[PATCH] c-user: Document new event record config options
Sebastian Huber
Thu Mar 19 08:03:22 UTC 2020
Update #3904.
c-user/config/event-record.rst | 64 ++++++++++++++++++++++++++++++++++++++++++
1 file changed, 64 insertions(+)
diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
index 7071c77..1dc7204 100644
--- a/c-user/config/event-record.rst
+++ b/c-user/config/event-record.rst
@@ -1,5 +1,6 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
Event Recording Configuration
@@ -33,6 +34,69 @@ NOTES:
The record extensions capture thread create, start, restart, delete, switch,
begin, exitted and terminate events.
+.. index:: CONFIGURE_RECORD_FATAL_DUMP_BASE64
+.. _CONFIGURE_RECORD_FATAL_DUMP_BASE64:
+CONFIGURE_RECORD_FATAL_DUMP_BASE64
+CONSTANT:
+ ``CONFIGURE_RECORD_FATAL_DUMP_BASE64``
+OPTION TYPE:
+ This configuration option is a boolean feature define.
+DEFAULT CONFIGURATION:
+ If this configuration option is undefined, then the event records are not
+ dumped in a fatal error extension.
+DESCRIPTION:
+ In case
+ * this configuration option is defined
+ * and :ref:`CONFIGURE_RECORD_EXTENSIONS_ENABLED` is defined
+ * and :ref:`CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB` is undefined,
+ then the event records are dumped in base64 encoding in a fatal error
+ extension (see :ref:`Terminate`).
+NOTES:
+ This extension can be used to produce crash dumps.
+.. index:: CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
+.. _CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB:
+CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
+CONSTANT:
+ ``CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB``
+OPTION TYPE:
+DESCRIPTION:
+ In case
+ * and :ref:`CONFIGURE_RECORD_EXTENSIONS_ENABLED` is defined,
+ then the event records are compressed by zlib and dumped in base64 encoding
+ in a fatal error extension (see :ref:`Terminate`).
+NOTES:
+ The zlib compression needs about 512KiB of RAM. This extension can be used
+ to produce crash dumps.
.. index:: CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
.. _CONFIGURE_RECORD_PER_PROCESSOR_ITEMS:
2.16.4
