[PATCH 20/20] c-user: Move "Obsolete Configuration Options"
Sebastian Huber
Mon Mar 9 09:03:03 UTC 2020
Update #3836.
c-user/config/index.rst | 222 +------------------------------------
c-user/config/obsolete-config.rst | 224 ++++++++++++++++++++++++++++++++++++++
2 files changed, 225 insertions(+), 221 deletions(-)
create mode 100644 c-user/config/obsolete-config.rst
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index c9e1c5c..b6eeecd 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -29,224 +29,4 @@ Configuring a System
libpci-config
event-record-config
ada-config
-Obsolete Configuration Options
-.. index:: CONFIGURE_BDBUF_BUFFER_COUNT
-CONFIGURE_BDBUF_BUFFER_COUNT
-This configuration option was introduced in RTEMS 4.7.0 and is obsolete since
-RTEMS 4.10.0.
-.. index:: CONFIGURE_BDBUF_BUFFER_SIZE
-CONFIGURE_BDBUF_BUFFER_SIZE
-RTEMS 4.10.0.
-.. index:: CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
-CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
-This configuration option was introduced in RTEMS 4.9.0 and is obsolete since
-RTEMS 5.1.
-.. index:: CONFIGURE_ENABLE_GO
-CONFIGURE_ENABLE_GO
-This configuration option is obsolete since RTEMS 5.1.
-.. index:: CONFIGURE_GNAT_RTEMS
-CONFIGURE_GNAT_RTEMS
-This configuration option was present in all RTEMS versions since at 1997 and is
-obsolete since RTEMS 5.1. See also :ref:`ConfigAda`.
-.. index:: CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
-CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
-.. index:: CONFIGURE_HAS_OWN_BDBUF_TABLE
-CONFIGURE_HAS_OWN_BDBUF_TABLE
-RTEMS 4.10.0.
-.. index:: CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
-CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
-This configuration option was present in all RTEMS versions since at least 1995
-and is obsolete since RTEMS 5.1.
-.. index:: CONFIGURE_HAS_OWN_INIT_TASK_TABLE
-.. _CONFIGURE_HAS_OWN_INIT_TASK_TABLE:
-CONFIGURE_HAS_OWN_INIT_TASK_TABLE
-and is obsolete since RTEMS 5.1. If you used this configuration option or you
-think that there should be a way to configure more than one Classic API
-initialization task, then please ask on the :r:list:`users`.
-.. index:: CONFIGURE_HAS_OWN_MOUNT_TABLE
-CONFIGURE_HAS_OWN_MOUNT_TABLE
-.. index:: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
-CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
-.. index:: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-This configuration option was present in all RTEMS versions since at 1998 and is
-obsolete since RTEMS 5.1. See also :ref:`CONFIGURE_MAXIMUM_FILE_DESCRIPTORS`.
-.. index:: CONFIGURE_MAXIMUM_ADA_TASKS
-CONFIGURE_MAXIMUM_ADA_TASKS
-.. index:: CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
-CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
-.. index:: CONFIGURE_MAXIMUM_GO_CHANNELS
-CONFIGURE_MAXIMUM_GO_CHANNELS
-.. index:: CONFIGURE_MAXIMUM_GOROUTINES
-CONFIGURE_MAXIMUM_GOROUTINES
-.. index:: CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
-CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
-.. index:: CONFIGURE_NUMBER_OF_TERMIOS_PORTS
-CONFIGURE_NUMBER_OF_TERMIOS_PORTS
-.. index:: CONFIGURE_MAXIMUM_POSIX_BARRIERS
-CONFIGURE_MAXIMUM_POSIX_BARRIERS
-.. index:: CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
-CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
-This configuration option was introduced in RTEMS 4.10.0 and is obsolete since
-RTEMS 5.1.
-.. index:: CONFIGURE_MAXIMUM_POSIX_MUTEXES
-CONFIGURE_MAXIMUM_POSIX_MUTEXES
-.. index:: CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-.. index:: CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-.. index:: CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-.. _CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE:
-CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-think that there should be a way to configure more than one POSIX initialization
-thread, then please ask on the :r:list:`users`.
-.. index:: CONFIGURE_SMP_APPLICATION
-CONFIGURE_SMP_APPLICATION
-This configuration option was introduced in RTEMS 4.11.0 and is obsolete since
-RTEMS 5.1.
-.. index:: CONFIGURE_SMP_MAXIMUM_PROCESSORS
-CONFIGURE_SMP_MAXIMUM_PROCESSORS
-RTEMS 5.1. See also :ref:`CONFIGURE_MAXIMUM_PROCESSORS`.
-.. index:: CONFIGURE_TERMIOS_DISABLED
-CONFIGURE_TERMIOS_DISABLED
+ obsolete-config
diff --git a/c-user/config/obsolete-config.rst b/c-user/config/obsolete-config.rst
new file mode 100644
index 0000000..329ccfa
--- /dev/null
+++ b/c-user/config/obsolete-config.rst
@@ -0,0 +1,224 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Obsolete Configuration Options
+.. index:: CONFIGURE_BDBUF_BUFFER_COUNT
+CONFIGURE_BDBUF_BUFFER_COUNT
+This configuration option was introduced in RTEMS 4.7.0 and is obsolete since
+RTEMS 4.10.0.
+.. index:: CONFIGURE_BDBUF_BUFFER_SIZE
+CONFIGURE_BDBUF_BUFFER_SIZE
+RTEMS 4.10.0.
+.. index:: CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
+CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
+This configuration option was introduced in RTEMS 4.9.0 and is obsolete since
+RTEMS 5.1.
+.. index:: CONFIGURE_ENABLE_GO
+CONFIGURE_ENABLE_GO
+This configuration option is obsolete since RTEMS 5.1.
+.. index:: CONFIGURE_GNAT_RTEMS
+CONFIGURE_GNAT_RTEMS
+This configuration option was present in all RTEMS versions since at 1997 and is
+obsolete since RTEMS 5.1. See also :ref:`ConfigAda`.
+.. index:: CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
+CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
+.. index:: CONFIGURE_HAS_OWN_BDBUF_TABLE
+CONFIGURE_HAS_OWN_BDBUF_TABLE
+RTEMS 4.10.0.
+.. index:: CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+This configuration option was present in all RTEMS versions since at least 1995
+and is obsolete since RTEMS 5.1.
+.. index:: CONFIGURE_HAS_OWN_INIT_TASK_TABLE
+.. _CONFIGURE_HAS_OWN_INIT_TASK_TABLE:
+CONFIGURE_HAS_OWN_INIT_TASK_TABLE
+and is obsolete since RTEMS 5.1. If you used this configuration option or you
+think that there should be a way to configure more than one Classic API
+initialization task, then please ask on the :r:list:`users`.
+.. index:: CONFIGURE_HAS_OWN_MOUNT_TABLE
+CONFIGURE_HAS_OWN_MOUNT_TABLE
+.. index:: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
+CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
+.. index:: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+This configuration option was present in all RTEMS versions since at 1998 and is
+obsolete since RTEMS 5.1. See also :ref:`CONFIGURE_MAXIMUM_FILE_DESCRIPTORS`.
+.. index:: CONFIGURE_MAXIMUM_ADA_TASKS
+CONFIGURE_MAXIMUM_ADA_TASKS
+.. index:: CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+.. index:: CONFIGURE_MAXIMUM_GO_CHANNELS
+CONFIGURE_MAXIMUM_GO_CHANNELS
+.. index:: CONFIGURE_MAXIMUM_GOROUTINES
+CONFIGURE_MAXIMUM_GOROUTINES
+.. index:: CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+.. index:: CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+.. index:: CONFIGURE_MAXIMUM_POSIX_BARRIERS
+CONFIGURE_MAXIMUM_POSIX_BARRIERS
+.. index:: CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
+CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
+.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
+CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
+This configuration option was introduced in RTEMS 4.10.0 and is obsolete since
+RTEMS 5.1.
+.. index:: CONFIGURE_MAXIMUM_POSIX_MUTEXES
+CONFIGURE_MAXIMUM_POSIX_MUTEXES
+.. index:: CONFIGURE_MAXIMUM_POSIX_RWLOCKS
+CONFIGURE_MAXIMUM_POSIX_RWLOCKS
+.. index:: CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
+CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
+.. index:: CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+.. _CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE:
+CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+think that there should be a way to configure more than one POSIX initialization
+thread, then please ask on the :r:list:`users`.
+.. index:: CONFIGURE_SMP_APPLICATION
+CONFIGURE_SMP_APPLICATION
+This configuration option was introduced in RTEMS 4.11.0 and is obsolete since
+RTEMS 5.1.
+.. index:: CONFIGURE_SMP_MAXIMUM_PROCESSORS
+CONFIGURE_SMP_MAXIMUM_PROCESSORS
+RTEMS 5.1. See also :ref:`CONFIGURE_MAXIMUM_PROCESSORS`.
+.. index:: CONFIGURE_TERMIOS_DISABLED
+CONFIGURE_TERMIOS_DISABLED
2.16.4
