[PATCH 17/20] c-user: Move "PCI Library Configuration"
Sebastian Huber
Mon Mar 9 09:03:00 UTC 2020
Update #3836.
c-user/config/index.rst | 53 +--------------------------------------
c-user/config/libpci-config.rst | 55 +++++++++++++++++++++++++++++++++++++++++
2 files changed, 56 insertions(+), 52 deletions(-)
create mode 100644 c-user/config/libpci-config.rst
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index e3c1720..e325d15 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -26,58 +26,7 @@ Configuring a System
clustered-sched-config
device-config
mpci-config
-PCI Library Configuration
-This section defines the system configuration parameters supported by
-``rtems/confdefs.h`` related to configuring the PCI Library for RTEMS.
-The PCI Library startup behaviour can be configured in four different ways
-depending on how ``CONFIGURE_PCI_CONFIG_LIB`` is defined:
-.. index:: PCI_LIB_AUTO
-``PCI_LIB_AUTO``
- Used to enable the PCI auto configuration software. PCI will be automatically
- probed, PCI buses enumerated, all devices and bridges will be initialized
- using Plug & Play software routines. The PCI device tree will be populated
- based on the PCI devices found in the system, PCI devices will be configured
- by allocating address region resources automatically in PCI space according
- to the BSP or host bridge driver set up.
-.. index:: PCI_LIB_READ
-``PCI_LIB_READ``
- Used to enable the PCI read configuration software. The current PCI
- configuration is read to create the RAM representation (the PCI device tree)
- of the PCI devices present. PCI devices are assumed to already have been
- initialized and PCI buses enumerated, it is therefore required that a BIOS or
- a boot loader has set up configuration space prior to booting into RTEMS.
-.. index:: PCI_LIB_STATIC
-``PCI_LIB_STATIC``
- Used to enable the PCI static configuration software. The user provides a PCI
- tree with information how all PCI devices are to be configured at compile
- time by linking in a custom ``struct pci_bus pci_hb`` tree. The static PCI
- library will not probe PCI for devices, instead it will assume that all
- devices defined by the user are present, it will enumerate the PCI buses and
- configure all PCI devices in static configuration accordingly. Since probe
- and allocation software is not needed the startup is faster, has smaller
- footprint and does not require dynamic memory allocation.
-.. index:: PCI_LIB_PERIPHERAL
-``PCI_LIB_PERIPHERAL``
- Used to enable the PCI peripheral configuration. It is similar to
- ``PCI_LIB_STATIC``, but it will never write the configuration to the PCI
- devices since PCI peripherals are not allowed to access PCI configuration
- space.
-Note that selecting ``PCI_LIB_STATIC`` or ``PCI_LIB_PERIPHERAL`` but not
-defining ``pci_hb`` will reuslt in link errors. Note also that in these modes
-Plug & Play is not performed.
+ libpci-config
Event Recording Configuration
diff --git a/c-user/config/libpci-config.rst b/c-user/config/libpci-config.rst
new file mode 100644
index 0000000..b62a56c
--- /dev/null
+++ b/c-user/config/libpci-config.rst
@@ -0,0 +1,55 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+PCI Library Configuration
+This section defines the system configuration parameters supported by
+``rtems/confdefs.h`` related to configuring the PCI Library for RTEMS.
+The PCI Library startup behaviour can be configured in four different ways
+depending on how ``CONFIGURE_PCI_CONFIG_LIB`` is defined:
+.. index:: PCI_LIB_AUTO
+``PCI_LIB_AUTO``
+ Used to enable the PCI auto configuration software. PCI will be automatically
+ probed, PCI buses enumerated, all devices and bridges will be initialized
+ using Plug & Play software routines. The PCI device tree will be populated
+ based on the PCI devices found in the system, PCI devices will be configured
+ by allocating address region resources automatically in PCI space according
+ to the BSP or host bridge driver set up.
+.. index:: PCI_LIB_READ
+``PCI_LIB_READ``
+ Used to enable the PCI read configuration software. The current PCI
+ configuration is read to create the RAM representation (the PCI device tree)
+ of the PCI devices present. PCI devices are assumed to already have been
+ initialized and PCI buses enumerated, it is therefore required that a BIOS or
+ a boot loader has set up configuration space prior to booting into RTEMS.
+.. index:: PCI_LIB_STATIC
+``PCI_LIB_STATIC``
+ Used to enable the PCI static configuration software. The user provides a PCI
+ tree with information how all PCI devices are to be configured at compile
+ time by linking in a custom ``struct pci_bus pci_hb`` tree. The static PCI
+ library will not probe PCI for devices, instead it will assume that all
+ devices defined by the user are present, it will enumerate the PCI buses and
+ configure all PCI devices in static configuration accordingly. Since probe
+ and allocation software is not needed the startup is faster, has smaller
+ footprint and does not require dynamic memory allocation.
+.. index:: PCI_LIB_PERIPHERAL
+``PCI_LIB_PERIPHERAL``
+ Used to enable the PCI peripheral configuration. It is similar to
+ ``PCI_LIB_STATIC``, but it will never write the configuration to the PCI
+ devices since PCI peripherals are not allowed to access PCI configuration
+ space.
+Note that selecting ``PCI_LIB_STATIC`` or ``PCI_LIB_PERIPHERAL`` but not
+defining ``pci_hb`` will reuslt in link errors. Note also that in these modes
+Plug & Play is not performed.
2.16.4
