[RFC] RTEMS Waf Clang support
Hesham Almatary
heshamelmatary at gmail.com
Mon Mar 16 13:04:07 UTC 2020
On Mon, 16 Mar 2020 at 12:54, Sebastian Huber <
> On 16/03/2020 13:51, Hesham Almatary wrote:
> Thanks Sebastian!
> I tried to follow your instructions for adding this as a new option, but
> unfortunately, XLEN didn't evaluate for RTEMS-BUILD-CPUKIT-OPTCLANG to use.
> Here's the diff:
> diff --git a/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTXLEN.yml
>> b/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTXLEN.yml
>> new file mode 100644
>> index 0000000000..840a8ecc2c
>> --- /dev/null
>> +++ b/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTXLEN.yml
>> @@ -0,0 +1,19 @@
>> +active: true
>> +build-type: option
>> +default: ''
>> +default-by-variant:
>> +- value: '64'
>> + variants:
>> + - riscv/rv64.*
>> +derived: false
>> +enabled-by: []
>> +header: ''
>> +level: '1.110'
>> +links: []
>> +name: XLEN
>> +normative: true
>> +order: -1000
>> +ref: ''
>> +reviewed: ChapNb5NSPl062d5CnU251RB5J6TljFz_mLkmFdgwVY=
>> +text: ''
>> +type: build
> grepping for XLEN only gets me:
>> c4che/spec_build.pickle:133389:ssS'RTEMS-BUILD-CPUKIT-OPTXLEN'
>> c4che/spec_build.pickle:133433:S'XLEN'
>> c4che/spec_build.pickle:154984:S'--target=${ARCH}${XLEN}-unknown-rtems${__RTEMS_MAJOR__}'
> Am I missing something?
> Did you link the new item to
> spec/build/cpukit/RTEMS-BUILD-CPUKIT-CPUOPTS.yml
That's what I was missing, thanks!
Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200316/273e4416/attachment-0001.html>
