[PATCH 10/12] record: Add zlib filter class
Sebastian Huber
Mon Mar 16 10:50:30 UTC 2020
Update #3904.
trace/record/client.h | 24 ++++++++++++
trace/record/record-filter-zlib.cc | 77 ++++++++++++++++++++++++++++++++++++++
trace/wscript | 5 +++
3 files changed, 106 insertions(+)
create mode 100644 trace/record/record-filter-zlib.cc
diff --git a/trace/record/client.h b/trace/record/client.h
index b4a0c26..62ffdb5 100644
--- a/trace/record/client.h
+++ b/trace/record/client.h
@@ -42,6 +42,11 @@
#include <stdexcept>
#include <string>
#include <utility>
+#include <vector>
+#ifdef HAVE_ZLIB_H
+#include <zlib.h>
+#endif
class ErrnoException : public std::runtime_error {
public:
@@ -132,6 +137,25 @@ class Base64Filter : public Filter {
bool DecodeChar(int c, char **target);
+#ifdef HAVE_ZLIB_H
+class ZlibFilter : public Filter {
+ public:
+ ZlibFilter();
+ ZlibFilter(const ZlibFilter&) = default;
+ ZlibFilter& operator=(const ZlibFilter&) = default;
+ virtual ~ZlibFilter();
+ virtual bool Run(void** buf, size_t* n);
+ private:
+ z_stream stream_;
+ std::vector<Bytef> buffer_;
+#endif
class Client {
public:
Client() = default;
diff --git a/trace/record/record-filter-zlib.cc b/trace/record/record-filter-zlib.cc
new file mode 100644
index 0000000..87b2cfe
--- /dev/null
+++ b/trace/record/record-filter-zlib.cc
@@ -0,0 +1,77 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#ifdef HAVE_ZLIB_H
+#include "client.h"
+ZlibFilter::ZlibFilter() : buffer_(65536)
+ inflateInit(&stream_);
+ZlibFilter::~ZlibFilter()
+ inflateEnd(&stream_);
+bool ZlibFilter::Run(void** buf, size_t* n) {
+ stream_.next_in = static_cast<unsigned char*>(*buf);
+ stream_.avail_in = *n;
+ stream_.next_out = &buffer_[0];
+ size_t avail_out = 0;
+ size_t buffer_size = buffer_.size();
+ size_t chunk_size = buffer_size;
+ stream_.avail_out = buffer_size;
+ while (true) {
+ int err = inflate(&stream_, Z_NO_FLUSH);
+ if (err != Z_OK && err != Z_STREAM_END) {
+ return false;
+ if (stream_.avail_in > 0) {
+ chunk_size = buffer_size;
+ buffer_size *= 2;
+ buffer_.resize(buffer_size);
+ stream_.next_out = reinterpret_cast<Bytef*>(&buffer_[chunk_size]);
+ stream_.avail_out = chunk_size;
+ avail_out += chunk_size;
+ continue;
+ *buf = &buffer_[0];
+ *n = avail_out + chunk_size - stream_.avail_out;
+ return true;
+#endif // HAVE_ZLIB_H
diff --git a/trace/wscript b/trace/wscript
index 7e35f74..656f92b 100644
--- a/trace/wscript
+++ b/trace/wscript
@@ -42,6 +42,8 @@ def configure(conf):
pass
if conf.check_cxx(lib = 'LLVM', mandatory=False):
conf.check(header_name='llvm/DebugInfo/Symbolize/Symbolize.h', features='cxx', mandatory=False)
+ if conf.check(header_name='zlib.h', features='cxx', mandatory=False):
+ conf.check_cxx(lib = 'z')
conf.check_cxx(lib = 'ws2_32', mandatory=False)
conf.write_config_header('config.h')
@@ -65,6 +67,8 @@ def build(bld):
conf['lib'].extend(bld.env.LIB_WS2_32)
if bld.env.LIB_LLVM:
conf['lib'].extend(bld.env.LIB_LLVM)
+ if bld.env.LIB_Z:
+ conf['lib'].extend(bld.env.LIB_Z)
# The list of defines
@@ -81,6 +85,7 @@ def build(bld):
'record/record-text.c',
'record/record-client-base.cc',
'record/record-filter-base64.cc',
+ 'record/record-filter-zlib.cc',
'record/record-main-lttng.cc',
'record/inih/ini.c'],
includes = conf['includes'],
2.16.4
