Project for GSoC 2020
dufault at hda.com dufault at hda.com
Sun Mar 8 19:28:18 UTC 2020
> On Mar 8, 2020, at 10:22 , Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Mar 8, 2020 at 8:10 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
>> I suspect that the same set of APIs won't work across all architectures and they would need to be implemented individually for each of them and a separate set of documentation would have to be provided for all the architectures for which the solution is implemented.
>> If this is not implementable for the length of GSoC can I take up this ticket as I believe I have a fair idea of how I can implement it and it seems doable for the length of GSoC.
> There is a fundamental difference between an API, which is an
> interface, and the architectural implementation. For sure the
> implementation would need to be different based on the hardware
> support available, and in some cases certain functionality may not be
> present to support an API feature. Those cases are what need to be
> documented and understood by users so that they can make good choices.
> Despite the variation in implementation, good software design mandates
> that an API should be consistent across applications, so the interface
> should strive to account for the differences in the underlying
> implementation. An interface is an abstraction of some functionality,
> and the problem for interface designers is to identify a suitable
> abstraction that is useful for clients and implementable by servers.
> One should be able to design an interface for thread stack protection.
> That should be uniform across all applications, and every architecture
> would try to implement the functionality needed to satisfy the design.
> A problem is that interface design is quite challenging. We've had
> many discussions on this mailing list about the proper interfaces for
> memory protection, but without any real movement. As a result what we
> have had evolve is a "bottom-up" approach that is implementing MMU/MPU
> hardware management in the BSP layers without a lot of consistency or
> high-level requirements.
> Unfortunately, specifying an interface may be beyond the capabilities
> of most GSoC students. And, it is something we would need done in the
> proposal, so that the proposed interface can be reviewed and evaluated
> closely before coding is even close to beginning. I don't think anyone
> else has the time or motivation right now to try to design such
> interfaces, but if you want to work on some memory protection project
> then this is where you need to begin. Basically every other memory
> protection project started in a similar way, and we have learned some
> key lessons along the way.
> If you want to work on a different project, or at least to discuss it,
> you should create a separate email thread with an appropriate subject
> line that would catch the attention of the potential mentors. You can
> also CC those potential mentors in this case as well.
> Gedare
>> On Sun, Mar 8, 2020 at 10:06 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Sat, Mar 7, 2020 at 12:00 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
>>>> Sorry for the late reply, I was busy with my college tests.
>>>> I looked into the MMU implementation of a few other RTOSs and zephyr RTOS has an interesting memory domain implementation for thread stack protection. Basically, the threads are grouped into memory domains as 'struct memory_domain'. Each memory domain has 'struct memory_partition' which contains the starting address, size and access policy for each partition the 'memory_domain' also contains APIs to add/remove the memory partition. Can this be implemented? I am not sure about the POSIX compliance of this implementation.
>>>> As was pointed out, a lot of the implementation in this project will be architecture-specific. Would it be feasible to take up the implementation for a particular architecture(specifically ARM or x86 as I have knowledge about their architecture ) as a GSoC project?
>>> Probably. But any design has to accommodate the many different kinds
>>> of MMU/MPU support that are avialable, and should also work when there
>>> is no support  (maybe with a warning or an error if an application
>>> tries to configure thread stack protection for an unsupported
>>> architecture/BSP).
>>>> On Mon, Mar 2, 2020 at 10:55 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>>>> ----- Am 2. Mrz 2020 um 17:44 schrieb Gedare Bloom gedare at rtems.org:
>>>>>> On Mon, Mar 2, 2020 at 9:37 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> On Mon, Mar 2, 2020 at 10:12 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>> On Mon, Mar 2, 2020 at 9:05 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>> On Mon, Mar 2, 2020 at 9:33 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>>>> On Sat, Feb 29, 2020 at 2:58 PM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
>>>>>>>>>>> I have gone through the details of the project adding memory protection using
>>>>>>>>>>> MMU and have a few questions and observations regarding the same-
>>>>>>>>>>> 1. Is this a project for which someone from the community would be willing to
>>>>>>>>>>> mentor for GSoC?
>>>>>>>>>> Yes, Peter Dufault has expressed interest. There are also several
>>>>>>>>>> generally interested parties that may like to stay in the loop.
>>>>>>>>>>> 2. As far I could understand by looking into the rtems tree ARM uses static
>>>>>>>>>>> initialization wherein it first invalidates the cache and TLB blocks and then
>>>>>>>>>>> performs initialization by setting up a 1 to 1 mapping of the parts of address
>>>>>>>>>>> space. According to me, static initialization of the mmu is a generic enough
>>>>>>>>>>> method that can be utilized in most of the architectures.
>>>>>>>>>> Yes, it should be. That is how most architectures will do it, if they
>>>>>>>>>> need to. Some might disable the MMU/MPU and not bother, then there is
>>>>>>>>>> some work to do to figure out how to enable the static/init-time
>>>>>>>>>> memory map.
>>>>>>>>>>> 3. For the thread stack protection, I believe either of the stack guard
>>>>>>>>>>> protection approach or by verification of stack canaries whereby the OS on each
>>>>>>>>>>> context switch would check whether the numbers associated with the canaries are
>>>>>>>>>>> still intact or not are worth considering. Although I still only have a
>>>>>>>>>>> high-level idea of both of these approaches and will be looking into their
>>>>>>>>>>> implementation details, I would request your kind feedback on it.
>>>>>>>>>> Thread stack protection is different from stack overflow protection.
>>>>>>>>>> We do have some stack overflow checking that can be enabled. The
>>>>>>>>>> thread stack protection means you would have separate MMU/MPU region
>>>>>>>>>> for each thread's stack, so on  context switch you would enable the
>>>>>>>>>> heir thread's stack region and disable the executing thread's region.
>>>>>>>>>> This way, different threads can't access each other's stacks directly.
>>>>>>>>> FWIW the thread stack allocator/deallocator plugin support was originally
>>>>>>>>> added for a user who allocated fixed size stacks to all threads and used
>>>>>>>>> the MMU to invalidate the addresses immediately before and after each
>>>>>>>>> stack area.
>>>>>>>>> Another thing to consider is the semantics of protecting a thread. Since
>>>>>>>>> RTEMS is POSIX single process, multi-threaded, there is an assumption
>>>>>>>>> that all data, bss, heap, and stack memory is accessible by all threads.
>>>>>>>>> This means you can protect for out of area writes/reads but can't generally
>>>>>>>>> protect from one thread accessing another thread's memory. This may
>>>>>>>> Right: thread stack protection must be application-configurable.
>>>>>>>>> sound like it doesn't happen often but anytime data is returned from a
>>>>>>>>> blocking call, the contents are copied from one thread's address space
>>>>>>>>> to another. Message queue receives are one example. I suspect all
>>>>>>>>> blocking reads do this (sockets, files, etc)
>>>>>>>> It should not happen inside rtems unless the user sends thread-stack
>>>>>>>> pointers via API calls, so the documentation must make it clear: user
>>>>>>>> beware!
>>>>>>> Yep.  Pushing this to the limit could break code in weird, hard
>>>>>>> to understand ways. The fault handler may have to give a hint. :)
>>>>>>>> It may eventually be worth considering (performance-degrading)
>>>>>>>> extensions to the API that copy buffers between thread contexts.
>>>>>>> This might be challenging to support everywhere. Say you have mmu_memcpy()
>>>>>>> or whatever. It has to be used inside code RTEMS owns as well as code that
>>>>>>> RTEMS is leveraging from third party sources. Hopefully you would at least
>>>>>>> know the source thread (running) and destination thread easily.
>>>>>> This brings up the interesting design point, which may have been
>>>>>> mentioned elsewhere, that is to group/pool threads together in the
>>>>>> same protection domain. This way the application designer can control
>>>>>> the sharing between threads that should share, while restricting
>>>>>> others.
>>>>> Some years ago I added private stacks on Nios II. The patch was relatively small. I think the event and message queue send needed some adjustments. Also some higher level code was broken, e.g. structures created on the stack with some sort of request/response handling (bdbuf). Doing this with a user extension was not possible. At some point in time you have to run without a stack to do the switching.
>>>>> On ARMv7-MR it would be easy to add a thread stack protection zone after the thread stack via the memory protection unit.
>>>>> On a recent project I added MMU protection to the heap (ARM 4KiB pages). You quickly get use after free and out of bounds errors with this. The problem is that each memory allocation consumes at least 4KiB of RAM.
>>>>> I am not sure if this area is good for GSoC. You need a lot of hardware-specific knowledge and generalizations across architectures are difficult.
I have not gone through this thread as thoroughly as I should.  Yet, I will still jump in.
The stack protectin mechanism should be done in a POSIX compliant way without defining any extensions.
When threads have protected stack areas that must be shared those regions should be shared using an "mmap" interface. That is POSIX compliant, and will require extra effort to establish the sharing of stack-based memory regions.
My two minute analysis of "thread pools" is that protected stacks in RTEMS should be implemented without that.  Applications that want protected stacks should have the discipline of explicitly requesting access to regions of memory that are in another threads stack.  The value of protected stacks will not be cost free.
I'd like to see:
- The ability of each thread to specify a protected stack.
- A protected thread's stack memory region shall be unavailable to other threads unless it is in a shared memory region.
-- I won't define the granularity of what the previous point means.  In most implementations, it probably means that if "task2" has access to memory in the "task1" stack via mmap then it can probably stomp all over any part of task1s stack, it probably implies that the task1 stack memory is left accessible when task2 is running instead of being unmapped.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
