Successfully built EPICS 7 with RTEMS 5 for mvme6100
Heinz Junkes junkes at fhi-berlin.mpg.de
Thu Mar 19 08:13:47 UTC 2020
> On 18. Mar 2020, at 22:17, Joel Sherrill <joel at rtems.org> wrote:
> We have had good experiences with RTEMS+libbsd with the Qemu ARM Zynq.
> We have been able to telnet to the RTEMS target from Linux and use the RTEMS
> NFS client to mount Linux files plus dynamic loading works. Personally I would
> start with that since the goal is EPICS not fixing a BSP. :)
This is a very good proposal, which I fully support.
> My second would be Qemu i386 pc386 but I don't know the status of libbsd on
> pc386 at the moment. This should work the same as the Zynq qemu but I
> personally don't know. Heinz.. do you have recent experience on it?
Not really good ones, unfortunately. We should try that when there is still time.
I will put together the things I have done for libbsd and EPICS/Rtems.
Heinz
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200319/14b29f0f/attachment.bin>
