[PATCH 15/20] c-user: Move "Device Driver Configuration"
Mon Mar 9 09:02:58 UTC 2020
Update #3836.
 c-user/config/device-config.rst | 507 ++++++++++++++++++++++++++++++++++++++++
 c-user/config/index.rst         | 505 +--------------------------------------
 2 files changed, 508 insertions(+), 504 deletions(-)
 create mode 100644 c-user/config/device-config.rst
diff --git a/c-user/config/device-config.rst b/c-user/config/device-config.rst
new file mode 100644
index 0000000..38638ce
--- /dev/null
+++ b/c-user/config/device-config.rst
@@ -0,0 +1,507 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Device Driver Configuration
+This section defines the configuration parameters related to the automatic
+generation of a Device Driver Table.  As ``<rtems/confdefs.h>`` only is aware
+of a small set of standard device drivers, the generated Device Driver Table is
+suitable for simple applications with no custom device drivers.
+Note that network device drivers are not configured in the Device Driver Table.
+.. index:: CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+.. _CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER:
+CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER``
+DATA TYPE:
+    Boolean feature macro.
+RANGE:
+    Defined or undefined.
+DEFAULT VALUE:
+    This is not defined by default.
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is defined when the
+    application does *NOT* want the Clock Device Driver and is *NOT* using the
+    Timer Driver.  The inclusion or exclusion of the Clock Driver must be
+    explicit in user applications.
+NOTES:
+    This configuration parameter is intended to prevent the common user error
+    of using the Hello World example as the baseline for an application and
+    leaving out a clock tick source.
+.. index:: CONFIGURE_APPLICATION_EXTRA_DRIVERS
+.. _CONFIGURE_APPLICATION_EXTRA_DRIVERS:
+CONFIGURE_APPLICATION_EXTRA_DRIVERS
+CONSTANT:
+    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS``
+DATA TYPE:
+    device driver entry structures
+RANGE:
+    Undefined or set of device driver entry structures
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS`` is defined if the application has
+    device drivers it needs to include in the Device Driver Table.  This should
+    be defined to the set of device driver entries that will be placed in the
+    table at the *END* of the Device Driver Table.
+NOTES:
+    None.
+.. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER`` is defined if the application
+    wishes to include the Clock Device Driver.
+NOTES:
+    This device driver is responsible for providing a regular interrupt which
+    invokes a clock tick directive.
+    If neither the Clock Driver not Benchmark Timer is enabled and the
+    configuration parameter
+    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is not defined, then a
+    compile time error will occur.
+.. index:: CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` is defined if the
+    application wishes to include the Console Device Driver.
+NOTES:
+    This device driver is responsible for providing the :file:`/dev/console`
+    device file.  This device is used to initialize the standard input, output,
+    and error file descriptors.
+    BSPs should be constructed in a manner that allows ``printk()`` to work
+    properly without the need for the console driver to be configured.
+    The
+    * ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``,
+    * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``, and
+    * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
+    configuration options are mutually exclusive.
+.. index:: CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER`` is defined if the
+    application wishes to include the BSP's Frame Buffer Device Driver.
+NOTES:
+    Most BSPs do not include support for a Frame Buffer Device Driver. This is
+    because many boards do not include the required hardware.
+    If this is defined and the BSP does not have this device driver, then the
+    user will get a link time error for an undefined symbol.
+.. index:: CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+.. index:: /dev/null
+.. _CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    This configuration variable is specified to enable ``/dev/null`` device driver.
+NOTES:
+    This device driver is supported by all BSPs.
+.. index:: CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER`` is defined if the application
+    wishes to include the Real-Time Clock Driver.
+NOTES:
+    Most BSPs do not include support for a real-time clock. This is because
+    many boards do not include the required hardware.
+.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` is defined if the
+    application wishes to include the Simple Console Device Driver.
+NOTES:
+    This device driver reads via ``getchark()``.
+    This device driver writes via ``rtems_putc()``.
+    The Termios framework is not used.  There is no support to change device
+    settings, e.g. baud, stop bits, parity, etc.
+    The
+.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER`` is defined if
+    the application wishes to include the Simple Task Console Device Driver.
+NOTES:
+    This device driver writes into a write buffer.  The count of characters
+    written into the write buffer is returned.  It might be less than the
+    requested count, in case the write buffer is full.  The write is
+    non-blocking and may be called from interrupt context.  A dedicated task
+    reads from the write buffer and outputs the characters via
+    ``rtems_putc()``.  This task runs with the least important priority.  The
+    write buffer size is 2047 characters and it is not configurable.
+    Use ``fsync(STDOUT_FILENO)`` or ``fdatasync(STDOUT_FILENO)`` to drain the
+    write buffer.
+    The
+.. index:: CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER`` is defined if the application
+    wishes to include the Stub Device Driver.
+NOTES:
+    This device driver simply provides entry points that return successful and
+    is primarily a test fixture. It is supported by all BSPs.
+.. index:: CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER`` is defined if the application
+    wishes to include the Timer Driver.  This device driver is used to
+    benchmark execution times by the RTEMS Timing Test Suites.
+NOTES:
+.. index:: CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER`` is defined if the
+    application wishes to include the Watchdog Driver.
+NOTES:
+    Most BSPs do not include support for a watchdog device driver. This is
+.. index:: CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+.. index:: /dev/zero
+.. _CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    This configuration variable is specified to enable ``/dev/zero`` device driver.
+NOTES:
+.. index:: CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
+.. _CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS:
+CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
+CONSTANT:
+    ``CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS`` is defined if the
+    application has device drivers it needs to include in the Device Driver
+    Table.  This should be defined to the set of device driver entries that
+    will be placed in the table at the *FRONT* of the Device Driver Table and
+    initialized before any other drivers *EXCEPT* any BSP prerequisite drivers.
+NOTES:
+    In some cases, it is used by System On Chip BSPs to support peripheral
+    buses beyond those normally found on the System On Chip. For example, this
+    is used by one RTEMS system which has implemented a SPARC/ERC32 based board
+    with VMEBus. The VMEBus Controller initialization is performed by a device
+    driver configured via this configuration parameter.
+.. index:: CONFIGURE_MAXIMUM_DRIVERS
+.. _CONFIGURE_MAXIMUM_DRIVERS:
+CONFIGURE_MAXIMUM_DRIVERS
+CONSTANT:
+    ``CONFIGURE_MAXIMUM_DRIVERS``
+DATA TYPE:
+    Unsigned integer (``uint32_t``).
+RANGE:
+    Zero or positive.
+DEFAULT VALUE:
+    This is computed by default, and is set to the number of device drivers
+    configured using the ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER``
+    configuration parameters.
+DESCRIPTION:
+    ``CONFIGURE_MAXIMUM_DRIVERS`` is defined as the number of device drivers
+    per node.
+NOTES:
+    If the application will dynamically install device drivers, then this
+    configuration parameter must be larger than the number of statically
+    configured device drivers. Drivers configured using the
+    ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER`` configuration parameters are
+    statically installed.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index c8275e9..b11a3a5 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -24,510 +24,7 @@ Configuring a System
     idle-task-config
     general-sched-config
     clustered-sched-config
-Device Driver Configuration
-This section defines the configuration parameters related to the automatic
-generation of a Device Driver Table.  As ``<rtems/confdefs.h>`` only is aware
-of a small set of standard device drivers, the generated Device Driver Table is
-suitable for simple applications with no custom device drivers.
-Note that network device drivers are not configured in the Device Driver Table.
-.. index:: CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-.. _CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER:
-CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is defined when the
-    application does *NOT* want the Clock Device Driver and is *NOT* using the
-    Timer Driver.  The inclusion or exclusion of the Clock Driver must be
-    explicit in user applications.
-NOTES:
-    This configuration parameter is intended to prevent the common user error
-    of using the Hello World example as the baseline for an application and
-    leaving out a clock tick source.
-.. index:: CONFIGURE_APPLICATION_EXTRA_DRIVERS
-.. _CONFIGURE_APPLICATION_EXTRA_DRIVERS:
-CONFIGURE_APPLICATION_EXTRA_DRIVERS
-CONSTANT:
-    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS``
-DATA TYPE:
-    device driver entry structures
-RANGE:
-    Undefined or set of device driver entry structures
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS`` is defined if the application has
-    device drivers it needs to include in the Device Driver Table.  This should
-    be defined to the set of device driver entries that will be placed in the
-    table at the *END* of the Device Driver Table.
-NOTES:
-    None.
-.. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER`` is defined if the application
-    wishes to include the Clock Device Driver.
-NOTES:
-    This device driver is responsible for providing a regular interrupt which
-    invokes a clock tick directive.
-    If neither the Clock Driver not Benchmark Timer is enabled and the
-    configuration parameter
-    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is not defined, then a
-    compile time error will occur.
-.. index:: CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` is defined if the
-    application wishes to include the Console Device Driver.
-NOTES:
-    This device driver is responsible for providing the :file:`/dev/console`
-    device file.  This device is used to initialize the standard input, output,
-    and error file descriptors.
-    BSPs should be constructed in a manner that allows ``printk()`` to work
-    properly without the need for the console driver to be configured.
-    The
-    * ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``,
-    * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``, and
-    * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
-    configuration options are mutually exclusive.
-.. index:: CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER`` is defined if the
-    application wishes to include the BSP's Frame Buffer Device Driver.
-NOTES:
-    Most BSPs do not include support for a Frame Buffer Device Driver. This is
-    because many boards do not include the required hardware.
-    If this is defined and the BSP does not have this device driver, then the
-    user will get a link time error for an undefined symbol.
-.. index:: CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
-.. index:: /dev/null
-.. _CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    This configuration variable is specified to enable ``/dev/null`` device driver.
-NOTES:
-    This device driver is supported by all BSPs.
-.. index:: CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER`` is defined if the application
-    wishes to include the Real-Time Clock Driver.
-NOTES:
-    Most BSPs do not include support for a real-time clock. This is because
-    many boards do not include the required hardware.
-.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` is defined if the
-    application wishes to include the Simple Console Device Driver.
-NOTES:
-    This device driver reads via ``getchark()``.
-    This device driver writes via ``rtems_putc()``.
-    The Termios framework is not used.  There is no support to change device
-    settings, e.g. baud, stop bits, parity, etc.
-    The
-.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER`` is defined if
-    the application wishes to include the Simple Task Console Device Driver.
-NOTES:
-    This device driver writes into a write buffer.  The count of characters
-    written into the write buffer is returned.  It might be less than the
-    requested count, in case the write buffer is full.  The write is
-    non-blocking and may be called from interrupt context.  A dedicated task
-    reads from the write buffer and outputs the characters via
-    ``rtems_putc()``.  This task runs with the least important priority.  The
-    write buffer size is 2047 characters and it is not configurable.
-    Use ``fsync(STDOUT_FILENO)`` or ``fdatasync(STDOUT_FILENO)`` to drain the
-    write buffer.
-    The
-.. index:: CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER`` is defined if the application
-    wishes to include the Stub Device Driver.
-NOTES:
-    This device driver simply provides entry points that return successful and
-    is primarily a test fixture. It is supported by all BSPs.
-.. index:: CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER`` is defined if the application
-    wishes to include the Timer Driver.  This device driver is used to
-    benchmark execution times by the RTEMS Timing Test Suites.
-NOTES:
-.. index:: CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER`` is defined if the
-    application wishes to include the Watchdog Driver.
-NOTES:
-    Most BSPs do not include support for a watchdog device driver. This is
-.. index:: CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
-.. index:: /dev/zero
-.. _CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    This configuration variable is specified to enable ``/dev/zero`` device driver.
-NOTES:
-.. index:: CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
-.. _CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS:
-CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
-CONSTANT:
-    ``CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS`` is defined if the
-    application has device drivers it needs to include in the Device Driver
-    Table.  This should be defined to the set of device driver entries that
-    will be placed in the table at the *FRONT* of the Device Driver Table and
-    initialized before any other drivers *EXCEPT* any BSP prerequisite drivers.
-NOTES:
-    In some cases, it is used by System On Chip BSPs to support peripheral
-    buses beyond those normally found on the System On Chip. For example, this
-    is used by one RTEMS system which has implemented a SPARC/ERC32 based board
-    with VMEBus. The VMEBus Controller initialization is performed by a device
-    driver configured via this configuration parameter.
-.. index:: CONFIGURE_MAXIMUM_DRIVERS
-.. _CONFIGURE_MAXIMUM_DRIVERS:
-CONFIGURE_MAXIMUM_DRIVERS
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_DRIVERS``
-DATA TYPE:
-    Unsigned integer (``uint32_t``).
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-    This is computed by default, and is set to the number of device drivers
-    configured using the ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER``
-    configuration parameters.
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_DRIVERS`` is defined as the number of device drivers
-    per node.
-NOTES:
-    If the application will dynamically install device drivers, then this
-    configuration parameter must be larger than the number of statically
-    configured device drivers. Drivers configured using the
-    ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER`` configuration parameters are
-    statically installed.
+    device-config
 Multiprocessing Configuration
2.16.4
