[rtems-examples PATCH 2/2] Replace deprecated CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS with CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Mar 17 09:53:51 UTC 2020
 benchmarks/nbench/main.c        | 2 +-
 c11/c11_cndvar01/rtems_config.c | 2 +-
 c11/c11_key01/rtems_config.c    | 2 +-
 c11/c11_mutex01/rtems_config.c  | 2 +-
 c11/c11_thread01/rtems_config.c | 2 +-
 file_io/crc/init.c              | 2 +-
 file_io/fdopen/README           | 2 +-
 file_io/fdopen/test.c           | 2 +-
 file_io/filerdback/test.c       | 2 +-
 file_io/repeated_opens/test.c   | 2 +-
 filesystem/fat_ramdisk/init.c   | 2 +-
 led/complex1/main.cc            | 2 +-
 lvgl/hello/test.c               | 2 +-
 micromonitor/umon/test.c        | 2 +-
 misc/adamain/rtems_init.c       | 2 +-
 misc/minimum/test.c             | 2 +-
 misc/qemu_vfat/system.h         | 2 +-
 ticker/low_ticker/init.c        | 2 +-
 ticker/low_ticker1/init.c       | 2 +-
 ticker/low_ticker2/init.c       | 2 +-
 20 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/benchmarks/nbench/main.c b/benchmarks/nbench/main.c
index f330255..68f799e 100644
--- a/benchmarks/nbench/main.c
+++ b/benchmarks/nbench/main.c
@@ -20,7 +20,7 @@
 #define CONFIGURE_MICROSECONDS_PER_TICK 1000
 #define CONFIGURE_TICKS_PER_TIMESLICE 5
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 50
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 50
 #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
 #define CONFIGURE_SWAPOUT_TASK_PRIORITY 220
diff --git a/c11/c11_cndvar01/rtems_config.c b/c11/c11_cndvar01/rtems_config.c
index a596695..218bfe9 100644
--- a/c11/c11_cndvar01/rtems_config.c
+++ b/c11/c11_cndvar01/rtems_config.c
@@ -45,7 +45,7 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_UNLIMITED_OBJECTS
 #define CONFIGURE_UNIFIED_WORK_AREAS
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 32
 #define CONFIGURE_MINIMUM_TASK_STACK_SIZE (64 * 1024)
diff --git a/c11/c11_key01/rtems_config.c b/c11/c11_key01/rtems_config.c
index b8fd346..b33ebbc 100644
--- a/c11/c11_key01/rtems_config.c
+++ b/c11/c11_key01/rtems_config.c
diff --git a/c11/c11_mutex01/rtems_config.c b/c11/c11_mutex01/rtems_config.c
index b72f679..3d9f8d3 100644
--- a/c11/c11_mutex01/rtems_config.c
+++ b/c11/c11_mutex01/rtems_config.c
diff --git a/c11/c11_thread01/rtems_config.c b/c11/c11_thread01/rtems_config.c
index 43c8e07..4bfded6 100644
--- a/c11/c11_thread01/rtems_config.c
+++ b/c11/c11_thread01/rtems_config.c
diff --git a/file_io/crc/init.c b/file_io/crc/init.c
index 4888e70..f05ab24 100644
--- a/file_io/crc/init.c
+++ b/file_io/crc/init.c
@@ -54,7 +54,7 @@ rtems_task Init(
 /* filesystem */
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 40
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 40
 #define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK 512
 /* tasks */
diff --git a/file_io/fdopen/README b/file_io/fdopen/README
index dee115d..6584480 100644
--- a/file_io/fdopen/README
+++ b/file_io/fdopen/README
@@ -57,7 +57,7 @@ into 0302), I would appreciate it.
 #define CONFIGURE_MAXIMUM_TASKS                   20
 #define CONFIGURE_MAXIMUM_TIMERS                  20
 #define CONFIGURE_MAXIMUM_PERIODS                 1
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS  10
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS  10
 #define CONFIGURE_INIT_TASK_STACK_SIZE            (32*1024)
 #define CONFIGURE_INIT_TASK_PRIORITY              90
 #define CONFIGURE_INIT_TASK_INITIAL_MODES         (RTEMS_PREEMPT | \
diff --git a/file_io/fdopen/test.c b/file_io/fdopen/test.c
index 5ab50a5..388624f 100644
--- a/file_io/fdopen/test.c
+++ b/file_io/fdopen/test.c
@@ -74,7 +74,7 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 6
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 #define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/file_io/filerdback/test.c b/file_io/filerdback/test.c
index ef0a4cc..96d983f 100644
--- a/file_io/filerdback/test.c
+++ b/file_io/filerdback/test.c
@@ -56,7 +56,7 @@ rtems_task Init(
diff --git a/file_io/repeated_opens/test.c b/file_io/repeated_opens/test.c
index 5106621..aeb8fad 100644
--- a/file_io/repeated_opens/test.c
+++ b/file_io/repeated_opens/test.c
@@ -51,7 +51,7 @@ rtems_task Init(rtems_task_argument a)
diff --git a/filesystem/fat_ramdisk/init.c b/filesystem/fat_ramdisk/init.c
index 57e0f26..7579c67 100644
--- a/filesystem/fat_ramdisk/init.c
+++ b/filesystem/fat_ramdisk/init.c
@@ -105,7 +105,7 @@ rtems_task Init(
 /* filesystem */
 #define CONFIGURE_FILESYSTEM_DOSFS
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
diff --git a/led/complex1/main.cc b/led/complex1/main.cc
index e60e4eb..c29d893 100644
--- a/led/complex1/main.cc
+++ b/led/complex1/main.cc
@@ -52,7 +52,7 @@ int main(
   #define CONFIGURE_EXTRA_TASK_STACKS (32 * 1024)
-  #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
+  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 20
   #define CONFIGURE_STACK_CHECKER_ENABLED
 #endif
diff --git a/lvgl/hello/test.c b/lvgl/hello/test.c
index c85bb35..d6948b3 100644
--- a/lvgl/hello/test.c
+++ b/lvgl/hello/test.c
@@ -114,7 +114,7 @@ Init(rtems_task_argument arg)
diff --git a/micromonitor/umon/test.c b/micromonitor/umon/test.c
index d1ba045..48a2d05 100644
--- a/micromonitor/umon/test.c
+++ b/micromonitor/umon/test.c
@@ -147,7 +147,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_SEMAPHORES 5
 #define CONFIGURE_MICROSECONDS_PER_TICK 5000
 #define CONFIGURE_INIT_TASK_STACK_SIZE  \
   (CONFIGURE_MINIMUM_TASK_STACK_SIZE * 10)
diff --git a/misc/adamain/rtems_init.c b/misc/adamain/rtems_init.c
index 7ffe112..eebf352 100644
--- a/misc/adamain/rtems_init.c
+++ b/misc/adamain/rtems_init.c
@@ -241,7 +241,7 @@ void *POSIX_Init( void *argument )
 #if 1
 /* We need to be able to create sockets */
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS	20
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS	20
 /* We need the full IMFS to pass the full ACATS */
diff --git a/misc/minimum/test.c b/misc/minimum/test.c
index 1605a17..49176f6 100644
--- a/misc/minimum/test.c
+++ b/misc/minimum/test.c
@@ -45,7 +45,7 @@ void *Init(
  *  This test does not use any stdio.
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 0
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
  *  This may prevent us from running on every architecture but it
diff --git a/misc/qemu_vfat/system.h b/misc/qemu_vfat/system.h
index f6663d8..62e66f8 100644
--- a/misc/qemu_vfat/system.h
+++ b/misc/qemu_vfat/system.h
@@ -52,7 +52,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_SEMAPHORES        20
 #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES    20
diff --git a/ticker/low_ticker/init.c b/ticker/low_ticker/init.c
index f25e7dd..ef83e0a 100644
--- a/ticker/low_ticker/init.c
+++ b/ticker/low_ticker/init.c
@@ -75,7 +75,7 @@ static void *Init(
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
 #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
 #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
 #define CONFIGURE_MAXIMUM_PRIORITY 15
 #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
diff --git a/ticker/low_ticker1/init.c b/ticker/low_ticker1/init.c
index 90a29d8..4682f8e 100644
--- a/ticker/low_ticker1/init.c
+++ b/ticker/low_ticker1/init.c
@@ -70,7 +70,7 @@ static void *Init(
  *  Reduce the stack as far as we think is safe on this architecture.
diff --git a/ticker/low_ticker2/init.c b/ticker/low_ticker2/init.c
index 024a52d..a687be9 100644
--- a/ticker/low_ticker2/init.c
+++ b/ticker/low_ticker2/init.c
@@ -64,7 +64,7 @@ void *Init(
2.21.1
