RFC: Exceptions to PEP-8 Adoption for RTEMS Tools
Thu Mar 19 15:42:14 UTC 2020
On Thu, Mar 19, 2020 at 1:25 AM Sebastian Huber
> On 19/03/2020 07:31, Sebastian Huber wrote:
> > Hello Gedare,
> > I am open for all exceptions provided
> > * there is a well known tool available which can format the code
> > automatically with the exceptions,
> > * the static analyzer tools can be configured to give good results
> > with the exceptions, and
> > * the exceptions are a best practice in a larger and well known Python
> > project.
> I checked in the first version of the guide:
> https://docs.rtems.org/branches/master/eng/python-devel.html
> We should refine it now step by step. In particular, it would be good to
> add some best practice parts to the Testing section.
> An open issue is how we would like to run the development tools.
> Integrate it in the build system (waf)? Run them through other standard
> Python tools for module  packaging, testing, and deployment? Run this
> tool with waf?
> For the static analysis tools flake8, pylint, and mypy you can use configuration files. For pylint, you can dump the default configuration with "pylint
> --generate-rcfile". Should we use a particular pylint version to generate configuration file for the RTEMS Project or should we just use whatever a future version will use as default?  I am not sure about the mypy configuration.
> How do we want to install the Python development tools? In the
> rtems-qual repository I simply set up a virtual environment with a Makefile:
> https://git.rtems.org/sebh/rtems-qual.git/tree/Makefile
> I think we should install specific versions of the tools to avoid that
> different developers get different tool reports.
Thank you Sebastian. You might want to open a new thread on this topic
or respond to your previous thread that had the draft of the guide.
