Successfully built EPICS 7 with RTEMS 5 for mvme6100
Joel Sherrill
joel at rtems.org
Thu Mar 19 14:07:23 UTC 2020
On Thu, Mar 19, 2020 at 4:20 AM <Jan.Sommer at dlr.de> wrote:
> > Von: devel [mailto:devel-bounces at rtems.org] Im Auftrag von Joel Sherrill
> > Gesendet: Mittwoch, 18. März 2020 22:18
> > An: Heinz Junkes
> > Cc: rtems-devel at rtems.org
> > Betreff: Re: Successfully built EPICS 7 with RTEMS 5 for mvme6100
> > On Wed, Mar 18, 2020 at 2:38 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
> wrote:
> > Hello, Mritunjay,
> > I will contact you tomorrow during the day (European time). We have
> here institute closings because of Corona Virus etc..
> > It's great that you've come this far. I can also provide you with an
> MVME6100 remotely so you can get a feeling for target development.
> > Yes, I have also started development of libbsd and the MVME2500. More on
> this tomorrow.
> > But the first, important step in this proposal would be to get EPICS7
> running with RTEMS5 on e.g. qemu, ideally on i386?
> > I think I had some problems with the psim in the past. Unfortunately I
> don't know exactly what it is anymore.
> > More tomorrow.
psim has a network driver for the legacy stack. I have no idea how to run
it. It would be great to see that BSP with NIC running again and then
updated to the new stack. I don't know that there is a PowerPC simulator
configuration with networking available at the moment.
> > We have had good experiences with RTEMS+libbsd with the Qemu ARM Zynq.
> > We have been able to telnet to the RTEMS target from Linux and use the
> RTEMS
> > NFS client to mount Linux files plus dynamic loading works. Personally I
> would
> > start with that since the goal is EPICS not fixing a BSP. :)
> > My second would be Qemu i386 pc386 but I don't know the status of libbsd
> on
> > pc386 at the moment. This should work the same as the Zynq qemu but I
> > personally don't know. Heinz.. do you have recent experience on it?
> If the patches here (
> https://lists.rtems.org/pipermail/devel/2020-March/058119.html) make it
> through the review, rtems-libbsd should compile again for the pc386 BSP.
Ping Sebastian to push them.
> We also could successfully run network tests in qemu with tap devices.
> Next step are real hardware tests. There were some issues during
> initialization,
We were re-establishing our hardware testing setup after moving offices a
twice over the past three years. When we got to the PC386, we had trouble.
We tried an embedded PC and a couple of odd desktops old enough to have
COM1. COM1 support appears to be broken for us. That's unfortunate for
automated testing.
> but we were interrupted with the preparations for Corona.
+1
I'm starting at home today. Not sure how long this will go on. I've done a
lot of work remote but never done extended work from home. This will be
interesting.
--joel
> Best regards,
> Jan
> > Gedare is correct though. Work on the proposal next. You are far enough
> along
> > with what you have done to been into debugging and integrating on a real
> > embedded target.
> > Many greetings and stay healthy,
> > Everything here is closed with teleworking. Two confirmed cases here
> > in town so far but one was at NASA Marshall and the other was a
> > pharmacist at the Army clinic. I expect we will have more in the near
> future.
> > --joel
> > Heinz
> > Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
> > Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
> > Faradayweg 4-6 | VC: 102220181216 at bjn.vc
> > D - 14195 Berlin | E-Mail: junkes at fhi-berlin.mpg.de
> > > On 18. Mar 2020, at 19:56, Mritunjay Sharma <
> mritunjaysharma394 at gmail.com> wrote:
> > > Thank you so much for the feedback. I will research more on the
> targets that can run with the simulator and would like to tell you that
> looking at https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0, I
> feel that @Heinz Junkes is already working on libbsd for RTEMS-MVME2500 and
> I would like to hear more from him to get some clarity on what can be done.
> Being a beginner, it's really a great welcome to the world of
> cross-compiler development and testing. :) Thank you for always helping me
> out!
> > > On Wed, Mar 18, 2020 at 11:51 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> > > On Wed, Mar 18, 2020 at 11:40 AM Mritunjay Sharma
> > > <mritunjaysharma394 at gmail.com> wrote:
> > > > Hi everyone,
> > > > As a part of working on ticket #3835 (BSP Buildset for EPICS), this
> is to inform the community that after a lot of research, help from RTEMS
> and EPICS community and
> https://epics.mpg.de/index.php?n=Software.EPICSRTEMS?userlang=en, I was
> able to build EPICS 7 for RTEMS 5 for mvme6100 (powerpc-rtems5).
> > > > After this, my development environment is almost completely set up
> with RTEMS, rtems-source-builder and epics7 (taken from
> https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0 ). While going
> through the entire process, I learnt about the changes to be made in
> epics7/configure/os/CONFIG_STATUS.Common.RTEMS and also encountered few
> errors while the 'make' process, however, it got fixed by commenting line
> 325 to 329 in
> '/home/mritunjay/development/rtems/5/powerpc-rtems5/beatnik/lib/include/rtems/confdefs/libio.h':
> > > > // #ifdef CONFIGURE_FILESYSTEM_ENTRY_DEVFS
> > > > // CONFIGURE_FILESYSTEM_ENTRY_DEVFS,
> > > > // #endif
> > > > I would like to know more on why this behaviour occurred. Is it a
> bug? Or something else?
> > > Include some of this detail in your proposal. I don't have time at the
> > > moment to delve into details.
> > > Next step would be to identify a target you can build EPICS7+RTEMS5
> > > with simulator support. This one is challenging since AFAIK there
> > > haven't been any successes in that regards. Find out what are the
> > > blockers and maybe you can work on those.
> > > > I wanted to test it but I am facing issues in connecting with tftp
> server when I run 'scp bin/RTEMS-beatnik/libComTestHarness.boot root at epics
> :/var/lib/tftp'
> > > > The following error was encountered:
> > > > /usr/bin/ssh: /lib/x86_64-linux-gnu/libcrypto.so.1.0.0: no version
> information available (required by /usr/bin/ssh)
> > > > ssh: Could not resolve hostname epics: Name or service not known
> > > > lost connection
> > > > I was wondering what can be the reason behind this, please help me
> fix this.
> > > Test it how -- do you have a powerpc MVME6100 board?
> > > I'm guessing whoever gave you that scp command line has a board with a
> > > local /etc/hosts entry for 'epics' pointing to some local IP address
> > > they connect to their board over.
> > > Welcome to the world of cross-compiler development and testing. :)
> https://docs.rtems.org/branches/master/user/hosts/index.html#development-host
> > > > Also, what are the next steps? I am working on the GSoC proposal
> currently and since the current ticket #3835 is a shorter project, I have
> to add certain similar sub-tasks within the GSoC timeline as suggested by
> @Gedare Bloom :
> > > > "* compile CFS by hand, create an RSB "recipe" to build it, then
> > > > integrate it with vertical buildset configuration.
> > > > * create vertical buildsets for PC, Raspberry Pi, and other boards.
> > > > ** EPICS community uses many powerpc boards so adding something there
> > > > would be good."
> > > Identify what might be potential simulator targets for you to use, and
> > > look at how easy they are to build with RSB. If any are missing
> > > support, work on adding them. If any are broken, poke into why.
> > > psim is a good powerpc simulator, although it may not have enough
> > > support for running epics--I haven't looked.
> > > For EPICS it is best to get something working in qemu so that you can
> > > run some networking. So I'd look at some qemu simulator targets and
> > > check what is their status and whether you can build and run anything
> > > for RTEMS on them. After that, can you build/run any RTEMS networking
> > > applications?
> > > Does the EPICS7+RTEMS5 stack still using cpukit/libnetworking, or is
> > > it able to use libbsd? That is an interesting question to find out.
> > > > I would like to have suggestions on resetting the timeline as I work
> on refining the proposal for GSoC based on Dr. @Gedare Bloom's suggestions.
> > > For timeline the first step is to break down all the tasks to figure
> > > out what you need to do to accomplish each of your goals. Then you
> > > should try to estimate how long you (or mentors) think each task will
> > > take, and use that create your plan. (Estimating time is notoriously
> > > difficult, but do your best. If it comes in too heavy or light, that
> > > is fine, you should put some activities in "Future Improvements" that
> > > can be moved into your summer work in case you get through your
> > > planned work faster than you expect; if you don't complete all your
> > > planned work, we understand and will take everything into
> > > consideration during evaluation. Do NOT think of your plan as a
> > > contract: it is not, it is a guideline for your summer.)
> > > > Thanks
> > > > Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200319/0d298cc2/attachment-0001.html>
