[rtems_waf PATCH] rtems: Allow checking multiple environment variable
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Mar 17 09:52:42 UTC 2020
rtems.py | 9 +++++----
1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/rtems.py b/rtems.py
index 6dd71b1..ceabcd9 100644
--- a/rtems.py
+++ b/rtems.py
@@ -479,10 +479,11 @@ def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_arc
return rtems_version, rtems_path, tools, archs, arch_bsps
-def check_env(ctx, var):
- if var in ctx.env and len(ctx.env[var]) != 0:
- return True
- return False
+def check_env(ctx, *env_vars):
+ for v in env_vars:
+ if v not in ctx.env or len(ctx.env[v]) == 0:
+ return False
+ return True
def check(ctx, option, setting = 'Yes'):
if option in ctx.env:
2.21.1
