[PATCH 1/2] Convert host checking to pytest.
Gedare Bloom
gedare at rtems.org
Sun Mar 15 23:26:50 UTC 2020
On Fri, Mar 13, 2020 at 5:28 PM Amar Takhar <amar at rtems.org> wrote:
> rtemstoolkit/darwin.py | 5 -----
> rtemstoolkit/freebsd.py | 5 -----
> rtemstoolkit/host.py | 14 --------------
> rtemstoolkit/linux.py | 5 -----
> rtemstoolkit/netbsd.py | 5 -----
> rtemstoolkit/solaris.py | 5 -----
> rtemstoolkit/tests/test_host.py | 32 ++++++++++++++++++++++++++++++++
> rtemstoolkit/windows.py | 5 -----
> 8 files changed, 32 insertions(+), 44 deletions(-)
> create mode 100644 rtemstoolkit/tests/test_host.py
> diff --git a/rtemstoolkit/darwin.py b/rtemstoolkit/darwin.py
> index e780d1d..b9e17cf 100644
> --- a/rtemstoolkit/darwin.py
> +++ b/rtemstoolkit/darwin.py
> @@ -76,8 +76,3 @@ def overrides():
> defines['_build_arch'] = defines['_host_arch']
> return defines
> -if __name__ == '__main__':
> - import pprint
> - pprint.pprint(cpus())
> - pprint.pprint(overrides())
> diff --git a/rtemstoolkit/freebsd.py b/rtemstoolkit/freebsd.py
> index ed16140..6e40c34 100644
> --- a/rtemstoolkit/freebsd.py
> +++ b/rtemstoolkit/freebsd.py
> @@ -97,8 +97,3 @@ def overrides():
> break
> return defines
> - import pprint
> diff --git a/rtemstoolkit/host.py b/rtemstoolkit/host.py
> index 01aae07..67b006a 100644
> --- a/rtemstoolkit/host.py
> +++ b/rtemstoolkit/host.py
> @@ -103,17 +103,3 @@ def label(mode = 'all'):
> if mode == 'all':
> return '%s (%s)' % (compact, extended)
> raise error.general('invalid platform mode: %s' % (mode))
> - import pprint
> - print('Python\'s OS name: %s' % (os.name))
> - load()
> - print('Name : %s' % (name))
> - if is_windows:
> - status = 'Yes'
> - else:
> - status = 'No'
> - print('Windows : %s' % (status))
> - print('CPUs : %d' % (cpus()))
> - print('Overrides :')
> diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
> index 21f6f97..15b8528 100644
> --- a/rtemstoolkit/linux.py
> +++ b/rtemstoolkit/linux.py
> @@ -134,8 +134,3 @@ def overrides():
> return defines
> - import pprint
> diff --git a/rtemstoolkit/netbsd.py b/rtemstoolkit/netbsd.py
> index 1d9a11f..eab9353 100644
> --- a/rtemstoolkit/netbsd.py
> +++ b/rtemstoolkit/netbsd.py
> @@ -90,8 +90,3 @@ def overrides():
> break
> return defines
> - import pprint
> diff --git a/rtemstoolkit/solaris.py b/rtemstoolkit/solaris.py
> index 79ddd75..1b265da 100644
> --- a/rtemstoolkit/solaris.py
> +++ b/rtemstoolkit/solaris.py
> @@ -83,8 +83,3 @@ def overrides():
> return defines
> - import pprint
> diff --git a/rtemstoolkit/tests/test_host.py b/rtemstoolkit/tests/test_host.py
> new file mode 100644
> index 0000000..4b1bf00
> --- /dev/null
> +++ b/rtemstoolkit/tests/test_host.py
> @@ -0,0 +1,32 @@
> +import pytest
> +from rtemstoolkit import host
> +import re
> +def test_cpu():
> + assert type(host.cpus()) is int
> +def test_overrides():
> + assert type(host.overrides()) is dict
> +def test_label_system():
> + assert host.label(mode="system") is not None
> +def test_label_compact():
> + assert re.match("^[a-zA-Z]*-.*-.*$", host.label(mode="compact"))
Make blank lines consistent, 1 or 2, between top-level definitions. (I
know, we still haven't settled on a style, but let's aim for
consistency.)
> +def test_label_extended():
> + assert re.match("^[a-zA-Z]* .*$", host.label(mode="extended"))
> +def test_label_all():
> + assert re.match("^[a-zA-Z]*-.*-.* \\(.*\\)$", host.label(mode="all"))
> +def test_label_error():
> + from rtemstoolkit.error import general
I think all imports should go at the top?
> + with pytest.raises(general, match=r"^error: invalid platform mode: _nonexistent_$"):
> + assert host.label(mode="_nonexistent_")
> diff --git a/rtemstoolkit/windows.py b/rtemstoolkit/windows.py
> index 802263b..585cddf 100644
> --- a/rtemstoolkit/windows.py
> +++ b/rtemstoolkit/windows.py
> @@ -132,8 +132,3 @@ def overrides():
> '___setup_shell': ('exe', 'required', '%{__sh}')
> return defines
> - import pprint
> 2.25.0
> devel mailing list
> devel at rtems.org
