[PATCH 1/1] eng: Add Python development guidelines
Mon Mar 16 18:25:24 UTC 2020
On Mon, Mar 16, 2020 at 9:11 AM Sebastian Huber
>  eng/management.rst   |   1 +
>  eng/python-devel.rst | 136 +++++++++++++++++++++++++++++++++++++++++++++++++++
>  2 files changed, 137 insertions(+)
>  create mode 100644 eng/python-devel.rst
> diff --git a/eng/management.rst b/eng/management.rst
> index 064559c..6eb4217 100644
> --- a/eng/management.rst
> +++ b/eng/management.rst
> @@ -16,5 +16,6 @@ Software Development Management
>      vc-users
>      vc-authors
>      coding
> +    python-devel
>      change-management
>      issue-tracking
> diff --git a/eng/python-devel.rst b/eng/python-devel.rst
> new file mode 100644
> index 0000000..0347892
> --- /dev/null
> +++ b/eng/python-devel.rst
> @@ -0,0 +1,136 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +.. _PythonDevelGuide:
> +Python Development Guidelines
> +Python is the main programming language for the RTEMS Tools.  The RTEMS Tools
> +run on the host computer of an RTEMS user or maintainer.  These guidelines
> +cover the Python language version, the source code formatting, use of static
> +analysis tools, type annotations, testing, code coverage, and documentation.
> +There are exceptions for existing code and third-party code.  It is recommended
> +to read the
> +`PEP 8 - Style Guide for Python Code <https://www.python.org/dev/peps/pep-0008/>`_
> +and the
> +`Google Python Style Guide <http://google.github.io/styleguide/pyguide.html>`_.
> +Python Language Versions
> +Although the official end-of-life of Python 2.7 was on January 1, 2020, the
> +RTEMS Project still cares about Python 2.7 compatibility for some tools.  Every
> +tool provided by the RTEMS Project which an RTEMS user may use to develop
> +applications with RTEMS should be Python 2.7 compatible.  Examples are the
> +build system, the RTEMS Source Builder, and the RTEMS Tester.  The rationale is
> +that there are still some maintained Linux distributions in the wild which ship
> +only Python 2.7 by default.  An example is CentOS 7 which gets maintenance
> +updates until June 2024.  Everything an RTEMS maintainer uses should be written
> +in Python 3.6.
> +Python Code Formatting
> +Good looking code is important.  Unfortunately, what looks good is a bit
> +subjective and varies from developer to developer.  Arguing about the code
> +format is not productive.  Code reviews should focus on more important topics,
> +e.g. functionality, testability, and performance.  Fortunately, for Python
> +there are some good automatic code formatters available.  All new code
> +specifically developed for the RTEMS Tools should be piped through the
> +`yapf <https://github.com/google/yapf>`_ Python code formatter before it is
> +committed or sent for review.  Use the default settings of the tool
s/sent/send
Rest of this looks good to me.
> +(`PEP 8 <https://www.python.org/dev/peps/pep-0008/>`_ coding style).
> +You can disable the automatic formatting by the tool in a region starting with
> +the ``#yapf: disable`` comment until the next ``# yapf: enable`` comment, e.g.
> +.. code-block:: python
> +    # yapf: disable
> +    FOO = {
> +        # ... some very large, complex data literal.
> +    BAR = [
> +        # ... another large data literal.
> +    # yapf: enable
> +For a single literal, you can disable the formatting like this:
> +    BAZ = {
> +        (1, 2, 3, 4),
> +        (5, 6, 7, 8),
> +        (9, 10, 11, 12),
> +    }  # yapf: disable
> +Static Analysis Tools
> +Use the ``flake8`` and ``pylint`` static analysis tools for Python.  Do not
> +commit your code or sent it for review if the tools find some rule
> +violations.  Run the tools with the default configuration.  If you have
> +problems to silence the tools, then please ask for help on the :r:list:`devel`.
> +Consult the tool documentation to silence false positives.
> +Type Annotations
> +For Python 3.6 or later code use type annotations.  All public functions of
> +your modules should have `PEP 484 <https://www.python.org/dev/peps/pep-0484/>`_
> +type annotations.  Check for type issues with the
> +`mypy <http://mypy-lang.org/>`_ static type checker.
> +Testing
> +Write unit tests for your code with the standard Python ``unittest`` and
> +``unittest.mock`` modules.  Use ``coverage run -m pytest`` to run the tests
> +with code coverage support.  If you modify existing code or contribute new code
> +to a subproject which uses unit tests and the code coverage metric, then do not
> +make the code coverage worse.
> +Documentation
> +Document your code using the
> +`PEP 257 - Docstring Conventions <https://www.python.org/dev/peps/pep-0257/>`_.
> +Contrary to PEP 257, use the descriptive-style
> +(``"""Fetches rows from a Bigtable."""``) instead of imperative-style
> +(``"""Fetch rows from a Bigtable."""``) as recommended by
> +`Comments and Docstrings - Functions and Methods <http://google.github.io/styleguide/pyguide.html#383-functions-and-methods>`_.
> +Use the
> +`Sphinx <https://sphinx-rtd-tutorial.readthedocs.io/en/latest/docstrings.html>`_
> +format.  The
> +`sphinx-autodoc-typehints <https://pypi.org/project/sphinx-autodoc-typehints/>`_
> +helps to reuse the type annotations for the documentation.  Test code does not
> +need docstrings in general.
> +Existing Code
> +Existing code in the RTEMS Tools may not follow the preceding guidelines.  The
> +RTEMS Project welcomes contributions which bring existing code in line with the
> +guidelines.  Firstly, run the ``yapf`` code formatter through the existing code
> +of interest.  Add ``# yapf: disable`` comments to avoid reformatting in some
> +areas if it makes sense.  If the existing code has no unit tests, then add unit
> +tests before you modify existing code by hand.  With the new unit tests aim at
> +a good code coverage especially in the areas you intend to modify.  While you
> +review the code add docstrings.  Run the static analysers and fix the rule
> +violations.  Please keep in mind that also trivial modifications can break
> +working code.  Make sure you have some unit tests.  Add type annotations unless
> +the code should be Python 2.7 compatible.  Concentrate on the public
> +interfaces.
> +Third-Party Code
> +Try to not modify imported third-party code.  In case there are issues with
> +third-party code, then at least write a bug report or otherwise contact the
> +upstream project.  Reimport the third-party code after the issue is fixed in
> +the upstream project.  Only temporarily modify imported third-party code until
> +a solution integrated in the upstream is available.
> 2.16.4
> devel mailing list
> devel at rtems.org
