[PATCH 1/3] i386: Add missing files from FreeBSD
Jan Sommer jan.sommer at dlr.de
Fri Mar 6 10:08:44 UTC 2020
- Files needed to make rtems-libbsd build again for i386
 .../sys/x86/include/machine/intr_machdep.h    | 180 ++++++++
 freebsd/sys/x86/include/machine/legacyvar.h   |  73 ++++
 freebsd/sys/x86/x86/legacy.c                  | 404 ++++++++++++++++++
 3 files changed, 657 insertions(+)
 create mode 100644 freebsd/sys/x86/include/machine/intr_machdep.h
 create mode 100644 freebsd/sys/x86/include/machine/legacyvar.h
 create mode 100644 freebsd/sys/x86/x86/legacy.c
diff --git a/freebsd/sys/x86/include/machine/intr_machdep.h b/freebsd/sys/x86/include/machine/intr_machdep.h
new file mode 100644
index 00000000..4818e932
--- /dev/null
+++ b/freebsd/sys/x86/include/machine/intr_machdep.h
@@ -0,0 +1,180 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2003 John Baldwin <jhb at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __X86_INTR_MACHDEP_H__
+#define	__X86_INTR_MACHDEP_H__
+#ifdef _KERNEL
+ * Values used in determining the allocation of IRQ values among
+ * different types of I/O interrupts.  These values are used as
+ * indices into a interrupt source array to map I/O interrupts to a
+ * device interrupt source whether it be a pin on an interrupt
+ * controller or an MSI interrupt.  The 16 ISA IRQs are assigned fixed
+ * IDT vectors, but all other device interrupts allocate IDT vectors
+ * on demand.  Currently we have 191 IDT vectors available for device
+ * interrupts on each CPU.  On many systems with I/O APICs, a lot of
+ * the IRQs are not used, so the total number of IRQ values reserved
+ * can exceed the number of available IDT slots.
+ * The first 16 IRQs (0 - 15) are reserved for ISA IRQs.  Interrupt
+ * pins on I/O APICs for non-ISA interrupts use IRQ values starting at
+ * IRQ 17.  This layout matches the GSI numbering used by ACPI so that
+ * IRQ values returned by ACPI methods such as _CRS can be used
+ * directly by the ACPI bus driver.
+ * MSI interrupts allocate a block of interrupts starting at either
+ * the end of the I/O APIC range or 256, whichever is higher.  When
+ * running under the Xen Hypervisor, an additional range of IRQ values
+ * are available for binding to event channel events.  We use 256 as
+ * the minimum IRQ value for MSI interrupts to attempt to leave 255
+ * unused since 255 is used in PCI to indicate an invalid INTx IRQ.
+#define	MINIMUM_MSI_INT	256
+extern u_int first_msi_irq;
+extern u_int num_io_irqs;
+extern u_int num_msi_irqs;
+ * Default base address for MSI messages on x86 platforms.
+#define	MSI_INTEL_ADDR_BASE		0xfee00000
+#ifndef LOCORE
+typedef void inthand_t(void);
+#define	IDTVEC(name)	__CONCAT(X,name)
+struct intsrc;
+ * Methods that a PIC provides to mask/unmask a given interrupt source,
+ * "turn on" the interrupt on the CPU side by setting up an IDT entry, and
+ * return the vector associated with this source.
+struct pic {
+	void (*pic_register_sources)(struct pic *);
+	void (*pic_enable_source)(struct intsrc *);
+	void (*pic_disable_source)(struct intsrc *, int);
+	void (*pic_eoi_source)(struct intsrc *);
+	void (*pic_enable_intr)(struct intsrc *);
+	void (*pic_disable_intr)(struct intsrc *);
+	int (*pic_vector)(struct intsrc *);
+	int (*pic_source_pending)(struct intsrc *);
+	void (*pic_suspend)(struct pic *);
+	void (*pic_resume)(struct pic *, bool suspend_cancelled);
+	int (*pic_config_intr)(struct intsrc *, enum intr_trigger,
+	    enum intr_polarity);
+	int (*pic_assign_cpu)(struct intsrc *, u_int apic_id);
+	void (*pic_reprogram_pin)(struct intsrc *);
+	TAILQ_ENTRY(pic) pics;
+/* Flags for pic_disable_source() */
+enum {
+	PIC_EOI,
+	PIC_NO_EOI,
+ * An interrupt source.  The upper-layer code uses the PIC methods to
+ * control a given source.  The lower-layer PIC drivers can store additional
+ * private data in a given interrupt source such as an interrupt pin number
+ * or an I/O APIC pointer.
+struct intsrc {
+	struct pic *is_pic;
+	struct intr_event *is_event;
+	u_long *is_count;
+	u_long *is_straycount;
+	u_int is_index;
+	u_int is_handlers;
+	u_int is_domain;
+	u_int is_cpu;
+struct trapframe;
+#ifdef SMP
+extern cpuset_t intr_cpus;
+#endif
+extern struct mtx icu_lock;
+extern int elcr_found;
+#ifdef SMP
+extern int msix_disable_migration;
+#endif
+#ifndef DEV_ATPIC
+void	atpic_reset(void);
+#endif
+/* XXX: The elcr_* prototypes probably belong somewhere else. */
+int	elcr_probe(void);
+enum intr_trigger elcr_read_trigger(u_int irq);
+void	elcr_resume(void);
+void	elcr_write_trigger(u_int irq, enum intr_trigger trigger);
+#ifdef SMP
+void	intr_add_cpu(u_int cpu);
+#endif
+int	intr_add_handler(const char *name, int vector, driver_filter_t filter,
+    driver_intr_t handler, void *arg, enum intr_type flags, void **cookiep,
+    int domain);
+#ifdef SMP
+int	intr_bind(u_int vector, u_char cpu);
+#endif
+int	intr_config_intr(int vector, enum intr_trigger trig,
+    enum intr_polarity pol);
+int	intr_describe(u_int vector, void *ih, const char *descr);
+void	intr_execute_handlers(struct intsrc *isrc, struct trapframe *frame);
+u_int	intr_next_cpu(int domain);
+struct intsrc *intr_lookup_source(int vector);
+int	intr_register_pic(struct pic *pic);
+int	intr_register_source(struct intsrc *isrc);
+int	intr_remove_handler(void *cookie);
+void	intr_resume(bool suspend_cancelled);
+void	intr_suspend(void);
+void	intr_reprogram(void);
+void	intrcnt_add(const char *name, u_long **countp);
+void	nexus_add_irq(u_long irq);
+int	msi_alloc(device_t dev, int count, int maxcount, int *irqs);
+void	msi_init(void);
+int	msi_map(int irq, uint64_t *addr, uint32_t *data);
+int	msi_release(int *irqs, int count);
+int	msix_alloc(device_t dev, int *irq);
+int	msix_release(int irq);
+#ifdef XENHVM
+void	xen_intr_alloc_irqs(void);
+#endif
+#endif	/* !LOCORE */
+#endif	/* _KERNEL */
+#endif	/* !__X86_INTR_MACHDEP_H__ */
diff --git a/freebsd/sys/x86/include/machine/legacyvar.h b/freebsd/sys/x86/include/machine/legacyvar.h
index 00000000..f6e5814a
--- /dev/null
+++ b/freebsd/sys/x86/include/machine/legacyvar.h
@@ -0,0 +1,73 @@
+ * Copyright (c) 2000 Peter Wemm <peter at FreeBSD.org>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _X86_LEGACYVAR_H_
+#define	_X86_LEGACYVAR_H_
+enum legacy_device_ivars {
+	LEGACY_IVAR_PCIDOMAIN,
+	LEGACY_IVAR_PCIBUS,
+	LEGACY_IVAR_PCISLOT,
+	LEGACY_IVAR_PCIFUNC
+#define LEGACY_ACCESSOR(var, ivar, type)				\
+    __BUS_ACCESSOR(legacy, var, LEGACY, ivar, type)
+LEGACY_ACCESSOR(pcidomain,		PCIDOMAIN,	uint32_t)
+LEGACY_ACCESSOR(pcibus,			PCIBUS,		uint32_t)
+LEGACY_ACCESSOR(pcislot,		PCISLOT,	int)
+LEGACY_ACCESSOR(pcifunc,		PCIFUNC,	int)
+#undef LEGACY_ACCESSOR
+int	legacy_pcib_maxslots(device_t dev);
+uint32_t legacy_pcib_read_config(device_t dev, u_int bus, u_int slot,
+    u_int func, u_int reg, int bytes);
+int	legacy_pcib_read_ivar(device_t dev, device_t child, int which,
+    uintptr_t *result);
+void	legacy_pcib_write_config(device_t dev, u_int bus, u_int slot,
+    u_int func, u_int reg, uint32_t data, int bytes);
+int	legacy_pcib_write_ivar(device_t dev, device_t child, int which,
+    uintptr_t value);
+struct resource *legacy_pcib_alloc_resource(device_t dev, device_t child,
+    int type, int *rid, rman_res_t start, rman_res_t end, rman_res_t count,
+    u_int flags);
+int	legacy_pcib_adjust_resource(device_t dev, device_t child, int type,
+    struct resource *r, rman_res_t start, rman_res_t end);
+int	legacy_pcib_release_resource(device_t dev, device_t child, int type,
+    int rid, struct resource *r);
+int	legacy_pcib_alloc_msi(device_t pcib, device_t dev, int count,
+    int maxcount, int *irqs);
+int	legacy_pcib_alloc_msix(device_t pcib, device_t dev, int *irq);
+int	legacy_pcib_map_msi(device_t pcib, device_t dev, int irq,
+    uint64_t *addr, uint32_t *data);
+#endif /* !_X86_LEGACYVAR_H_ */
diff --git a/freebsd/sys/x86/x86/legacy.c b/freebsd/sys/x86/x86/legacy.c
index 00000000..1ac57d26
--- /dev/null
+++ b/freebsd/sys/x86/x86/legacy.c
@@ -0,0 +1,404 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright 1998 Massachusetts Institute of Technology
+ * Permission to use, copy, modify, and distribute this software and
+ * its documentation for any purpose and without fee is hereby
+ * granted, provided that both the above copyright notice and this
+ * permission notice appear in all copies, that both the above
+ * copyright notice and this permission notice appear in all
+ * supporting documentation, and that the name of M.I.T. not be used
+ * in advertising or publicity pertaining to distribution of the
+ * software without specific, written prior permission.  M.I.T. makes
+ * no representations about the suitability of this software for any
+ * purpose.  It is provided "as is" without express or implied
+ * warranty.
+ * THIS SOFTWARE IS PROVIDED BY M.I.T. ``AS IS''.  M.I.T. DISCLAIMS
+ * ALL EXPRESS OR IMPLIED WARRANTIES WITH REGARD TO THIS SOFTWARE,
+ * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT
+ * SHALL M.I.T. BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * This code implements a system driver for legacy systems that do not
+ * support ACPI or when ACPI support is not present in the kernel.
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/cpu.h>
+#include <sys/kernel.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <machine/bus.h>
+#include <sys/pcpu.h>
+#include <sys/rman.h>
+#include <sys/smp.h>
+#include <dev/pci/pcireg.h>
+#include <machine/clock.h>
+#include <machine/pci_cfgreg.h>
+#include <machine/resource.h>
+#include <x86/legacyvar.h>
+static MALLOC_DEFINE(M_LEGACYDEV, "legacydrv", "legacy system device");
+struct legacy_device {
+	int	lg_pcibus;
+	int	lg_pcislot;
+	int	lg_pcifunc;
+#define DEVTOAT(dev)	((struct legacy_device *)device_get_ivars(dev))
+static	int legacy_probe(device_t);
+static	int legacy_attach(device_t);
+static	int legacy_print_child(device_t, device_t);
+static device_t legacy_add_child(device_t bus, u_int order, const char *name,
+				int unit);
+static	int legacy_read_ivar(device_t, device_t, int, uintptr_t *);
+static	int legacy_write_ivar(device_t, device_t, int, uintptr_t);
+static device_method_t legacy_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		legacy_probe),
+	DEVMETHOD(device_attach,	legacy_attach),
+	DEVMETHOD(device_detach,	bus_generic_detach),
+	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
+	DEVMETHOD(device_suspend,	bus_generic_suspend),
+	DEVMETHOD(device_resume,	bus_generic_resume),
+	/* Bus interface */
+	DEVMETHOD(bus_print_child,	legacy_print_child),
+	DEVMETHOD(bus_add_child,	legacy_add_child),
+	DEVMETHOD(bus_read_ivar,	legacy_read_ivar),
+	DEVMETHOD(bus_write_ivar,	legacy_write_ivar),
+	DEVMETHOD(bus_alloc_resource,	bus_generic_alloc_resource),
+	DEVMETHOD(bus_adjust_resource,	bus_generic_adjust_resource),
+	DEVMETHOD(bus_release_resource,	bus_generic_release_resource),
+	DEVMETHOD(bus_activate_resource, bus_generic_activate_resource),
+	DEVMETHOD(bus_deactivate_resource, bus_generic_deactivate_resource),
+	DEVMETHOD(bus_setup_intr,	bus_generic_setup_intr),
+	DEVMETHOD(bus_teardown_intr,	bus_generic_teardown_intr),
+	{ 0, 0 }
+static driver_t legacy_driver = {
+	"legacy",
+	legacy_methods,
+	1,			/* no softc */
+static devclass_t legacy_devclass;
+DRIVER_MODULE(legacy, nexus, legacy_driver, legacy_devclass, 0, 0);
+static int
+legacy_probe(device_t dev)
+	device_set_desc(dev, "legacy system");
+	device_quiet(dev);
+	return (0);
+#ifndef __rtems__
+ * Grope around in the PCI config space to see if this is a chipset
+ * that is capable of doing memory-mapped config cycles.  This also
+ * implies that it can do PCIe extended config cycles.
+static void
+legacy_pci_cfgregopen(device_t dev)
+	uint64_t pciebar;
+	u_int16_t did, vid;
+	if (cfgmech == CFGMECH_NONE || cfgmech == CFGMECH_PCIE)
+		return;
+	/* Check for supported chipsets */
+	vid = pci_cfgregread(0, 0, 0, PCIR_VENDOR, 2);
+	did = pci_cfgregread(0, 0, 0, PCIR_DEVICE, 2);
+	switch (vid) {
+	case 0x8086:
+		switch (did) {
+		case 0x3590:
+		case 0x3592:
+			/* Intel 7520 or 7320 */
+			pciebar = pci_cfgregread(0, 0, 0, 0xce, 2) << 16;
+			pcie_cfgregopen(pciebar, 0, 255);
+			break;
+		case 0x2580:
+		case 0x2584:
+		case 0x2590:
+			/* Intel 915, 925, or 915GM */
+			pciebar = pci_cfgregread(0, 0, 0, 0x48, 4);
+			break;
+	if (bootverbose && cfgmech == CFGMECH_PCIE)
+		device_printf(dev, "Enabled ECAM PCIe accesses\n");
+#endif /* __rtems__ */
+static int
+legacy_attach(device_t dev)
+	device_t child;
+#ifndef __rtems__
+	legacy_pci_cfgregopen(dev);
+	 * Let our child drivers identify any child devices that they
+	 * can find.  Once that is done attach any devices that we
+	 * found.
+	bus_generic_probe(dev);
+	bus_generic_attach(dev);
+	 * If we didn't see ISA on a pci bridge, create some
+	 * connection points now so they show up "on motherboard".
+	if (!devclass_get_device(devclass_find("isa"), 0)) {
+		child = BUS_ADD_CHILD(dev, 0, "isa", 0);
+		if (child == NULL)
+			panic("legacy_attach isa");
+		device_probe_and_attach(child);
+	return 0;
+static int
+legacy_print_child(device_t bus, device_t child)
+	struct legacy_device *atdev = DEVTOAT(child);
+	int retval = 0;
+	retval += bus_print_child_header(bus, child);
+	if (atdev->lg_pcibus != -1)
+		retval += printf(" pcibus %d", atdev->lg_pcibus);
+	retval += printf(" on motherboard\n");	/* XXX "motherboard", ick */
+	return (retval);
+static device_t
+legacy_add_child(device_t bus, u_int order, const char *name, int unit)
+	device_t child;
+	struct legacy_device *atdev;
+	atdev = malloc(sizeof(struct legacy_device), M_LEGACYDEV,
+	    M_NOWAIT | M_ZERO);
+	if (atdev == NULL)
+		return(NULL);
+	atdev->lg_pcibus = -1;
+	atdev->lg_pcislot = -1;
+	atdev->lg_pcifunc = -1;
+	child = device_add_child_ordered(bus, order, name, unit);
+		free(atdev, M_LEGACYDEV);
+	else
+		/* should we free this in legacy_child_detached? */
+		device_set_ivars(child, atdev);
+	return (child);
+static int
+legacy_read_ivar(device_t dev, device_t child, int which, uintptr_t *result)
+	switch (which) {
+	case LEGACY_IVAR_PCIDOMAIN:
+		*result = 0;
+		break;
+	case LEGACY_IVAR_PCIBUS:
+		*result = atdev->lg_pcibus;
+		break;
+	case LEGACY_IVAR_PCISLOT:
+		*result = atdev->lg_pcislot;
+		break;
+	case LEGACY_IVAR_PCIFUNC:
+		*result = atdev->lg_pcifunc;
+		break;
+	default:
+		return ENOENT;
+	return 0;
+static int
+legacy_write_ivar(device_t dev, device_t child, int which, uintptr_t value)
+	switch (which) {
+		return EINVAL;
+		atdev->lg_pcibus = value;
+		break;
+		atdev->lg_pcislot = value;
+		break;
+		atdev->lg_pcifunc = value;
+		break;
+	default:
+		return ENOENT;
+	return 0;
+ * Legacy CPU attachment when ACPI is not available.  Drivers like
+ * cpufreq(4) hang off this.
+static void	cpu_identify(driver_t *driver, device_t parent);
+static int	cpu_read_ivar(device_t dev, device_t child, int index,
+static device_t cpu_add_child(device_t bus, u_int order, const char *name,
+		    int unit);
+static struct resource_list *cpu_get_rlist(device_t dev, device_t child);
+struct cpu_device {
+	struct resource_list cd_rl;
+	struct pcpu *cd_pcpu;
+static device_method_t cpu_methods[] = {
+	DEVMETHOD(device_identify,	cpu_identify),
+	DEVMETHOD(device_probe,		bus_generic_probe),
+	DEVMETHOD(device_attach,	bus_generic_attach),
+	DEVMETHOD(bus_add_child,	cpu_add_child),
+	DEVMETHOD(bus_read_ivar,	cpu_read_ivar),
+	DEVMETHOD(bus_get_resource_list, cpu_get_rlist),
+	DEVMETHOD(bus_get_resource,	bus_generic_rl_get_resource),
+	DEVMETHOD(bus_set_resource,	bus_generic_rl_set_resource),
+	DEVMETHOD(bus_alloc_resource,	bus_generic_rl_alloc_resource),
+	DEVMETHOD(bus_release_resource,	bus_generic_rl_release_resource),
+	DEVMETHOD_END
+static driver_t cpu_driver = {
+	"cpu",
+	cpu_methods,
+	1,		/* no softc */
+static devclass_t cpu_devclass;
+DRIVER_MODULE(cpu, legacy, cpu_driver, cpu_devclass, 0, 0);
+static void
+cpu_identify(driver_t *driver, device_t parent)
+	device_t child;
+	int i;
+	 * Attach a cpuX device for each CPU.  We use an order of 150
+	 * so that these devices are attached after the Host-PCI
+	 * bridges (which are added at order 100).
+	CPU_FOREACH(i) {
+		child = BUS_ADD_CHILD(parent, 150, "cpu", i);
+			panic("legacy_attach cpu");
+static device_t
+cpu_add_child(device_t bus, u_int order, const char *name, int unit)
+	struct cpu_device *cd;
+	device_t child;
+	struct pcpu *pc;
+	if ((cd = malloc(sizeof(*cd), M_DEVBUF, M_NOWAIT | M_ZERO)) == NULL)
+		return (NULL);
+	resource_list_init(&cd->cd_rl);
+#ifndef __rtems__
+	pc = pcpu_find(device_get_unit(bus));
+	cd->cd_pcpu = pc;
+	if (child != NULL) {
+#ifndef __rtems__
+		pc->pc_device = child;
+		device_set_ivars(child, cd);
+	} else
+		free(cd, M_DEVBUF);
+	return (child);
+cpu_get_rlist(device_t dev, device_t child)
+	struct cpu_device *cpdev;
+	cpdev = device_get_ivars(child);
+	return (&cpdev->cd_rl);
+static int
+cpu_read_ivar(device_t dev, device_t child, int index, uintptr_t *result)
+	switch (index) {
+#ifndef __rtems__
+	case CPU_IVAR_PCPU:
+		*result = (uintptr_t)cpdev->cd_pcpu;
+		break;
+	case CPU_IVAR_NOMINAL_MHZ:
+		if (tsc_is_invariant) {
+			*result = (uintptr_t)(atomic_load_acq_64(&tsc_freq) /
+			    1000000);
+			break;
+		/* FALLTHROUGH */
+	default:
+		return (ENOENT);
+	return (0);
2.17.1
