[PATCH] libdebugger: Fix ARMv7-M with -O0
Thu Mar 19 08:52:15 UTC 2020
The ARMv7-M architecture has no CP-15.  The inline assembly for the
CP-15 access leads to assembler errors if compiled with -O0.
 cpukit/libdebugger/rtems-debugger-arm.c | 24 +++++++++++++-----------
 1 file changed, 13 insertions(+), 11 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-arm.c b/cpukit/libdebugger/rtems-debugger-arm.c
index 106cbe8b8a..67f5e2ad90 100644
--- a/cpukit/libdebugger/rtems-debugger-arm.c
+++ b/cpukit/libdebugger/rtems-debugger-arm.c
@@ -269,6 +269,7 @@ do { \
 RTEMS_INTERRUPT_LOCK_DEFINE(static, target_lock, "target_lock")
+#if ARM_CP15
  * An exception offset is added to the return address of the PC on an
  * exception's stack frame. The PC needs to be adjusted.
@@ -280,6 +281,7 @@ static const size_t exc_offsets[2][5] =
   /* TMB undef_ins sup call pref abt data abt */
   {  0,  2,        0,       4,       8 }
+#endif
  * Is a session active?
@@ -1014,6 +1016,7 @@ arm_debug_break_setup(arm_debug_hwbreak* bp,
   bp->value = (intptr_t) address;
+#if ARM_CP15
 static void
 arm_debug_break_write_control(int bp, uint32_t control)
@@ -1167,6 +1170,7 @@ arm_debug_method_of_entry(void)
   return (arm_debug_dbgdscr_read() >> 2) & 0xf;
+#endif
 static void
 arm_debug_disable_interrupts(void)
@@ -1174,6 +1178,7 @@ arm_debug_disable_interrupts(void)
   debug_disable_ints = true;
+#if ARM_CP15
 static void
 arm_debug_commit_interrupt_disable(void)
@@ -1188,6 +1193,7 @@ arm_debug_enable_interrupts(void)
   arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() & ~(1 << 11));
+#endif
 static void
 arm_debug_break_clear(void)
@@ -1211,6 +1217,7 @@ arm_debug_set_context_id(const uint32_t id)
 #endif
+#if ARM_CP15
  * You can only load the hardware breaks points when in the SVC mode or the
  * single step inverted break point will trigger.
@@ -1237,10 +1244,12 @@ arm_debug_break_load(void)
   rtems_interrupt_lock_release(&target_lock, &lock_context);
+#endif
 static void
 arm_debug_break_unload(void)
+#if ARM_CP15
   rtems_interrupt_lock_context lock_context;
   arm_debug_hwbreak*           bp = &hw_breaks[0];
   int                          i;
@@ -1251,8 +1260,10 @@ arm_debug_break_unload(void)
     arm_debug_break_write_control(i, 0);
+#endif
+#if ARM_CP15
 static void
 arm_debug_break_dump(void)
@@ -1267,6 +1278,7 @@ arm_debug_break_dump(void)
 #endif
+#endif
 #if NOT_USED_BUT_KEEPING
 static size_t
@@ -1295,6 +1307,7 @@ rtems_debugger_target_configure(rtems_debugger_target* target)
   return arm_debug_probe(target);
+#if ARM_CP15
 static void
 target_print_frame(CPU_Exception_frame* frame)
@@ -1591,7 +1604,6 @@ target_exception(CPU_Exception_frame* frame)
  * This is used to catch faulting accesses.
-#if ARM_CP15
 static void __attribute__((naked))
 arm_debug_unlock_abort(void)
@@ -1601,7 +1613,6 @@ arm_debug_unlock_abort(void)
   EXCEPTION_ENTRY_THREAD(frame);
   longjmp(unlock_abort_jmpbuf, -1);
-#endif
 target_exception_undefined_instruction(void)
@@ -1677,7 +1688,6 @@ target_exception_data_abort(void)
   EXCEPTION_EXIT_EXC();
-#if ARM_CP15
  * The init value for the text section.
@@ -1721,14 +1731,6 @@ rtems_debugger_target_set_vectors(void)
    * Dummy, please add support for your ARM variant.
-  void* ui = target_exception_undefined_instruction;
-  void* sc = target_exception_supervisor_call;
-  void* pa = target_exception_prefetch_abort;
-  void* da = target_exception_data_abort;
-  (void) ui;
-  (void) sc;
-  (void) pa;
-  (void) da;
 static void
2.16.4
