[RFC] RTEMS Waf Clang support
Hesham Almatary
heshamelmatary at gmail.com
Mon Mar 16 12:09:08 UTC 2020
On Mon, 16 Mar 2020 at 11:53, Sebastian Huber
> On 16/03/2020 12:39, Hesham Almatary wrote:
> > Hi Sebastian,
> > I have pushed a few commits to my repo to support building RTEMS with
> > Clang/LLVM for RISC-V. Here are the changes [1]. Since I'm still
> > learning about Waf and the build system, I'd appreciate your input.
> > Most importantly, I want to know what's the right way to set "target"
> > and "xlen" variables.
> > [1] https://github.com/CTSRD-CHERI/rtems/compare/967b62464bf39602f8b0f2baf57617ad74c3643d...aa73f72b929856efdb41f9f8582263b5395a3276
> You need a new option, e.g.
> spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTXLEN.yml
> It should be enabled by clang and riscv:
> enabled-by:
> and:
> - clang
> - riscv
> The option must be evaluated before the tool settings:
> order: -1000
Yes, I thought of that too. But I need to define XLEN to empty or
something for other architectures too since I use it in
RTEMS-BUILD-CPUKIT-OPTCLANG:
> - set-value: --target=${ARCH}${XLEN}-unknown-rtems${__RTEMS_MAJOR__}
> - substitute: null
> - env-append: ABI_FLAGS
How should each RISC-V BSP assign XLEN? I thought of a few ways:
1) to make each BSP yml file do it, or
2) to script it for RISC-V and extract it from the march value,
3) to assign it in a single file and, similar to how
RISC-V-BUILD-BSP-RISC-V-ABI currently works, assign it per variant.
Hesham
