[PATCH] Improve Python 3 compatibility
Tue Mar 17 07:34:59 UTC 2020
 tester/rt/check.py | 2 +-
 wscript            | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rt/check.py b/tester/rt/check.py
index c7f6c23..2a38d99 100755
--- a/tester/rt/check.py
+++ b/tester/rt/check.py
@@ -284,7 +284,7 @@ class warnings_errors:
         common = warnings['common']
         for build in builds:
             build_warnings = warnings[build]
-            if build is not 'common':
+            if build != 'common':
                 build_warnings = [w for w in build_warnings if w not in common]
             s += textbox.row(cols_1,
                              [' %s : %d warning(s)' % (build,
diff --git a/wscript b/wscript
index bd7c54d..1f5bbea 100644
--- a/wscript
+++ b/wscript
@@ -135,7 +135,7 @@ def check_options(ctx, host):
         ctx.env.CXX = '%s-g++' % (host)
         ctx.env.AR = '%s-ar' % (host)
         ctx.env.PYTHON = 'python'
-    elif host is not 'native':
+    elif host != 'native':
         ctx.fatal('unknown host: %s' % (host));
2.16.4
