[rtems-libbsd commit] nfsclient: Use a system event for RPC
Wed Mar 18 15:47:44 UTC 2020
Is this the same as the NFS client for the legacy stack?
On Wed, Mar 18, 2020, 2:27 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module:    rtems-libbsd
> Branch:    5-freebsd-12
> Commit:    039afd9816122fc52f77966dc78430e009aa220c
> Changeset:
> http://git.rtems.org/rtems-libbsd/commit/?id=039afd9816122fc52f77966dc78430e009aa220c
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Wed Mar 11 11:05:59 2020 +0100
> Aviod conflicts with application events.
>  rtemsbsd/nfsclient/rpcio.c | 12 ++++++------
>  1 file changed, 6 insertions(+), 6 deletions(-)
> diff --git a/rtemsbsd/nfsclient/rpcio.c b/rtemsbsd/nfsclient/rpcio.c
> index cd04de3..40f8f08 100644
> --- a/rtemsbsd/nfsclient/rpcio.c
> +++ b/rtemsbsd/nfsclient/rpcio.c
> @@ -145,7 +145,7 @@ static struct timeval _rpc_default_timeout = { 10 /*
> secs */, 0 /* usecs */ };
>   * MUST NOT be used by any application
>   * thread doing RPC IO (e.g. NFS)
> -#define RTEMS_RPC_EVENT                RTEMS_EVENT_30  /* THE event used
> by RPCIO. Every task doing
> +#define RTEMS_RPC_EVENT                RTEMS_EVENT_SYSTEM_SERVER       /*
> THE event used by RPCIO. Every task doing
>                * RPC IO will receive this - hence it is
>                * RESERVED
> @@ -867,7 +867,7 @@ rtems_event_set             gotEvents;
>         do {
>         /* block for the reply */
> -       status = rtems_event_receive(
> +       status = rtems_event_system_receive(
>                 RTEMS_RPC_EVENT,
>                 RTEMS_WAIT | RTEMS_EVENT_ANY,
>                 RTEMS_NO_TIMEOUT,
> @@ -1316,7 +1316,7 @@ rtems_status_code status;
>                                 /* wakeup requestor */
> -                               rtems_event_send(xact->requestor,
> RTEMS_RPC_EVENT);
> +                               rtems_event_system_send(xact->requestor,
> RTEMS_RPC_EVENT);
> @@ -1371,7 +1371,7 @@ rtems_status_code status;
>  #if (DEBUG) & DEBUG_TIMEOUT
>                                         fprintf(stderr,"RPCIO XACT timed
> out; waking up requestor\n");
>  #endif
> -                                       if (
> rtems_event_send(xact->requestor, RTEMS_RPC_EVENT) ) {
> +                                       if (
> rtems_event_system_send(xact->requestor, RTEMS_RPC_EVENT) ) {
>                                                 rtems_panic("RPCIO PANIC:
> requestor id was 0x%08x",
> xact->requestor);
> @@ -1403,7 +1403,7 @@ rtems_status_code status;
>                                                 fprintf(stderr,"RPCIO:
> SEND failure\n");
> -                                               status =
> rtems_event_send(xact->requestor, RTEMS_RPC_EVENT);
> +                                               status =
> rtems_event_system_send(xact->requestor, RTEMS_RPC_EVENT);
>                                                 assert( status ==
> RTEMS_SUCCESSFUL );
>                                         } else {
> @@ -1541,7 +1541,7 @@ rtems_status_code status;
>         for (xact=((RpcUdpXact)listHead.next); xact;
> xact=((RpcUdpXact)xact->node.next)) {
>                         xact->status.re_status = RPC_TIMEDOUT;
> -                       rtems_event_send(xact->requestor, RTEMS_RPC_EVENT);
> RTEMS_RPC_EVENT);
>  #endif
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200318/39a059c6/attachment.html>
