[PATCH 06/12] record: Add option to print config default values
Sebastian Huber
Mon Mar 16 10:50:26 UTC 2020
Update #3904.
trace/record/record-main-lttng.cc | 35 ++++++++++++++++++++++++++---------
1 file changed, 26 insertions(+), 9 deletions(-)
diff --git a/trace/record/record-main-lttng.cc b/trace/record/record-main-lttng.cc
index 891281e..15536f4 100644
--- a/trace/record/record-main-lttng.cc
+++ b/trace/record/record-main-lttng.cc
@@ -759,9 +759,10 @@ static void SignalHandler(int s) {
static const struct option kLongOpts[] = {
- {"elf", 1, NULL, 'e'}, {"help", 0, NULL, 'h'}, {"host", 1, NULL, 'H'},
- {"limit", 1, NULL, 'l'}, {"port", 1, NULL, 'p'}, {"config", 1, NULL, 'c'},
- {NULL, 0, NULL, 0}};
+ {"elf", 1, NULL, 'e'}, {"help", 0, NULL, 'h'},
+ {"host", 1, NULL, 'H'}, {"limit", 1, NULL, 'l'},
+ {"port", 1, NULL, 'p'}, {"config", 1, NULL, 'c'},
+ {"defaults", 0, NULL, 'd'}, {NULL, 0, NULL, 0}};
static void Usage(char** argv) {
std::cout << argv[0] << " [OPTION]... [INPUT-FILE]" << std::endl
@@ -781,9 +782,22 @@ static void Usage(char** argv) {
<< std::endl
<< " -c, --config=CONFIG an INI-style configuration file"
<< std::endl
+ << " -d, --defaults print default values for "
+ "configuration file"
+ << std::endl
<< " INPUT-FILE the input file" << std::endl;
+static void PrintDefaults() {
+ std::cout << "[EventNames]" << std::endl;
+ for (int i = 0; i <= RTEMS_RECORD_LAST; ++i) {
+ std::cout << i << " = "
+ << rtems_record_event_text(static_cast<rtems_record_event>(i))
+ << std::endl;
int main(int argc, char** argv) {
const char* host = "127.0.0.1";
uint16_t port = 1234;
@@ -793,27 +807,30 @@ int main(int argc, char** argv) {
int opt;
int longindex;
- while ((opt = getopt_long(argc, argv, "e:hH:l:p:c:", &kLongOpts[0],
+ while ((opt = getopt_long(argc, argv, "hH:p:l:be:c:d", &kLongOpts[0],
&longindex)) != -1) {
switch (opt) {
- case 'e':
- elf_file = optarg;
- break;
case 'h':
Usage(argv);
return 0;
case 'H':
host = optarg;
break;
+ case 'p':
+ port = (uint16_t)strtoul(optarg, NULL, 0);
+ break;
case 'l':
client.set_limit(strtoull(optarg, NULL, 0));
break;
- case 'p':
- port = (uint16_t)strtoul(optarg, NULL, 0);
+ case 'e':
+ elf_file = optarg;
break;
case 'c':
config_file = optarg;
break;
+ case 'd':
+ PrintDefaults();
+ return 0;
default:
return 1;
2.16.4
