[PATCH] Start conversion tests to using pytest.
Amar Takhar
amar at rtems.org
Mon Mar 16 03:52:42 UTC 2020
On 2020-03-15 21:28 -0600, Gedare Bloom wrote:
> For new files, we should try to use the boilerplate recently suggested:
> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#python-file-template
I'll fix this before pushing thanks.
> If that should be tweaked, now is the time to do it. Similarly, if the
> she-bang should be removed in some cases, the rationale should be
> documented in the eng guide.
None of these are executables but noted.
Amar.
