RTEMS Python Standardization (ticket #3892)
Thu Mar 12 13:20:18 UTC 2020
On Thu, Mar 12, 2020 at 12:22 AM Anmol Mishra <anmol.j2020 at gmail.com> wrote:
> Hello,
> With whom can I discuss regarding douts, Any tentative mentor open for guiding me, I have a few doubts regarding the project. Is Dr. Gedare going to be a tentative mentor?
No, I won't be. I oversee all projects, and try to provide
guidance/structure and make sure proposals are sufficiently detailed
for us to evaluate. Amar is the most likely potential mentor on this
project and should be engaged to get technical direction/advice. The
mailing list is also preferred for most communication unless of a
personal nature.
> Best Regards
> On Tue, Mar 10, 2020 at 11:12 AM Anmol Mishra <anmol.j2020 at gmail.com> wrote:
>> Sure thing, I have replied and reviewed all your comments. Working on them and I will restructure it at the earliest. Now I understand google's idea to get it reviewed by mentors asap, so that reshaping can be done to match the target in time.
>> Thanks for your input and time.
>> Best Regards
>> On Tue, Mar 10, 2020 at 3:18 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> Hello Anmol,
>>> I have provided some feedback on your draft. Please focus on reshaping
>>> your proposal to provide a stronger organization of both your thought
>>> process and your plan for working in the summer. You might like to
>>> review advice in: https://google.github.io/gsocguides/student/
>>> On Mon, Mar 9, 2020 at 12:02 PM Anmol Mishra <anmol.j2020 at gmail.com> wrote:
>>> > Hello,
>>> > I proposed the project and after a lot of input, I saw that a project RTEMS Python Standardization (ticket #3892) has been added to the list.
>>> > I have drafted a proposal (It needs a lot of refinement and I seek from expected mentor and co-mentor in this step)
>>> > https://docs.google.com/document/d/1_G0-q7J2b-5kJzZGI32a-KpC6gMzJ1FcNFFTdMCw1c4/edit?usp=sharing
>>> > Please consider me a little naive as this is my first proposal, I will try to match the benchmark in the final proposal, A lot of discussions is to be done at this stage.
>>> > Best Regards
>>> > Anmol Mishra
