions(+), 40 deletions(-)
diff --git a/cpukit/include/rtems/confdefs/libio.h b/cpukit/include/rtems/confdefs/libio.h
index aced98b3b9..3c45771952 100644
--- a/cpukit/include/rtems/confdefs/libio.h
+++ b/cpukit/include/rtems/confdefs/libio.h
@@ -196,7 +196,7 @@ static const devFS_data _Filesystem_Root_data = {
   #error "CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK must be a power of two between 16 and 512"
 #endif
-int imfs_rq_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
+const int imfs_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
 static IMFS_fs_info_t _IMFS_fs_info;
diff --git a/cpukit/include/rtems/imfs.h b/cpukit/include/rtems/imfs.h
index 565d103226..09e8bd4a9d 100644
--- a/cpukit/include/rtems/imfs.h
+++ b/cpukit/include/rtems/imfs.h
@@ -66,8 +66,7 @@ typedef struct IMFS_jnode_tt IMFS_jnode_t;
  *  @endcode
 #define IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK     128
-  extern int imfs_rq_memfile_bytes_per_block;
-  extern int imfs_memfile_bytes_per_block;
+  extern const int imfs_memfile_bytes_per_block;
 #define IMFS_MEMFILE_BYTES_PER_BLOCK imfs_memfile_bytes_per_block
 #define IMFS_MEMFILE_BLOCK_SLOTS \
diff --git a/cpukit/libfs/src/imfs/imfs_initsupp.c b/cpukit/libfs/src/imfs/imfs_initsupp.c
index 124a1622c9..58ec41f269 100644
--- a/cpukit/libfs/src/imfs/imfs_initsupp.c
+++ b/cpukit/libfs/src/imfs/imfs_initsupp.c
@@ -21,35 +21,6 @@
 #include <rtems/imfs.h>
-#include <stdlib.h>
-#include <string.h>
-#include <unistd.h>
-static int IMFS_determine_bytes_per_block(
-  int *dest_bytes_per_block,
-  int requested_bytes_per_block,
-  int default_bytes_per_block
-  bool is_valid = false;
-  int bit_mask;
-   * check, whether requested bytes per block is valid
-  for (bit_mask = 16; !is_valid && (bit_mask <= 512); bit_mask <<= 1) {
-    if (bit_mask == requested_bytes_per_block) {
-      is_valid = true;
-      break;
-    if(bit_mask > requested_bytes_per_block)
-      break;
-  *dest_bytes_per_block = ((is_valid)
-			   ? requested_bytes_per_block
-			   : default_bytes_per_block);
-  return 0;
 int IMFS_initialize_support(
   rtems_filesystem_mount_table_entry_t *mt_entry,
@@ -78,12 +49,6 @@ int IMFS_initialize_support(
   mt_entry->mt_fs_root->location.node_access = root_node;
   IMFS_Set_handlers( &mt_entry->mt_fs_root->location );
-  IMFS_determine_bytes_per_block(
-    &imfs_memfile_bytes_per_block,
-    imfs_rq_memfile_bytes_per_block,
-    IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK
   return 0;
diff --git a/cpukit/libfs/src/imfs/imfs_stat_file.c b/cpukit/libfs/src/imfs/imfs_stat_file.c
index 0135fe43e3..ef1d0095a6 100644
--- a/cpukit/libfs/src/imfs/imfs_stat_file.c
+++ b/cpukit/libfs/src/imfs/imfs_stat_file.c
@@ -19,8 +19,6 @@
-int imfs_memfile_bytes_per_block;
 int IMFS_stat_file(
   const rtems_filesystem_location_info_t *loc,
   struct stat *buf
2.16.4
