Issues when adding a multi-port PCI serial card
Sebastian Huber
Fri Mar 13 12:42:47 UTC 2020
On 12/03/2020 21:44, Peter Dufault wrote:
> I've added an 8-port RS232 PCI Mezzanine Card to the "beatnik" BSP. The console (aka serial port) code is confusing.
> I decided I should use what is in "bsp/console-termios.h" as opposed to the "legacy console" approach, *even though* "legacy console" is used in many recent BSPS.
What is a recent BSP for you? I would call all BSPs which still use this
major/minor number drivers a legacy BSP.
> * Is that correct?
> That approach went well, I created a replacement shared PowerPC console in "bsps/powerpc/shared/console/console-config.c" with only 129 lines of code and half of it comments.
This is probably all right. What we don't have in RTEMS is a generic
device enumeration framework.
> Where does the driver go: Next I had to add the PCI multi-port serial card driver. I put it in "bsps/shared/dev/pci/mp_serial.c". The other directory choice was "bsps/shared/dev/serial". I didn't like either, the "dev/pci" is very associated with PCI discovery and the "dev/serial" is very associated with the generic low-level serial driver support, even thought it has the "legacy-console" cruft in it.
> * Where should it go?
The serial drivers which are not specific to a BSP should go to
"bsps/shared/dev/serial" or even "cpukit/dev/serial".
> Difficulty in assigning common TTY names: Since my new shared PowerPC "console-config.c" created "/dev/ttyS0" and "/dev/ttyS1" I wanted to name the new serial devices with a number that started at 2, i.e., "/dev/ttyS2".
> * Is there a way in the "console-termios" framework to know what the highest "minor number" for a serial port is? I searched, gave up, and made it a configuration item.
No, we don't have a framework for unit number assignments. It is not
that easy if you look at the FreeBSD code. Why don't use use driver
specific names, e.g. "/dev/pci-serial-XXX"?
> Next I had to figure out the best way to probe and discover the board.
> * I wanted to add an RTEMS_SYSINIT_ITEM that would call a probe routine to discover the multiport cards at the appropriate time, after "/dev/console" was discovered but before I wanted to spawn my shell. I had trouble figuring out what level and order I should use for the probe routine. I never got this working, my probe routine kept getting called much later then I expected it to. I need a pointer to the documentation to RTEMS_SYSINIT_ITEM ordering.
I would initialize this in the Init task. The system initialization is
documented here:
https://docs.rtems.org/branches/master/c-user/initialization.html#initializing-rtems
> Finally, after initial successful loop-back testing, I tried to start an RTEMS shell on one of the new ports.
> *Here I'm trying hard to avoid all-caps because this took the most time of all (it should have been easiest), and I gave up!*
> * HOW (sorry) do you spawn a shell on a serial port? The documentation, at https://docs.rtems.org/branches/master/shell/configuration_and_init.html that suggests just setting the shell device name to "/dev/console", or in my case "/dev/ttyS9", is incorrect. The shell startup is intent on using "stdin" and "stdout".
I don't know this off hand.
