[PATCH 04/12] record: Add INI file parser
Sebastian Huber
Mon Mar 16 10:50:24 UTC 2020
Import from:
https://github.com/benhoyt/inih
commit 351217124ddb3e3fe2b982248a04c672350bb0af
Author: Stephan Lachnit <stephanlachnit at protonmail.com>
Date: Sun Mar 1 07:31:28 2020 +0100
r48 release (#100)
* Bump copyright to 2020
* Remove makefile for static library
* meson: version 48
Signed-off-by: Stephan Lachnit <stephanlachnit at protonmail.com>
Update #3904.
trace/record/inih/LICENSE.txt | 27 ++++
trace/record/inih/ini.c | 284 ++++++++++++++++++++++++++++++++++++++++++
trace/record/inih/ini.h | 148 ++++++++++++++++++++++
trace/wscript | 5 +-
4 files changed, 462 insertions(+), 2 deletions(-)
create mode 100644 trace/record/inih/LICENSE.txt
create mode 100644 trace/record/inih/ini.c
create mode 100644 trace/record/inih/ini.h
diff --git a/trace/record/inih/LICENSE.txt b/trace/record/inih/LICENSE.txt
new file mode 100644
index 0000000..cb7ee2d
--- /dev/null
+++ b/trace/record/inih/LICENSE.txt
@@ -0,0 +1,27 @@
+The "inih" library is distributed under the New BSD license:
+Copyright (c) 2009, Ben Hoyt
+All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are met:
+ * Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+ * Redistributions in binary form must reproduce the above copyright
+ notice, this list of conditions and the following disclaimer in the
+ documentation and/or other materials provided with the distribution.
+ * Neither the name of Ben Hoyt nor the names of its contributors
+ may be used to endorse or promote products derived from this software
+ without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY BEN HOYT ''AS IS'' AND ANY
+EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+DISCLAIMED. IN NO EVENT SHALL BEN HOYT BE LIABLE FOR ANY
+DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
diff --git a/trace/record/inih/ini.c b/trace/record/inih/ini.c
index 0000000..d19d613
--- /dev/null
+++ b/trace/record/inih/ini.c
@@ -0,0 +1,284 @@
+/* inih -- simple .INI file parser
+SPDX-License-Identifier: BSD-3-Clause
+Copyright (C) 2009-2020, Ben Hoyt
+inih is released under the New BSD license (see LICENSE.txt). Go to the project
+home page for more info:
+https://github.com/benhoyt/inih
+#if defined(_MSC_VER) && !defined(_CRT_SECURE_NO_WARNINGS)
+#define _CRT_SECURE_NO_WARNINGS
+#endif
+#include <stdio.h>
+#include <ctype.h>
+#include <string.h>
+#include "ini.h"
+#if !INI_USE_STACK
+#include <stdlib.h>
+#endif
+#define MAX_SECTION 50
+#define MAX_NAME 50
+/* Used by ini_parse_string() to keep track of string parsing state. */
+typedef struct {
+ const char* ptr;
+ size_t num_left;
+} ini_parse_string_ctx;
+/* Strip whitespace chars off end of given string, in place. Return s. */
+static char* rstrip(char* s)
+ char* p = s + strlen(s);
+ while (p > s && isspace((unsigned char)(*--p)))
+ *p = '\0';
+ return s;
+/* Return pointer to first non-whitespace char in given string. */
+static char* lskip(const char* s)
+ while (*s && isspace((unsigned char)(*s)))
+ s++;
+ return (char*)s;
+/* Return pointer to first char (of chars) or inline comment in given string,
+ or pointer to null at end of string if neither found. Inline comment must
+ be prefixed by a whitespace character to register as a comment. */
+static char* find_chars_or_comment(const char* s, const char* chars)
+#if INI_ALLOW_INLINE_COMMENTS
+ int was_space = 0;
+ while (*s && (!chars || !strchr(chars, *s)) &&
+ !(was_space && strchr(INI_INLINE_COMMENT_PREFIXES, *s))) {
+ was_space = isspace((unsigned char)(*s));
+ s++;
+#else
+ while (*s && (!chars || !strchr(chars, *s))) {
+ s++;
+#endif
+ return (char*)s;
+/* Version of strncpy that ensures dest (size bytes) is null-terminated. */
+static char* strncpy0(char* dest, const char* src, size_t size)
+ strncpy(dest, src, size - 1);
+ dest[size - 1] = '\0';
+ return dest;
+/* See documentation in header file. */
+int ini_parse_stream(ini_reader reader, void* stream, ini_handler handler,
+ void* user)
+ /* Uses a fair bit of stack (use heap instead if you need to) */
+#if INI_USE_STACK
+ char line[INI_MAX_LINE];
+ int max_line = INI_MAX_LINE;
+#else
+ char* line;
+ size_t max_line = INI_INITIAL_ALLOC;
+#endif
+#if INI_ALLOW_REALLOC && !INI_USE_STACK
+ char* new_line;
+ size_t offset;
+#endif
+ char section[MAX_SECTION] = "";
+ char prev_name[MAX_NAME] = "";
+ char* start;
+ char* end;
+ char* name;
+ char* value;
+ int lineno = 0;
+ int error = 0;
+#if !INI_USE_STACK
+ line = (char*)malloc(INI_INITIAL_ALLOC);
+ if (!line) {
+ return -2;
+#endif
+#if INI_HANDLER_LINENO
+#define HANDLER(u, s, n, v) handler(u, s, n, v, lineno)
+#else
+#define HANDLER(u, s, n, v) handler(u, s, n, v)
+#endif
+ /* Scan through stream line by line */
+ while (reader(line, (int)max_line, stream) != NULL) {
+ offset = strlen(line);
+ while (offset == max_line - 1 && line[offset - 1] != '\n') {
+ max_line *= 2;
+ if (max_line > INI_MAX_LINE)
+ max_line = INI_MAX_LINE;
+ new_line = realloc(line, max_line);
+ if (!new_line) {
+ free(line);
+ return -2;
+ line = new_line;
+ if (reader(line + offset, (int)(max_line - offset), stream) == NULL)
+ break;
+ if (max_line >= INI_MAX_LINE)
+ break;
+ offset += strlen(line + offset);
+#endif
+ lineno++;
+ start = line;
+#if INI_ALLOW_BOM
+ if (lineno == 1 && (unsigned char)start[0] == 0xEF &&
+ (unsigned char)start[1] == 0xBB &&
+ (unsigned char)start[2] == 0xBF) {
+ start += 3;
+#endif
+ start = lskip(rstrip(start));
+ if (strchr(INI_START_COMMENT_PREFIXES, *start)) {
+ /* Start-of-line comment */
+#if INI_ALLOW_MULTILINE
+ else if (*prev_name && *start && start > line) {
+ /* Non-blank line with leading whitespace, treat as continuation
+ of previous name's value (as per Python configparser). */
+ if (!HANDLER(user, section, prev_name, start) && !error)
+ error = lineno;
+#endif
+ else if (*start == '[') {
+ /* A "[section]" line */
+ end = find_chars_or_comment(start + 1, "]");
+ if (*end == ']') {
+ *end = '\0';
+ strncpy0(section, start + 1, sizeof(section));
+ *prev_name = '\0';
+#if INI_CALL_HANDLER_ON_NEW_SECTION
+ if (!HANDLER(user, section, NULL, NULL) && !error)
+ error = lineno;
+#endif
+ else if (!error) {
+ /* No ']' found on section line */
+ error = lineno;
+ else if (*start) {
+ /* Not a comment, must be a name[=:]value pair */
+ end = find_chars_or_comment(start, "=:");
+ if (*end == '=' || *end == ':') {
+ *end = '\0';
+ name = rstrip(start);
+ value = end + 1;
+ end = find_chars_or_comment(value, NULL);
+ if (*end)
+ *end = '\0';
+#endif
+ value = lskip(value);
+ rstrip(value);
+ /* Valid name[=:]value pair found, call handler */
+ strncpy0(prev_name, name, sizeof(prev_name));
+ if (!HANDLER(user, section, name, value) && !error)
+ error = lineno;
+ /* No '=' or ':' found on name[=:]value line */
+#if INI_ALLOW_NO_VALUE
+ *end = '\0';
+ if (!HANDLER(user, section, name, NULL) && !error)
+ error = lineno;
+#else
+ error = lineno;
+#endif
+#if INI_STOP_ON_FIRST_ERROR
+ if (error)
+ break;
+#endif
+#if !INI_USE_STACK
+ free(line);
+#endif
+ return error;
+int ini_parse_file(FILE* file, ini_handler handler, void* user)
+ return ini_parse_stream((ini_reader)fgets, file, handler, user);
+int ini_parse(const char* filename, ini_handler handler, void* user)
+ FILE* file;
+ int error;
+ file = fopen(filename, "r");
+ if (!file)
+ return -1;
+ error = ini_parse_file(file, handler, user);
+ fclose(file);
+ return error;
+/* An ini_reader function to read the next line from a string buffer. This
+ is the fgets() equivalent used by ini_parse_string(). */
+static char* ini_reader_string(char* str, int num, void* stream) {
+ ini_parse_string_ctx* ctx = (ini_parse_string_ctx*)stream;
+ const char* ctx_ptr = ctx->ptr;
+ size_t ctx_num_left = ctx->num_left;
+ char* strp = str;
+ char c;
+ if (ctx_num_left == 0 || num < 2)
+ return NULL;
+ while (num > 1 && ctx_num_left != 0) {
+ c = *ctx_ptr++;
+ ctx_num_left--;
+ *strp++ = c;
+ if (c == '\n')
+ break;
+ num--;
+ *strp = '\0';
+ ctx->ptr = ctx_ptr;
+ ctx->num_left = ctx_num_left;
+ return str;
+int ini_parse_string(const char* string, ini_handler handler, void* user) {
+ ini_parse_string_ctx ctx;
+ ctx.ptr = string;
+ ctx.num_left = strlen(string);
+ return ini_parse_stream((ini_reader)ini_reader_string, &ctx, handler,
+ user);
diff --git a/trace/record/inih/ini.h b/trace/record/inih/ini.h
index 0000000..441f560
--- /dev/null
+++ b/trace/record/inih/ini.h
@@ -0,0 +1,148 @@
+#ifndef __INI_H__
+#define __INI_H__
+/* Make this header file easier to include in C++ code */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdio.h>
+/* Nonzero if ini_handler callback should accept lineno parameter. */
+#ifndef INI_HANDLER_LINENO
+#define INI_HANDLER_LINENO 0
+#endif
+/* Typedef for prototype of handler function. */
+typedef int (*ini_handler)(void* user, const char* section,
+ const char* name, const char* value,
+ int lineno);
+#else
+ const char* name, const char* value);
+#endif
+/* Typedef for prototype of fgets-style reader function. */
+typedef char* (*ini_reader)(char* str, int num, void* stream);
+/* Parse given INI-style file. May have [section]s, name=value pairs
+ (whitespace stripped), and comments starting with ';' (semicolon). Section
+ is "" if name=value pair parsed before any section heading. name:value
+ pairs are also supported as a concession to Python's configparser.
+ For each name=value pair parsed, call handler function with given user
+ pointer as well as section, name, and value (data only valid for duration
+ of handler call). Handler should return nonzero on success, zero on error.
+ Returns 0 on success, line number of first error on parse error (doesn't
+ stop on first error), -1 on file open error, or -2 on memory allocation
+ error (only when INI_USE_STACK is zero).
+int ini_parse(const char* filename, ini_handler handler, void* user);
+/* Same as ini_parse(), but takes a FILE* instead of filename. This doesn't
+ close the file when it's finished -- the caller must do that. */
+int ini_parse_file(FILE* file, ini_handler handler, void* user);
+/* Same as ini_parse(), but takes an ini_reader function pointer instead of
+ filename. Used for implementing custom or string-based I/O (see also
+ ini_parse_string). */
+ void* user);
+/* Same as ini_parse(), but takes a zero-terminated string with the INI data
+instead of a file. Useful for parsing INI data from a network socket or
+already in memory. */
+int ini_parse_string(const char* string, ini_handler handler, void* user);
+/* Nonzero to allow multi-line value parsing, in the style of Python's
+ configparser. If allowed, ini_parse() will call the handler with the same
+ name for each subsequent line parsed. */
+#ifndef INI_ALLOW_MULTILINE
+#define INI_ALLOW_MULTILINE 1
+#endif
+/* Nonzero to allow a UTF-8 BOM sequence (0xEF 0xBB 0xBF) at the start of
+ the file. See https://github.com/benhoyt/inih/issues/21 */
+#ifndef INI_ALLOW_BOM
+#define INI_ALLOW_BOM 1
+#endif
+/* Chars that begin a start-of-line comment. Per Python configparser, allow
+ both ; and # comments at the start of a line by default. */
+#ifndef INI_START_COMMENT_PREFIXES
+#define INI_START_COMMENT_PREFIXES ";#"
+#endif
+/* Nonzero to allow inline comments (with valid inline comment characters
+ specified by INI_INLINE_COMMENT_PREFIXES). Set to 0 to turn off and match
+ Python 3.2+ configparser behaviour. */
+#ifndef INI_ALLOW_INLINE_COMMENTS
+#define INI_ALLOW_INLINE_COMMENTS 1
+#endif
+#ifndef INI_INLINE_COMMENT_PREFIXES
+#define INI_INLINE_COMMENT_PREFIXES ";"
+#endif
+/* Nonzero to use stack for line buffer, zero to use heap (malloc/free). */
+#ifndef INI_USE_STACK
+#define INI_USE_STACK 1
+#endif
+/* Maximum line length for any line in INI file (stack or heap). Note that
+ this must be 3 more than the longest line (due to '\r', '\n', and '\0'). */
+#ifndef INI_MAX_LINE
+#define INI_MAX_LINE 200
+#endif
+/* Nonzero to allow heap line buffer to grow via realloc(), zero for a
+ fixed-size buffer of INI_MAX_LINE bytes. Only applies if INI_USE_STACK is
+ zero. */
+#ifndef INI_ALLOW_REALLOC
+#define INI_ALLOW_REALLOC 0
+#endif
+/* Initial size in bytes for heap line buffer. Only applies if INI_USE_STACK
+ is zero. */
+#ifndef INI_INITIAL_ALLOC
+#define INI_INITIAL_ALLOC 200
+#endif
+/* Stop parsing on first error (default is to keep parsing). */
+#ifndef INI_STOP_ON_FIRST_ERROR
+#define INI_STOP_ON_FIRST_ERROR 0
+#endif
+/* Nonzero to call the handler at the start of each new section (with
+ name and value NULL). Default is to only call the handler on
+ each name=value pair. */
+#ifndef INI_CALL_HANDLER_ON_NEW_SECTION
+#define INI_CALL_HANDLER_ON_NEW_SECTION 0
+#endif
+/* Nonzero to allow a name without a value (no '=' or ':' on the line) and
+ call the handler with value NULL in this case. Default is to treat
+ no-value lines as an error. */
+#ifndef INI_ALLOW_NO_VALUE
+#define INI_ALLOW_NO_VALUE 0
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* __INI_H__ */
diff --git a/trace/wscript b/trace/wscript
index 38220a5..3ded695 100644
--- a/trace/wscript
+++ b/trace/wscript
@@ -54,7 +54,7 @@ def build(bld):
# Build flags.
- conf['includes'] = ['.', 'record']
+ conf['includes'] = ['.', 'record', 'record/inih']
conf['warningflags'] = ['-Wall', '-Wextra', '-pedantic']
conf['optflags'] = bld.env.C_OPTS
conf['cflags'] = ['-pipe', '-g'] + conf['optflags']
@@ -80,7 +80,8 @@ def build(bld):
source = ['record/record-client.c',
'record/record-text.c',
'record/record-client-base.cc',
- 'record/record-main-lttng.cc'],
+ 'record/record-main-lttng.cc',
+ 'record/inih/ini.c'],
includes = conf['includes'],
defines = defines,
cflags = conf['cflags'] + conf['warningflags'],
2.16.4
