[PATCH 1/6] c-user: Clarify BSP related configuration options
Sebastian Huber
Fri Mar 6 15:35:40 UTC 2020
Sort options alphabetically.
Update #3836.
c-user/configuring_a_system.rst | 127 ++++++++++++++++++++--------------------
1 file changed, 63 insertions(+), 64 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 4c7bae6..e45af77 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -3002,69 +3002,13 @@ DESCRIPTION:
NOTES:
None.
-BSP Specific Settings
-This section describes BSP specific configuration settings used by
-``<rtems/confdefs.h>``. The BSP specific configuration settings are defined in
-``<bsp.h>``.
-.. index:: CONFIGURE_DISABLE_BSP_SETTINGS
-.. _CONFIGURE_DISABLE_BSP_SETTINGS:
-CONFIGURE_DISABLE_BSP_SETTINGS
-CONSTANT:
- ``CONFIGURE_DISABLE_BSP_SETTINGS``
-DATA TYPE:
- Boolean feature macro.
-RANGE:
- Defined or undefined.
-DEFAULT VALUE:
- This is not defined by default.
-DESCRIPTION:
- All BSP specific configuration settings can be disabled by the application
- with the ``CONFIGURE_DISABLE_BSP_SETTINGS`` option.
-NOTES:
- None.
-.. index:: CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
-.. _CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK:
-CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
-CONSTANT:
- ``CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
- This option is BSP specific.
-DESCRIPTION:
- This configuration parameter is defined by a BSP to indicate that it does
- not allocate all available memory to the C Program Heap used by the Malloc
- Family of routines.
- If defined, when ``malloc()`` is unable to allocate memory, it will call
- the BSP supplied ``sbrk()`` to obtain more memory.
+BSP Related Configuration Options
-NOTES:
- This parameter should not be defined by the application. Only the BSP knows
- how it allocates memory to the C Program Heap.
+This section describes configuration options related to the BSP. Some
+configuration options may have a BSP-specific setting which is defined by
+``<bsp.h>``. The BSP-specific settings can be disabled by the
+:ref:`CONFIGURE_DISABLE_BSP_SETTINGS` configuration option.
.. index:: BSP_IDLE_TASK_BODY
@@ -3130,8 +3074,6 @@ NOTES:
- If defined, then the application specified ``CONFIGURE_IDLE_TASK_SIZE``.
-.. COMMENT: XXX - add cross references to other related values.
.. index:: BSP_INITIAL_EXTENSION
.. _BSP_INITIAL_EXTENSION:
@@ -3247,6 +3189,63 @@ NOTES:
configure common infrastructure such as bus controllers or probe for
devices.
+.. index:: CONFIGURE_DISABLE_BSP_SETTINGS
+.. _CONFIGURE_DISABLE_BSP_SETTINGS:
+CONFIGURE_DISABLE_BSP_SETTINGS
+CONSTANT:
+ ``CONFIGURE_DISABLE_BSP_SETTINGS``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ All BSP specific configuration settings can be disabled by the application
+ with the ``CONFIGURE_DISABLE_BSP_SETTINGS`` option.
+NOTES:
+ None.
+.. index:: CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+.. _CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK:
+CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+CONSTANT:
+ ``CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+ This option is BSP specific.
+DESCRIPTION:
+ This configuration parameter is defined by a BSP to indicate that it does
+ not allocate all available memory to the C Program Heap used by the Malloc
+ Family of routines.
+ If defined, when ``malloc()`` is unable to allocate memory, it will call
+ the BSP supplied ``sbrk()`` to obtain more memory.
+NOTES:
+ This parameter should not be defined by the application. Only the BSP knows
+ how it allocates memory to the C Program Heap.
Idle Task Configuration
2.16.4
