[PATCH v2] eng: Add Python development guidelines
Chris Johns
chrisj at rtems.org
Wed Mar 18 05:28:11 UTC 2020
On 18/3/20 7:50 am, Sebastian Huber wrote:
> v2:
> * Fix grammar
> * Recommend pytest instead of unittest
> eng/management.rst | 1 +
> eng/python-devel.rst | 163 +++++++++++++++++++++++++++++++++++++++++++++++++++
> 2 files changed, 164 insertions(+)
> create mode 100644 eng/python-devel.rst
> diff --git a/eng/management.rst b/eng/management.rst
> index 064559c..6eb4217 100644
> --- a/eng/management.rst
> +++ b/eng/management.rst
> @@ -16,5 +16,6 @@ Software Development Management
> vc-users
> vc-authors
> coding
> + python-devel
> change-management
> issue-tracking
> diff --git a/eng/python-devel.rst b/eng/python-devel.rst
> new file mode 100644
> index 0000000..a36d95e
> --- /dev/null
> +++ b/eng/python-devel.rst
> @@ -0,0 +1,163 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +.. _PythonDevelGuide:
> +Python Development Guidelines
> +Python is the main programming language for the RTEMS Tools. The RTEMS Tools
Preferred rather than main? We also have a C++ toolkit.
> +run on the host computer of an RTEMS user or maintainer. These guidelines
> +cover the Python language version, the source code formatting, use of static
> +analysis tools, type annotations, testing, code coverage, and documentation.
> +There are exceptions for existing code and third-party code. It is recommended
> +to read the
> +`PEP 8 - Style Guide for Python Code <https://www.python.org/dev/peps/pep-0008/>`_
> +and the
> +`Google Python Style Guide <http://google.github.io/styleguide/pyguide.html>`_.
> +Python Language Versions
> +Although the official end-of-life of Python 2.7 was on January 1, 2020, the
> +RTEMS Project still cares about Python 2.7 compatibility for some tools. Every
> +tool provided by the RTEMS Project which an RTEMS user may use to develop
> +applications with RTEMS should be Python 2.7 compatible. Examples are the
> +build system, the RTEMS Source Builder, and the RTEMS Tester. The rationale is
> +that there are still some maintained Linux distributions in the wild which ship
> +only Python 2.7 by default. An example is CentOS 7 which gets maintenance
> +updates until June 2024. Everything an RTEMS maintainer uses should be written
> +in Python 3.6.
> +Python Code Formatting
> +Good looking code is important. Unfortunately, what looks good is a bit
> +subjective and varies from developer to developer. Arguing about the code
> +format is not productive. Code reviews should focus on more important topics,
> +for example functionality, testability, and performance. Fortunately, for
> +Python there are some good automatic code formatters available. All new code
> +specifically developed for the RTEMS Tools should be piped through the
> +`yapf <https://github.com/google/yapf>`_ Python code formatter before it is
> +committed or sent for review. Use the default settings of the tool
> +(`PEP 8 <https://www.python.org/dev/peps/pep-0008/>`_ coding style).
> +You can disable the automatic formatting by the tool in a region starting with
> +the ``#yapf: disable`` comment until the next ``# yapf: enable`` comment, for
> +example
> +.. code-block:: python
> + # yapf: disable
> + FOO = {
> + # ... some very large, complex data literal.
> + BAR = [
> + # ... another large data literal.
> + # yapf: enable
> +For a single literal, you can disable the formatting like this:
> + BAZ = {
> + (1, 2, 3, 4),
> + (5, 6, 7, 8),
> + (9, 10, 11, 12),
> + } # yapf: disable
> +Static Analysis Tools
> +Use the ``flake8`` and ``pylint`` static analysis tools for Python. Do not
> +commit your code or send it for review if the tools find some rule
> +violations. Run the tools with the default configuration. If you have
> +problems to silence the tools, then please ask for help on the :r:list:`devel`.
> +Consult the tool documentation to silence false positives.
Would these be wrapped in a build environment so you can say ...
./waf lint
Even ...
./waf format
> +Type Annotations
> +For Python 3.6 or later code use type annotations. All public functions of
> +your modules should have `PEP 484 <https://www.python.org/dev/peps/pep-0484/>`_
> +type annotations. Check for type issues with the
> +`mypy <http://mypy-lang.org/>`_ static type checker.
> +Testing
> +Write tests for your code with the
> +`pytest <https://docs.pytest.org/en/latest/contents.html>`_ framework. Use the
> +`monkeypatch <https://docs.pytest.org/en/latest/monkeypatch.html>`_ mocking
> +module. Do not use the standard Python ``unittest`` and ``unittest.mock``
> +modules. Use ``coverage run -m pytest`` to run the tests with code coverage
> +support. If you modify existing code or contribute new code to a subproject
> +which uses tests and the code coverage metric, then do not make the code
> +coverage worse.
> +Test Organization
> +Do not use test classes to group tests. Use separate files instead. Avoid
> +deep test directory hierarchies. For example, place tests for
> +:file:`mymodule.py` in :file:`tests/test_mymodule.py`. For class-specific
> +tests use:
> +* ``mymodule.py:class First`` :math:`\rightarrow`
> + :file:`tests/test_mymodule_first.py`
> +* ``mymodule.py:class Second`` :math:`\rightarrow`
> + :file:`tests/test_mymodule_second.py`
> +* ``mymodule.py:class Third`` :math:`\rightarrow`
> + :file:`tests/test_mymodule_third.py`
> +You can also group tests in other ways, for example:
> +* :file:`mymodule.py` :math:`\rightarrow` :file:`tests/test_mymodule_input.py`
> +* :file:`mymodule.py` :math:`\rightarrow` :file:`tests/test_mymodule_output.py`
> +Documentation
> +Document your code using the
> +`PEP 257 - Docstring Conventions <https://www.python.org/dev/peps/pep-0257/>`_.
> +Contrary to PEP 257, use the descriptive-style
> +(``"""Fetches rows from a Bigtable."""``) instead of imperative-style
> +(``"""Fetch rows from a Bigtable."""``) as recommended by
> +`Comments and Docstrings - Functions and Methods <http://google.github.io/styleguide/pyguide.html#383-functions-and-methods>`_.
> +Use the
> +`Sphinx <https://sphinx-rtd-tutorial.readthedocs.io/en/latest/docstrings.html>`_
> +format. The
> +`sphinx-autodoc-typehints <https://pypi.org/project/sphinx-autodoc-typehints/>`_
> +helps to reuse the type annotations for the documentation. Test code does not
> +need docstrings in general.
> +Existing Code
> +Existing code in the RTEMS Tools may not follow the preceding guidelines. The
> +RTEMS Project welcomes contributions which bring existing code in line with the
> +guidelines. Firstly, run the ``yapf`` code formatter through the existing code
> +of interest. Add ``# yapf: disable`` comments to avoid reformatting in some
> +areas if it makes sense. If the existing code has no unit tests, then add unit
> +tests before you modify existing code by hand. With the new unit tests aim at
> +a good code coverage especially in the areas you intend to modify. While you
> +review the code add docstrings. Run the static analysers and fix the rule
> +violations. Please keep in mind that also trivial modifications can break
> +working code. Make sure you have some unit tests. Add type annotations unless
> +the code should be Python 2.7 compatible. Concentrate on the public
> +interfaces.
And cursing Chris for not doing all this in first place while doing these
changes is fine.
> +Third-Party Code
> +Try to not modify imported third-party code. In case there are issues with
> +third-party code, then at least write a bug report or otherwise contact the
> +upstream project. Reimport the third-party code after the issue is fixed in
> +the upstream project. Only temporarily modify imported third-party code until
> +a solution integrated in the upstream is available.
Build System
Any need to have something about the build system to be used to wrap a project?
There is waf as used in rtems-tools and then are are Python packaging systems.
Should this be covered?
