Project for GSoC 2020
Utkarsh Rai
utkarsh.rai60 at gmail.com
Sat Mar 7 12:29:37 UTC 2020
Sorry for the late reply, I was busy with my college tests.
I looked into the MMU implementation of a few other RTOSs and zephyr RTOS
has an interesting memory domain implementation for thread stack
protection. Basically, the threads are grouped into memory domains as
'struct memory_domain'. Each memory domain has 'struct memory_partition'
which contains the starting address, size and access policy for each
partition the 'memory_domain' also contains APIs to add/remove the memory
partition. Can this be implemented? I am not sure about the POSIX
compliance of this implementation.
As was pointed out, a lot of the implementation in this project will be
architecture-specific. Would it be feasible to take up the implementation
for a particular architecture(specifically ARM or x86 as I have knowledge
about their architecture ) as a GSoC project?
On Mon, Mar 2, 2020 at 10:55 PM Sebastian Huber <
> ----- Am 2. Mrz 2020 um 17:44 schrieb Gedare Bloom gedare at rtems.org:
> > On Mon, Mar 2, 2020 at 9:37 AM Joel Sherrill <joel at rtems.org> wrote:
> >> On Mon, Mar 2, 2020 at 10:12 AM Gedare Bloom <gedare at rtems.org> wrote:
> >>> On Mon, Mar 2, 2020 at 9:05 AM Joel Sherrill <joel at rtems.org> wrote:
> >>> > On Mon, Mar 2, 2020 at 9:33 AM Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> >> On Sat, Feb 29, 2020 at 2:58 PM Utkarsh Rai <
> utkarsh.rai60 at gmail.com> wrote:
> >>> >> > I have gone through the details of the project adding memory
> protection using
> >>> >> > MMU and have a few questions and observations regarding the same-
> >>> >> > 1. Is this a project for which someone from the community would
> be willing to
> >>> >> > mentor for GSoC?
> >>> >> Yes, Peter Dufault has expressed interest. There are also several
> >>> >> generally interested parties that may like to stay in the loop.
> >>> >> > 2. As far I could understand by looking into the rtems tree ARM
> uses static
> >>> >> > initialization wherein it first invalidates the cache and TLB
> blocks and then
> >>> >> > performs initialization by setting up a 1 to 1 mapping of the
> parts of address
> >>> >> > space. According to me, static initialization of the mmu is a
> generic enough
> >>> >> > method that can be utilized in most of the architectures.
> >>> >> Yes, it should be. That is how most architectures will do it, if
> they
> >>> >> need to. Some might disable the MMU/MPU and not bother, then there
> is
> >>> >> some work to do to figure out how to enable the static/init-time
> >>> >> memory map.
> >>> >> > 3. For the thread stack protection, I believe either of the stack
> guard
> >>> >> > protection approach or by verification of stack canaries whereby
> the OS on each
> >>> >> > context switch would check whether the numbers associated with
> the canaries are
> >>> >> > still intact or not are worth considering. Although I still only
> have a
> >>> >> > high-level idea of both of these approaches and will be looking
> into their
> >>> >> > implementation details, I would request your kind feedback on it.
> >>> >> Thread stack protection is different from stack overflow protection.
> >>> >> We do have some stack overflow checking that can be enabled. The
> >>> >> thread stack protection means you would have separate MMU/MPU region
> >>> >> for each thread's stack, so on context switch you would enable the
> >>> >> heir thread's stack region and disable the executing thread's
> region.
> >>> >> This way, different threads can't access each other's stacks
> directly.
> >>> > FWIW the thread stack allocator/deallocator plugin support was
> originally
> >>> > added for a user who allocated fixed size stacks to all threads and
> used
> >>> > the MMU to invalidate the addresses immediately before and after each
> >>> > stack area.
> >>> > Another thing to consider is the semantics of protecting a thread.
> Since
> >>> > RTEMS is POSIX single process, multi-threaded, there is an assumption
> >>> > that all data, bss, heap, and stack memory is accessible by all
> threads.
> >>> > This means you can protect for out of area writes/reads but can't
> generally
> >>> > protect from one thread accessing another thread's memory. This may
> >>> Right: thread stack protection must be application-configurable.
> >>> > sound like it doesn't happen often but anytime data is returned from
> a
> >>> > blocking call, the contents are copied from one thread's address
> space
> >>> > to another. Message queue receives are one example. I suspect all
> >>> > blocking reads do this (sockets, files, etc)
> >>> It should not happen inside rtems unless the user sends thread-stack
> >>> pointers via API calls, so the documentation must make it clear: user
> >>> beware!
> >> Yep. Pushing this to the limit could break code in weird, hard
> >> to understand ways. The fault handler may have to give a hint. :)
> >>> It may eventually be worth considering (performance-degrading)
> >>> extensions to the API that copy buffers between thread contexts.
> >> This might be challenging to support everywhere. Say you have
> mmu_memcpy()
> >> or whatever. It has to be used inside code RTEMS owns as well as code
> that
> >> RTEMS is leveraging from third party sources. Hopefully you would at
> least
> >> know the source thread (running) and destination thread easily.
> > This brings up the interesting design point, which may have been
> > mentioned elsewhere, that is to group/pool threads together in the
> > same protection domain. This way the application designer can control
> > the sharing between threads that should share, while restricting
> > others.
> Some years ago I added private stacks on Nios II. The patch was relatively
> small. I think the event and message queue send needed some adjustments.
> Also some higher level code was broken, e.g. structures created on the
> stack with some sort of request/response handling (bdbuf). Doing this with
> a user extension was not possible. At some point in time you have to run
> without a stack to do the switching.
> On ARMv7-MR it would be easy to add a thread stack protection zone after
> the thread stack via the memory protection unit.
> On a recent project I added MMU protection to the heap (ARM 4KiB pages).
> You quickly get use after free and out of bounds errors with this. The
> problem is that each memory allocation consumes at least 4KiB of RAM.
> I am not sure if this area is good for GSoC. You need a lot of
> hardware-specific knowledge and generalizations across architectures are
> difficult.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200307/020ca3d5/attachment.html>
