virtex4 fails to link norun tests
Joel Sherrill
joel at rtems.org
Fri Mar 13 15:28:03 UTC 2020
Thanks. I just started a build sweep for that. I also just started a tool
build, etc on Ubuntu.
FWIW This was found using my older rtems-testing scripts.
On Fri, Mar 13, 2020 at 9:21 AM Sebastian Huber <
> On 13/03/2020 14:40, Joel Sherrill wrote:
> > Not sure how to fix this or how long it has been broken:
> > powerpc-rtems5-gcc -mcpu=405 -O2 -g -fno-keep-inline-functions
> > -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
> > -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
> > -B./../../lib/libbsp/powerpc/virtex4
> -B/home/joel/rtems-work/rtems-testing/rtems/rtems/bsps/powerpc/virtex4/start
> > -specs bsp_specs -qrtems -L./../../cpukit
> -L/home/joel/rtems-work/rtems-testing/rtems/rtems/bsps/powerpc/shared/start
> > -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar -Wl,--gc-sections
> > -o calloc.norun.exe POSIX/calloc.o
> > ./../../cpukit/librtemsdefaultconfig.a
> > ./../../lib/libbsp/powerpc/virtex4/librtemsbsp.a
> > ./../../cpukit/librtemscpu.a ./../../cpukit/librtemstest.a
> /data/home/joel/rtems-work/tools/5/bin/../lib/gcc/powerpc-rtems5/7.5.0/../../../../powerpc-rtems5/bin/ld:
> > ./../../lib/libbsp/powerpc/virtex4/librtemsbsp.a(irq_init.o): in
> > function `BSP_install_rtems_irq_handler':
> This should be fixed now.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200313/c96c916c/attachment.html>
