[PATCH] gdbarmsim: Remove
Thu Mar 19 23:10:39 UTC 2020
Looks good and thanks.
Plus there is this ...
https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#gdbarmsim
On 20/3/20 7:56 am, Joel Sherrill wrote:
> Closes #3611.
>  .../arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg |   5 -
>  bsps/arm/gdbarmsim/config/arm1136jfs.cfg           |  18 -
>  bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg |   5 -
>  bsps/arm/gdbarmsim/config/arm1136js.cfg            |  18 -
>  bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg  |   5 -
>  bsps/arm/gdbarmsim/config/arm7tdmi.cfg             |  18 -
>  bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg    |   5 -
>  bsps/arm/gdbarmsim/config/arm920.cfg               |  18 -
>  .../gdbarmsim/config/armcortexa9-testsuite.tcfg    |   5 -
>  bsps/arm/gdbarmsim/config/armcortexa9.cfg          |  19 -
>  bsps/arm/gdbarmsim/console/console-io.c            |  58 --
>  bsps/arm/gdbarmsim/headers.am                      |  11 -
>  bsps/arm/gdbarmsim/include/bsp.h                   |  85 ---
>  bsps/arm/gdbarmsim/include/bsp/irq.h               |  95 ---
>  bsps/arm/gdbarmsim/include/bsp/swi.h               | 110 ---
>  bsps/arm/gdbarmsim/include/tm27.h                  |   1 -
>  bsps/arm/gdbarmsim/irq/irq-dispatch.c              |  50 --
>  bsps/arm/gdbarmsim/irq/irq.c                       |  71 --
>  bsps/arm/gdbarmsim/start/bsp_specs                 |   9 -
>  bsps/arm/gdbarmsim/start/bspreset.c                |  17 -
>  bsps/arm/gdbarmsim/start/bspstart.c                |  22 -
>  bsps/arm/gdbarmsim/start/bspstarthooks.c           |  20 -
>  bsps/arm/gdbarmsim/start/linkcmds                  |  23 -
>  bsps/arm/gdbarmsim/start/syscalls.c                | 763 ---------------------
>  c/src/lib/libbsp/arm/acinclude.m4                  |   2 -
>  c/src/lib/libbsp/arm/gdbarmsim/Makefile.am         |  57 --
>  c/src/lib/libbsp/arm/gdbarmsim/configure.ac        |  21 -
>  27 files changed, 1531 deletions(-)
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm1136jfs.cfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm1136js.cfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm7tdmi.cfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/arm920.cfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg
>  delete mode 100644 bsps/arm/gdbarmsim/config/armcortexa9.cfg
>  delete mode 100644 bsps/arm/gdbarmsim/console/console-io.c
>  delete mode 100644 bsps/arm/gdbarmsim/headers.am
>  delete mode 100644 bsps/arm/gdbarmsim/include/bsp.h
>  delete mode 100644 bsps/arm/gdbarmsim/include/bsp/irq.h
>  delete mode 100644 bsps/arm/gdbarmsim/include/bsp/swi.h
>  delete mode 100644 bsps/arm/gdbarmsim/include/tm27.h
>  delete mode 100644 bsps/arm/gdbarmsim/irq/irq-dispatch.c
>  delete mode 100644 bsps/arm/gdbarmsim/irq/irq.c
>  delete mode 100644 bsps/arm/gdbarmsim/start/bsp_specs
>  delete mode 100644 bsps/arm/gdbarmsim/start/bspreset.c
>  delete mode 100644 bsps/arm/gdbarmsim/start/bspstart.c
>  delete mode 100644 bsps/arm/gdbarmsim/start/bspstarthooks.c
>  delete mode 100644 bsps/arm/gdbarmsim/start/linkcmds
>  delete mode 100644 bsps/arm/gdbarmsim/start/syscalls.c
>  delete mode 100644 c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
>  delete mode 100644 c/src/lib/libbsp/arm/gdbarmsim/configure.ac
> diff --git a/bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg b/bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg
> deleted file mode 100644
> index 70a1a31..0000000
> --- a/bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg
> +++ /dev/null
> @@ -1,5 +0,0 @@
> -# The GDB ARM Simulator does not have a tick interrupt.
> -include: testdata/require-tick-isr.tcfg
> diff --git a/bsps/arm/gdbarmsim/config/arm1136jfs.cfg b/bsps/arm/gdbarmsim/config/arm1136jfs.cfg
> index be4d5a6..0000000
> --- a/bsps/arm/gdbarmsim/config/arm1136jfs.cfg
> +++ /dev/null
> @@ -1,18 +0,0 @@
> -#  Config file for GDB ARM Simulator as arm1136jf-s (FPU)
> -include $(RTEMS_ROOT)/make/custom/default.cfg
> -RTEMS_CPU=arm
> -#  This contains the compiler options necessary to select the CPU model
> -#  and (hopefully) optimize for it.
> -CPU_CFLAGS = -mcpu=arm1136jf-s
> -# optimize flag: typically -O2
> -CFLAGS_OPTIMIZE_V = -O2 -g
> -# Add CFLAGS and LDFLAGS for compiling and linking with per item sections
> -CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
> -LDFLAGS            = -Wl,--gc-sections
> diff --git a/bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg b/bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg
> --- a/bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg
> +++ /dev/null
> @@ -1,5 +0,0 @@
> diff --git a/bsps/arm/gdbarmsim/config/arm1136js.cfg b/bsps/arm/gdbarmsim/config/arm1136js.cfg
> index 83308c3..0000000
> --- a/bsps/arm/gdbarmsim/config/arm1136js.cfg
> +++ /dev/null
> @@ -1,18 +0,0 @@
> -#  Config file for GDB ARM Simulator as arm1136j-s (no FPU)
> -RTEMS_CPU=arm
> -CPU_CFLAGS = -mcpu=arm1136j-s
> diff --git a/bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg b/bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg
> --- a/bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg
> +++ /dev/null
> @@ -1,5 +0,0 @@
> diff --git a/bsps/arm/gdbarmsim/config/arm7tdmi.cfg b/bsps/arm/gdbarmsim/config/arm7tdmi.cfg
> index e992733..0000000
> --- a/bsps/arm/gdbarmsim/config/arm7tdmi.cfg
> +++ /dev/null
> @@ -1,18 +0,0 @@
> -#  Config file for GDB ARM Simulator as arm7tdmi
> -RTEMS_CPU=arm
> -CPU_CFLAGS = -mcpu=arm7tdmi
> diff --git a/bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg b/bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg
> --- a/bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg
> +++ /dev/null
> @@ -1,5 +0,0 @@
> diff --git a/bsps/arm/gdbarmsim/config/arm920.cfg b/bsps/arm/gdbarmsim/config/arm920.cfg
> index b246d5b..0000000
> --- a/bsps/arm/gdbarmsim/config/arm920.cfg
> +++ /dev/null
> @@ -1,18 +0,0 @@
> -#  Config file for GDB ARM Simulator as arm920
> -RTEMS_CPU=arm
> -CPU_CFLAGS = -mcpu=arm920
> diff --git a/bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg b/bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg
> --- a/bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg
> +++ /dev/null
> @@ -1,5 +0,0 @@
> diff --git a/bsps/arm/gdbarmsim/config/armcortexa9.cfg b/bsps/arm/gdbarmsim/config/armcortexa9.cfg
> index 6eecf70..0000000
> --- a/bsps/arm/gdbarmsim/config/armcortexa9.cfg
> +++ /dev/null
> @@ -1,19 +0,0 @@
> -#  Config file for GDB ARM Simulator as cortex-a9
> -RTEMS_CPU=arm
> -# CPU_CFLAGS = -mcpu=arm920 -mstructure-size-boundary=8
> -CPU_CFLAGS = -mcpu=cortex-a9
> diff --git a/bsps/arm/gdbarmsim/console/console-io.c b/bsps/arm/gdbarmsim/console/console-io.c
> index 8bea74d..0000000
> --- a/bsps/arm/gdbarmsim/console/console-io.c
> +++ /dev/null
> @@ -1,58 +0,0 @@
> - *  COPYRIGHT (c) 1989-2009.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -#include <bsp.h>
> -#include <bsp/console-polled.h>
> -#include <rtems/libio.h>
> -#include <stdlib.h>
> -#include <assert.h>
> - *  console_initialize_hardware
> - *  This routine initializes the console hardware.
> -void console_initialize_hardware(void)
> -  return;
> - *  console_outbyte_polled
> - *  This routine transmits a character using polling.
> -void console_outbyte_polled(
> -  int  port,
> -  char ch
> -  gdbarmsim_writec(ch);
> - *  console_inbyte_nonblocking
> - *  This routine polls for a character.
> -int console_inbyte_nonblocking(
> -  int port
> -  return -1;
> -#include <rtems/bspIo.h>
> -static void MyBSP_output_char(char c) { console_outbyte_polled( 0, c ); }
> -BSP_output_char_function_type           BSP_output_char = MyBSP_output_char;
> -BSP_polling_getchar_function_type       BSP_poll_char = NULL;
> diff --git a/bsps/arm/gdbarmsim/headers.am b/bsps/arm/gdbarmsim/headers.am
> index 25e9fca..0000000
> --- a/bsps/arm/gdbarmsim/headers.am
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -## This file was generated by "./boostrap -H".
> -include_HEADERS =
> -include_HEADERS += ../../../../../../bsps/arm/gdbarmsim/include/bsp.h
> -include_HEADERS += include/bspopts.h
> -include_HEADERS += ../../../../../../bsps/arm/gdbarmsim/include/tm27.h
> -include_bspdir = $(includedir)/bsp
> -include_bsp_HEADERS =
> -include_bsp_HEADERS += ../../../../../../bsps/arm/gdbarmsim/include/bsp/irq.h
> -include_bsp_HEADERS += ../../../../../../bsps/arm/gdbarmsim/include/bsp/swi.h
> diff --git a/bsps/arm/gdbarmsim/include/bsp.h b/bsps/arm/gdbarmsim/include/bsp.h
> index d70be07..0000000
> --- a/bsps/arm/gdbarmsim/include/bsp.h
> +++ /dev/null
> @@ -1,85 +0,0 @@
> - * @file
> - * @ingroup RTEMSBSPsARMGDBSim
> - * @brief Global BSP definitions.
> -#ifndef LIBBSP_ARM_GDBARMSIM_BSP_H
> -#define LIBBSP_ARM_GDBARMSIM_BSP_H
> - * @defgroup RTEMSBSPsARMGDBSim GDB Simulator
> - * @brief GDB Simulator Board Support Package.
> -#include <bspopts.h>
> -#include <bsp/default-initial-extension.h>
> -#include <rtems.h>
> -#include <sys/stat.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> - * @brief Support for simulated clock tick
> -void *clock_driver_sim_idle_body(uintptr_t);
> -#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
> - * Access to the GDB simulator.
> - * NOTE: Full list possible is included. Not all are available in BSP.
> -int     gdbarmsim_system(const char *);
> -int     gdbarmsim_rename(const char *, const char *);
> -int     gdbarmsim__isatty(int);
> -/* clock_t gdbarmsim_times(struct tms *); */
> -int     gdbarmsim_gettimeofday(struct timeval *, void *);
> -int     gdbarmsim_unlink(const char *);
> -int     gdbarmsim_link(void);
> -int     gdbarmsim_stat(const char *, struct stat *);
> -int     gdbarmsim_fstat(int, struct stat *);
> -int	gdbarmsim_swistat(int fd, struct stat * st);
> -int     gdbarmsim_close(int);
> -clock_t gdbarmsim_clock(void);
> -int     gdbarmsim_swiclose(int);
> -int     gdbarmsim_open(const char *, int, ...);
> -int     gdbarmsim_swiopen(const char *, int);
> -int     gdbarmsim_writec(const char c);
> -int     gdbarmsim_write(int, char *, int);
> -int     gdbarmsim_swiwrite(int, char *, int);
> -int     gdbarmsim_lseek(int, int, int);
> -int     gdbarmsim_swilseek(int, int, int);
> -int     gdbarmsim_read(int, char *, int);
> -int     gdbarmsim_swiread(int, char *, int);
> -void    initialise_monitor_handles(void);
> -#ifdef __cplusplus
> -#endif
> -#endif /* _BSP_H */
> diff --git a/bsps/arm/gdbarmsim/include/bsp/irq.h b/bsps/arm/gdbarmsim/include/bsp/irq.h
> index 3c86d22..0000000
> --- a/bsps/arm/gdbarmsim/include/bsp/irq.h
> +++ /dev/null
> @@ -1,95 +0,0 @@
> - * @file
> - * @ingroup bsp_interrupt
> - * @brief Dummy interrupt definitions.
> - * Copyright (c) 2008
> - * Embedded Brains GmbH
> - * Obere Lagerstr. 30
> - * D-82178 Puchheim
> - * Germany
> - * rtems at embedded-brains.de
> -#ifndef LIBBSP_ARM_DUMMY_IRQ_H
> -#define LIBBSP_ARM_DUMMY_IRQ_H
> -#ifndef ASM
> -#include <rtems.h>
> -#include <rtems/irq.h>
> -#include <rtems/irq-extension.h>
> - * @addtogroup bsp_interrupt
> -#define DUMMY_IRQ_WDT 0
> -#define DUMMY_IRQ_SOFTWARE 1
> -#define DUMMY_IRQ_ARM_CORE_0 2
> -#define DUMMY_IRQ_ARM_CORE_1 3
> -#define DUMMY_IRQ_TIMER_0 4
> -#define DUMMY_IRQ_TIMER_1 5
> -#define DUMMY_IRQ_UART_0 6
> -#define DUMMY_IRQ_UART_1 7
> -#define DUMMY_IRQ_PWM 8
> -#define DUMMY_IRQ_I2C_0 9
> -#define DUMMY_IRQ_SPI_SSP_0 10
> -#define DUMMY_IRQ_SSP_1 11
> -#define DUMMY_IRQ_PLL 12
> -#define DUMMY_IRQ_RTC 13
> -#define DUMMY_IRQ_EINT_0 14
> -#define DUMMY_IRQ_EINT_1 15
> -#define DUMMY_IRQ_EINT_2 16
> -#define DUMMY_IRQ_EINT_3 17
> -#define DUMMY_IRQ_ADC_0 18
> -#define DUMMY_IRQ_I2C_1 19
> -#define DUMMY_IRQ_BOD 20
> -#define DUMMY_IRQ_ETHERNET 21
> -#define DUMMY_IRQ_USB 22
> -#define DUMMY_IRQ_CAN 23
> -#define DUMMY_IRQ_SD_MMC 24
> -#define DUMMY_IRQ_DMA 25
> -#define DUMMY_IRQ_TIMER_2 26
> -#define DUMMY_IRQ_TIMER_3 27
> -#define DUMMY_IRQ_UART_2 28
> -#define DUMMY_IRQ_UART_3 29
> -#define DUMMY_IRQ_I2C_2 30
> -#define DUMMY_IRQ_I2S 31
> -#define DUMMY_IRQ_PRIORITY_VALUE_MIN 0U
> -#define DUMMY_IRQ_PRIORITY_VALUE_MAX 15U
> - * @brief Minimum vector number.
> -#define BSP_INTERRUPT_VECTOR_MIN DUMMY_IRQ_WDT
> - * @brief Maximum vector number.
> -#define BSP_INTERRUPT_VECTOR_MAX DUMMY_IRQ_I2S
> -void bsp_interrupt_dispatch(void);
> -#if 0
> -void lpc24xx_irq_set_priority( rtems_vector_number vector, unsigned priority);
> -unsigned lpc24xx_irq_priority( rtems_vector_number vector);
> -#endif
> -#endif /* ASM */
> -#endif /* LIBBSP_ARM_DUMMY_IRQ_H */
> diff --git a/bsps/arm/gdbarmsim/include/bsp/swi.h b/bsps/arm/gdbarmsim/include/bsp/swi.h
> index 7604ad9..0000000
> --- a/bsps/arm/gdbarmsim/include/bsp/swi.h
> +++ /dev/null
> @@ -1,110 +0,0 @@
> - * @file
> - * @brief Software interrupt definitions.
> - * @defgroup gdbarmsim_swi SWI Definitions
> - *  Copied from libgloss 1 Oct 2009.
> - *  Minor modifications to work with RTEMS.
> -/* SWI numbers for RDP (Demon) monitor.  */
> -#define SWI_WriteC                 0x0
> -#define SWI_Write0                 0x2
> -#define SWI_ReadC                  0x4
> -#define SWI_CLI                    0x5
> -#define SWI_GetEnv                 0x10
> -#define SWI_Exit                   0x11
> -#define SWI_EnterOS                0x16
> -#define SWI_GetErrno               0x60
> -#define SWI_Clock                  0x61
> -#define SWI_Time                   0x63
> -#define SWI_Remove                 0x64
> -#define SWI_Rename                 0x65
> -#define SWI_Open                   0x66
> -#define SWI_Close                  0x68
> -#define SWI_Write                  0x69
> -#define SWI_Read                   0x6a
> -#define SWI_Seek                   0x6b
> -#define SWI_Flen                   0x6c
> -#define SWI_IsTTY                  0x6e
> -#define SWI_TmpNam                 0x6f
> -#define SWI_InstallHandler         0x70
> -#define SWI_GenerateError          0x71
> -/* Now the SWI numbers and reason codes for RDI (Angel) monitors.  */
> -#define AngelSWI_ARM 			0x123456
> -#ifdef __thumb__
> -#define AngelSWI 			0xAB
> -#else
> -#define AngelSWI 			AngelSWI_ARM
> -#endif
> -/* For Thumb-2 code use the BKPT instruction instead of SWI.  */
> -#ifdef __thumb2__
> -#define AngelSWIInsn			"bkpt"
> -#define AngelSWIAsm			bkpt
> -#else
> -#define AngelSWIInsn			"swi"
> -#define AngelSWIAsm			swi
> -#endif
> -/* The reason codes:  */
> -#define AngelSWI_Reason_Open		0x01
> -#define AngelSWI_Reason_Close		0x02
> -#define AngelSWI_Reason_WriteC		0x03
> -#define AngelSWI_Reason_Write0		0x04
> -#define AngelSWI_Reason_Write		0x05
> -#define AngelSWI_Reason_Read		0x06
> -#define AngelSWI_Reason_ReadC		0x07
> -#define AngelSWI_Reason_IsTTY		0x09
> -#define AngelSWI_Reason_Seek		0x0A
> -#define AngelSWI_Reason_FLen		0x0C
> -#define AngelSWI_Reason_TmpNam		0x0D
> -#define AngelSWI_Reason_Remove		0x0E
> -#define AngelSWI_Reason_Rename		0x0F
> -#define AngelSWI_Reason_Clock		0x10
> -#define AngelSWI_Reason_Time		0x11
> -#define AngelSWI_Reason_System		0x12
> -#define AngelSWI_Reason_Errno		0x13
> -#define AngelSWI_Reason_GetCmdLine 	0x15
> -#define AngelSWI_Reason_HeapInfo 	0x16
> -#define AngelSWI_Reason_EnterSVC 	0x17
> -#define AngelSWI_Reason_ReportException 0x18
> -#define ADP_Stopped_ApplicationExit 	((2 << 16) + 38)
> -#define ADP_Stopped_RunTimeError 	((2 << 16) + 35)
> -#if defined(ARM_RDI_MONITOR) && !defined(__ASSEMBLER__)
> -static inline int
> -do_AngelSWI (int reason, void * arg)
> -  int value;
> -  __asm__ volatile ("mov r0, %1; mov r1, %2; " AngelSWIInsn " %a3; mov %0, r0"
> -       : "=r" (value) /* Outputs */
> -       : "r" (reason), "r" (arg), "i" (AngelSWI) /* Inputs */
> -       : "r0", "r1", "r2", "r3", "ip", "lr", "memory", "cc"
> -		/* Clobbers r0 and r1, and lr if in supervisor mode */);
> -                /* Accordingly to page 13-77 of ARM DUI 0040D other registers
> -                   can also be clobbered.  Some memory positions may also be
> -                   changed by a system call, so they should not be kept in
> -                   registers. Note: we are assuming the manual is right and
> -                   Angel is respecting the APCS.  */
> -  return value;
> -#endif
> diff --git a/bsps/arm/gdbarmsim/include/tm27.h b/bsps/arm/gdbarmsim/include/tm27.h
> index 0dfa7bf..0000000
> --- a/bsps/arm/gdbarmsim/include/tm27.h
> +++ /dev/null
> @@ -1 +0,0 @@
> -#include <rtems/tm27-default.h>
> diff --git a/bsps/arm/gdbarmsim/irq/irq-dispatch.c b/bsps/arm/gdbarmsim/irq/irq-dispatch.c
> index f045fb8..0000000
> --- a/bsps/arm/gdbarmsim/irq/irq-dispatch.c
> +++ /dev/null
> @@ -1,50 +0,0 @@
> - * @file
> - * @brief GDB ARM Simulator interrupt support.
> - * Copyright (c) 2008-2012 embedded brains GmbH.  All rights reserved.
> - *  embedded brains GmbH
> - *  82178 Puchheim
> - *  Germany
> - *  <rtems at embedded-brains.de>
> -#include <rtems/score/armv4.h>
> -#include <bsp.h>
> -#include <bsp/irq.h>
> -#include <bsp/irq-generic.h>
> -#ifdef ARM_MULTILIB_ARCH_V4
> -  /* Read current vector number */
> -  /* rtems_vector_number vector = VICVectAddr; */
> -  rtems_vector_number vector = 0;
> -  /* Enable interrupts in program status register */
> -  uint32_t psr = _ARMV4_Status_irq_enable();
> -  /* Dispatch interrupt handlers */
> -  bsp_interrupt_handler_dispatch(vector);
> -  /* Restore program status register */
> -  _ARMV4_Status_restore(psr);
> -  /* Acknowledge interrupt */
> -  //VICVectAddr = 0;
> -#endif /* ARM_MULTILIB_ARCH_V4 */
> diff --git a/bsps/arm/gdbarmsim/irq/irq.c b/bsps/arm/gdbarmsim/irq/irq.c
> index 886f928..0000000
> --- a/bsps/arm/gdbarmsim/irq/irq.c
> +++ /dev/null
> @@ -1,71 +0,0 @@
> - * @file
> - *  82178 Puchheim
> - *  Germany
> -#include <rtems/score/armv7m.h>
> -#include <bsp.h>
> -#include <bsp/linker-symbols.h>
> - *  Prototypes
> -void lpc24xx_irq_set_priority(rtems_vector_number, unsigned);
> -unsigned lpc24xx_irq_get_priority(rtems_vector_number);
> -static inline bool lpc24xx_irq_is_valid(rtems_vector_number vector)
> -  return vector <= BSP_INTERRUPT_VECTOR_MAX;
> -void lpc24xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
> -unsigned lpc24xx_irq_get_priority(rtems_vector_number vector)
> -  return 0; /* bogus value to avoid warning */
> -void bsp_interrupt_vector_enable(rtems_vector_number vector)
> -  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
> -void bsp_interrupt_vector_disable(rtems_vector_number vector)
> -rtems_status_code bsp_interrupt_facility_initialize(void)
> -  /* Install the IRQ exception handler */
> -  _CPU_ISR_install_vector(ARM_EXCEPTION_IRQ, _ARMV4_Exception_interrupt, NULL);
> -  return RTEMS_SUCCESSFUL;
> diff --git a/bsps/arm/gdbarmsim/start/bsp_specs b/bsps/arm/gdbarmsim/start/bsp_specs
> index 47dd31d..0000000
> --- a/bsps/arm/gdbarmsim/start/bsp_specs
> +++ /dev/null
> @@ -1,9 +0,0 @@
> -%rename endfile old_endfile
> -%rename startfile old_startfile
> -*startfile:
> -%{!qrtems: %(old_startfile)} \
> -%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
> -*endfile:
> -%{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s}
> diff --git a/bsps/arm/gdbarmsim/start/bspreset.c b/bsps/arm/gdbarmsim/start/bspreset.c
> index b32c80e..0000000
> --- a/bsps/arm/gdbarmsim/start/bspreset.c
> +++ /dev/null
> @@ -1,17 +0,0 @@
> -#include <rtems.h>
> -#include <bsp/bootcard.h>
> -#include <bsp/swi.h>
> -void bsp_reset( void )
> -  __asm__ ("swi %a0" :: "i" (SWI_Exit));
> diff --git a/bsps/arm/gdbarmsim/start/bspstart.c b/bsps/arm/gdbarmsim/start/bspstart.c
> index de31264..0000000
> --- a/bsps/arm/gdbarmsim/start/bspstart.c
> +++ /dev/null
> @@ -1,22 +0,0 @@
> -#include <bsp.h>
> - * This routine would usually do the bulk of the system initialization.
> - * But if a BSP doesn't need to do anything, it can use this version.
> -void bsp_start( void )
> -  initialise_monitor_handles(void);
> diff --git a/bsps/arm/gdbarmsim/start/bspstarthooks.c b/bsps/arm/gdbarmsim/start/bspstarthooks.c
> index 996d358..0000000
> --- a/bsps/arm/gdbarmsim/start/bspstarthooks.c
> +++ /dev/null
> @@ -1,20 +0,0 @@
> - * Copyright (c) 2014 Chris Johns <chrisj at rtems.org>  All rights reserved.
> -#include <bsp.h>
> -#include <bsp/start.h>
> -BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> -BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
> -  bsp_start_copy_sections();
> -  bsp_start_clear_bss();
> diff --git a/bsps/arm/gdbarmsim/start/linkcmds b/bsps/arm/gdbarmsim/start/linkcmds
> index 536dbf5..0000000
> --- a/bsps/arm/gdbarmsim/start/linkcmds
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -MEMORY {
> -	RAM : ORIGIN = 0x00000000, LENGTH = 4M
> -REGION_ALIAS ("REGION_START", RAM);
> -REGION_ALIAS ("REGION_VECTOR", RAM);
> -REGION_ALIAS ("REGION_TEXT", RAM);
> -REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
> -REGION_ALIAS ("REGION_RODATA", RAM);
> -REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
> -REGION_ALIAS ("REGION_DATA", RAM);
> -REGION_ALIAS ("REGION_DATA_LOAD", RAM);
> -REGION_ALIAS ("REGION_FAST_TEXT", RAM);
> -REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
> -REGION_ALIAS ("REGION_FAST_DATA", RAM);
> -REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
> -REGION_ALIAS ("REGION_BSS", RAM);
> -REGION_ALIAS ("REGION_WORK", RAM);
> -REGION_ALIAS ("REGION_STACK", RAM);
> -REGION_ALIAS ("REGION_NOCACHE", RAM);
> -REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
> -INCLUDE linkcmds.armv4
> diff --git a/bsps/arm/gdbarmsim/start/syscalls.c b/bsps/arm/gdbarmsim/start/syscalls.c
> index 2e761dd..0000000
> --- a/bsps/arm/gdbarmsim/start/syscalls.c
> +++ /dev/null
> @@ -1,763 +0,0 @@
> -/* Support files for GNU libc.  Files in the system namespace go here.
> -   Files in the C namespace (ie those that do not start with an
> -   underscore) go in .c.  */
> - * Rename all the functions present here to stop then clashing with RTEMS
> - * names.
> -#include <_ansi.h>
> -#include <sys/types.h>
> -#include <sys/fcntl.h>
> -#include <stdio.h>
> -#include <string.h>
> -#include <time.h>
> -#include <sys/time.h>
> -#include <sys/times.h>
> -#include <errno.h>
> -#include <reent.h>
> -#include <unistd.h>
> -#include <sys/wait.h>
> -#include <bsp.h>
> -/* Forward prototypes.  */
> -static int	checkerror(int);
> -static int	error(int);
> -static int	get_errno(void);
> -/* Struct used to keep track of the file position, just so we
> -   can implement fseek(fh,x,SEEK_CUR).  */
> -struct fdent
> -  int handle;
> -  int pos;
> -#define MAX_OPEN_FILES 20
> -/* User file descriptors (fd) are integer indexes into
> -   the openfiles[] array. Error checking is done by using
> -   findslot().
> -   This openfiles array is manipulated directly by only
> -   these 5 functions:
> -	findslot() - Translate entry.
> -	newslot() - Find empty entry.
> -	initilise_monitor_handles() - Initialize entries.
> -	_swiopen() - Initialize entry.
> -	_close() - Handle stdout == stderr case.
> -   Every other function must use findslot().  */
> -static struct fdent openfiles [MAX_OPEN_FILES];
> -static struct fdent* 	findslot (int);
> -static int		newslot	(void);
> -/* Register name faking - works in collusion with the linker.  */
> -register char * stack_ptr __asm__ ("sp");
> -/* following is copied from libc/stdio/local.h to check std streams */
> -extern void __sinit(struct _reent *);
> -#define CHECK_INIT(ptr) \
> -  do						\
> -      if ((ptr) && !(ptr)->__sdidinit)		\
> -	__sinit (ptr);				\
> -  while (0)
> -static int monitor_stdin;
> -static int monitor_stdout;
> -static int monitor_stderr;
> -/* Return a pointer to the structure associated with
> -   the user file descriptor fd. */
> -findslot (int fd)
> -  CHECK_INIT(_REENT);
> -  /* User file descriptor is out of range. */
> -  if ((unsigned int)fd >= MAX_OPEN_FILES)
> -    return NULL;
> -  /* User file descriptor is open? */
> -  if (openfiles[fd].handle == -1)
> -    return NULL;
> -  /* Valid. */
> -  return &openfiles[fd];
> -/* Return the next lowest numbered free file
> -   structure, or -1 if we can't find one. */
> -static int
> -newslot (void)
> -  int i;
> -  for (i = 0; i < MAX_OPEN_FILES; i++)
> -    if (openfiles[i].handle == -1)
> -      break;
> -  if (i == MAX_OPEN_FILES)
> -    return -1;
> -  return i;
> -void
> -initialise_monitor_handles (void)
> -  int i;
> -  /* Open the standard file descriptors by opening the special
> -   * teletype device, ":tt", read-only to obtain a descritpor for
> -   * standard input and write-only to obtain a descriptor for standard
> -   * output. Finally, open ":tt" in append mode to obtain a descriptor
> -   * for standard error. Since this is a write mode, most kernels will
> -   * probably return the same value as for standard output, but the
> -   * kernel can differentiate the two using the mode flag and return a
> -   * different descriptor for standard error.
> -#ifdef ARM_RDI_MONITOR
> -  int volatile block[3];
> -  block[0] = (int) ":tt";
> -  block[2] = 3;     /* length of filename */
> -  block[1] = 0;     /* mode "r" */
> -  monitor_stdin = do_AngelSWI (AngelSWI_Reason_Open, (void *) block);
> -  block[1] = 4;     /* mode "w" */
> -  monitor_stdout = do_AngelSWI (AngelSWI_Reason_Open, (void *) block);
> -  block[1] = 8;     /* mode "a" */
> -  monitor_stderr = do_AngelSWI (AngelSWI_Reason_Open, (void *) block);
> -#else
> -  int fh;
> -  const char * name;
> -  name = ":tt";
> -  __asm__ ("mov r0,%2; mov r1, #0; swi %a1; mov %0, r0"
> -       : "=r"(fh)
> -       : "i" (SWI_Open),"r"(name)
> -       : "r0","r1");
> -  monitor_stdin = fh;
> -  name = ":tt";
> -  __asm__ ("mov r0,%2; mov r1, #4; swi %a1; mov %0, r0"
> -       : "=r"(fh)
> -       : "r0","r1");
> -  monitor_stdout = fh;
> -  name = ":tt";
> -  __asm__ ("mov r0,%2; mov r1, #8; swi %a1; mov %0, r0"
> -       : "=r"(fh)
> -       : "r0","r1");
> -  monitor_stderr = fh;
> -#endif
> -  /* If we failed to open stderr, redirect to stdout. */
> -  if (monitor_stderr == -1)
> -    monitor_stderr = monitor_stdout;
> -  for (i = 0; i < MAX_OPEN_FILES; i ++)
> -    openfiles[i].handle = -1;
> -  openfiles[0].handle = monitor_stdin;
> -  openfiles[0].pos = 0;
> -  openfiles[1].handle = monitor_stdout;
> -  openfiles[1].pos = 0;
> -  openfiles[2].handle = monitor_stderr;
> -  openfiles[2].pos = 0;
> -static int
> -get_errno (void)
> -  return do_AngelSWI (AngelSWI_Reason_Errno, NULL);
> -#else
> -  register int r0 __asm__ ("r0");
> -  __asm__ ("swi %a1" : "=r"(r0) : "i" (SWI_GetErrno));
> -  return r0;
> -#endif
> -/* Set errno and return result. */
> -static int
> -error (int result)
> -  errno = get_errno ();
> -  return result;
> -/* Check the return and set errno appropriately. */
> -static int
> -checkerror (int result)
> -  if (result == -1)
> -    return error (-1);
> -  return result;
> -/* fh, is a valid internal file handle.
> -   ptr, is a null terminated string.
> -   len, is the length in bytes to read.
> -   Returns the number of bytes *not* written. */
> -int
> -gdbarmsim_swiread (int fh,
> -                   char * ptr,
> -                   int len)
> -  int block[3];
> -  block[0] = fh;
> -  block[1] = (int) ptr;
> -  block[2] = len;
> -  return checkerror (do_AngelSWI (AngelSWI_Reason_Read, block));
> -#else
> -  register int r1 __asm__ ("r1");
> -  register int r2 __asm__ ("r2");
> -  r0 = fh;
> -  r1 = (int)ptr;
> -  r2 = len;
> -  __asm__ ("swi %a4"
> -       : "=r" (r0)
> -       : "0"(r0), "r"(r1), "r"(r2), "i"(SWI_Read));
> -  return checkerror (r0);
> -#endif
> -/* fd, is a valid user file handle.
> -   Translates the return of _swiread into
> -   bytes read. */
> -int
> -gdbarmsim_read (int fd,
> -                char * ptr,
> -                int len)
> -  int res;
> -  struct fdent *pfd;
> -  pfd = findslot (fd);
> -  if (pfd == NULL)
> -      errno = EBADF;
> -      return -1;
> -  res = gdbarmsim_swiread (pfd->handle, ptr, len);
> -  if (res == -1)
> -    return res;
> -  pfd->pos += len - res;
> -  /* res == len is not an error,
> -     at least if we want feof() to work.  */
> -  return len - res;
> -/* fd, is a user file descriptor. */
> -int
> -gdbarmsim_swilseek (int fd,
> -                    int ptr,
> -                    int dir)
> -  int res;
> -  /* Valid file descriptor? */
> -  if (pfd == NULL)
> -      errno = EBADF;
> -      return -1;
> -  /* Valid whence? */
> -  if ((dir != SEEK_CUR)
> -      && (dir != SEEK_SET)
> -      && (dir != SEEK_END))
> -      errno = EINVAL;
> -      return -1;
> -  /* Convert SEEK_CUR to SEEK_SET */
> -  if (dir == SEEK_CUR)
> -      ptr = pfd->pos + ptr;
> -      /* The resulting file offset would be negative. */
> -      if (ptr < 0)
> -          errno = EINVAL;
> -          if ((pfd->pos > 0) && (ptr > 0))
> -            errno = EOVERFLOW;
> -          return -1;
> -      dir = SEEK_SET;
> -  int block[2];
> -  if (dir == SEEK_END)
> -      block[0] = pfd->handle;
> -      res = checkerror (do_AngelSWI (AngelSWI_Reason_FLen, block));
> -      if (res == -1)
> -        return -1;
> -      ptr += res;
> -  /* This code only does absolute seeks.  */
> -  block[1] = ptr;
> -  res = checkerror (do_AngelSWI (AngelSWI_Reason_Seek, block));
> -#else
> -      __asm__ ("mov r0, %2; swi %a1; mov %0, r0"
> -	   : "=r" (res)
> -	   : "i" (SWI_Flen), "r" (pfd->handle)
> -	   : "r0");
> -      checkerror (res);
> -      if (res == -1)
> -        return -1;
> -      ptr += res;
> -  __asm__ ("mov r0, %2; mov r1, %3; swi %a1; mov %0, r0"
> -       : "=r" (res)
> -       : "i" (SWI_Seek), "r" (pfd->handle), "r" (ptr)
> -       : "r0", "r1");
> -  checkerror (res);
> -#endif
> -  /* At this point ptr is the current file position. */
> -  if (res >= 0)
> -      pfd->pos = ptr;
> -      return ptr;
> -  else
> -    return -1;
> -int
> -gdbarmsim_lseek (int fd,
> -                 int ptr,
> -                 int dir)
> -  return gdbarmsim_swilseek (fd, ptr, dir);
> -/* write a single character out the hosts stdout */
> -int
> -gdbarmsim_writec (const char c)
> -  int block[1];
> -  block[0] = ((int) c) & 0xff;;
> -  return checkerror (do_AngelSWI (AngelSWI_Reason_WriteC, block));
> -#else
> -  r0 = ((int) c) & 0xff;
> -  __asm__ ("swi %a2"
> -       : "=r" (r0)
> -       : "0"(r0), "i"(SWI_WriteC));
> -#endif
> -int
> -gdbarmsim_swiwrite (int    fh,
> -                    char * ptr,
> -                    int    len)
> -  int block[3];
> -  block[0] = fh;
> -  block[2] = len;
> -  return checkerror (do_AngelSWI (AngelSWI_Reason_Write, block));
> -#else
> -  r0 = fh;
> -  r1 = (int)ptr;
> -  r2 = len;
> -       : "=r" (r0)
> -       : "0"(r0), "r"(r1), "r"(r2), "i"(SWI_Write));
> -#endif
> -int
> -gdbarmsim_write (int    fd,
> -                 char * ptr,
> -                 int    len)
> -  int res;
> -  if (pfd == NULL)
> -      errno = EBADF;
> -      return -1;
> -  res = gdbarmsim_swiwrite (pfd->handle, ptr,len);
> -  /* Clearly an error. */
> -  if (res < 0)
> -    return -1;
> -  /* We wrote 0 bytes?
> -     Retrieve errno just in case. */
> -  if ((len - res) == 0)
> -    return error (0);
> -  return (len - res);
> -int
> -gdbarmsim_swiopen (const char * path, int flags)
> -  int aflags = 0, fh;
> -  int block[3];
> -#endif
> -  int fd = newslot ();
> -  if (fd == -1)
> -      errno = EMFILE;
> -      return -1;
> -  /* It is an error to open a file that already exists. */
> -  if ((flags & O_CREAT)
> -      && (flags & O_EXCL))
> -      struct stat st;
> -      int res;
> -      res = gdbarmsim_stat (path, &st);
> -      if (res != -1)
> -	  errno = EEXIST;
> -	  return -1;
> -  /* The flags are Unix-style, so we need to convert them. */
> -#ifdef O_BINARY
> -  if (flags & O_BINARY)
> -    aflags |= 1;
> -#endif
> -  /* In O_RDONLY we expect aflags == 0. */
> -  if (flags & O_RDWR)
> -    aflags |= 2;
> -      || (flags & O_TRUNC)
> -      || (flags & O_WRONLY))
> -    aflags |= 4;
> -  if (flags & O_APPEND)
> -      /* Can't ask for w AND a; means just 'a'.  */
> -      aflags &= ~4;
> -      aflags |= 8;
> -  block[0] = (int) path;
> -  block[2] = strlen (path);
> -  block[1] = aflags;
> -  fh = do_AngelSWI (AngelSWI_Reason_Open, block);
> -#else
> -  __asm__ ("mov r0,%2; mov r1, %3; swi %a1; mov %0, r0"
> -       : "=r"(fh)
> -       : "i" (SWI_Open),"r"(path),"r"(aflags)
> -       : "r0","r1");
> -#endif
> -  /* Return a user file descriptor or an error. */
> -  if (fh >= 0)
> -      openfiles[fd].handle = fh;
> -      openfiles[fd].pos = 0;
> -      return fd;
> -  else
> -    return error (fh);
> -int
> -gdbarmsim_open (const char * path, int flags, ...)
> -  return gdbarmsim_swiopen (path, flags);
> -/* fh, is a valid internal file handle. */
> -int
> -gdbarmsim_swiclose (int fh)
> -  return checkerror (do_AngelSWI (AngelSWI_Reason_Close, &fh));
> -#else
> -  r0 = fh;
> -       : "=r"(r0)
> -       : "0"(r0), "i" (SWI_Close));
> -#endif
> -int
> -gdbarmsim_close (int fd)
> -  int res;
> -  if (pfd == NULL)
> -      errno = EBADF;
> -      return -1;
> -  /* Handle stderr == stdout. */
> -  if ((fd == 1 || fd == 2)
> -      && (openfiles[1].handle == openfiles[2].handle))
> -      pfd->handle = -1;
> -      return 0;
> -  /* Attempt to close the handle. */
> -  res = gdbarmsim_swiclose (pfd->handle);
> -  /* Reclaim handle? */
> -  if (res == 0)
> -    pfd->handle = -1;
> -  return res;
> -int
> -gdbarmsim_swistat (int fd, struct stat * st)
> -  int res;
> -  if (pfd == NULL)
> -      errno = EBADF;
> -      return -1;
> -  /* Always assume a character device,
> -     with 1024 byte blocks. */
> -  st->st_mode |= S_IFCHR;
> -  st->st_blksize = 1024;
> -  res = checkerror (do_AngelSWI (AngelSWI_Reason_FLen, &pfd->handle));
> -#else
> -       : "=r" (res)
> -       : "r0");
> -  checkerror (res);
> -#endif
> -  if (res == -1)
> -    return -1;
> -  /* Return the file size. */
> -  st->st_size = res;
> -  return 0;
> -int
> -gdbarmsim_fstat (int fd, struct stat * st)
> -  memset (st, 0, sizeof (* st));
> -  return gdbarmsim_swistat (fd, st);
> -int
> -gdbarmsim_stat (const char *fname, struct stat *st)
> -  int fd, res;
> -  /* The best we can do is try to open the file readonly.
> -     If it exists, then we can guess a few things about it. */
> -  if ((fd = gdbarmsim_open (fname, O_RDONLY)) == -1)
> -    return -1;
> -  st->st_mode |= S_IFREG | S_IREAD;
> -  res = gdbarmsim_swistat (fd, st);
> -  /* Not interested in the error. */
> -  gdbarmsim_close (fd);
> -  return res;
> -int
> -gdbarmsim_unlink (const char *path)
> -  int res;
> -  int block[2];
> -  block[0] = (int)path;
> -  block[1] = strlen(path);
> -  res = do_AngelSWI (AngelSWI_Reason_Remove, block);
> -#else
> -  r0 = (int)path;
> -       : "=r"(r0)
> -       : "0"(r0), "i" (SWI_Remove));
> -  res = r0;
> -#endif
> -  if (res == -1)
> -    return error (res);
> -  return 0;
> -/* Return a clock that ticks at 100Hz.  */
> -clock_t
> -gdbarmsim_clock (void)
> -  clock_t timeval;
> -  timeval = do_AngelSWI (AngelSWI_Reason_Clock,NULL);
> -#else
> -  __asm__ ("swi %a1; mov %0, r0" : "=r" (timeval): "i" (SWI_Clock) : "r0");
> -#endif
> -  return timeval;
> -int
> -gdbarmsim__isatty (int fd)
> -  if (pfd == NULL)
> -      errno = EBADF;
> -      return -1;
> -  return checkerror (do_AngelSWI (AngelSWI_Reason_IsTTY, &pfd->handle));
> -#else
> -  r0 = pfd->handle;
> -       : "=r" (r0)
> -       : "0"(r0), "i" (SWI_IsTTY));
> -#endif
> -int
> -gdbarmsim_system (const char *s)
> -  int block[2];
> -  int e;
> -  /* Hmmm.  The ARM debug interface specification doesn't say whether
> -     SYS_SYSTEM does the right thing with a null argument, or assign any
> -     meaning to its return value.  Try to do something reasonable....  */
> -  if (!s)
> -    return 1;  /* maybe there is a shell available? we can hope. :-P */
> -  block[0] = (int)s;
> -  block[1] = strlen (s);
> -  e = checkerror (do_AngelSWI (AngelSWI_Reason_System, block));
> -  if ((e >= 0) && (e < 256))
> -      /* We have to convert e, an exit status to the encoded status of
> -         the command.  To avoid hard coding the exit status, we simply
> -	 loop until we find the right position.  */
> -      int exit_code;
> -      for (exit_code = e; e && WEXITSTATUS (e) != exit_code; e <<= 1)
> -	continue;
> -  return e;
> -#else
> -  r0 = (int)s;
> -       : "=r" (r0)
> -       : "0"(r0), "i" (SWI_CLI));
> -#endif
> -int
> -gdbarmsim_rename (const char * oldpath, const char * newpath)
> -  int block[4];
> -  block[0] = (int)oldpath;
> -  block[1] = strlen(oldpath);
> -  block[2] = (int)newpath;
> -  block[3] = strlen(newpath);
> -  return checkerror (do_AngelSWI (AngelSWI_Reason_Rename, block)) ? -1 : 0;
> -#else
> -  r0 = (int)oldpath;
> -  r1 = (int)newpath;
> -  __asm__ ("swi %a3"
> -       : "=r" (r0)
> -       : "0" (r0), "r" (r1), "i" (SWI_Rename));
> -#endif
> diff --git a/c/src/lib/libbsp/arm/acinclude.m4 b/c/src/lib/libbsp/arm/acinclude.m4
> index 4d50477..6f75afe 100644
> --- a/c/src/lib/libbsp/arm/acinclude.m4
> +++ b/c/src/lib/libbsp/arm/acinclude.m4
> @@ -14,8 +14,6 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>      AC_CONFIG_SUBDIRS([csb337]);;
>    edb7312 )
>      AC_CONFIG_SUBDIRS([edb7312]);;
> -  gdbarmsim )
> -    AC_CONFIG_SUBDIRS([gdbarmsim]);;
>    gumstix )
>      AC_CONFIG_SUBDIRS([gumstix]);;
>    imx )
> diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
> index 0ae0e82..0000000
> --- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
> +++ /dev/null
> @@ -1,57 +0,0 @@
> -ACLOCAL_AMFLAGS = -I ../../../../aclocal
> -include $(top_srcdir)/../../../../automake/compile.am
> -include $(top_srcdir)/../../bsp.am
> -dist_project_lib_DATA = ../../../../../../bsps/arm/gdbarmsim/start/bsp_specs
> -noinst_PROGRAMS =
> -start.$(OBJEXT): ../../../../../../bsps/arm/shared/start/start.S
> -	$(CPPASCOMPILE) -o $@ -c $<
> -project_lib_DATA = start.$(OBJEXT)
> -project_lib_DATA += linkcmds
> -project_lib_LIBRARIES = librtemsbsp.a
> -librtemsbsp_a_SOURCES =
> -# startup
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspstart-empty.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/gdbarmsim/start/bspreset.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/gdbarmsim/start/syscalls.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
> -# console
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-polled.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/gdbarmsim/console/console-io.c
> -# clock
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/clock/clock-simidle.c
> -# timer
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
> -# start hooks
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/gdbarmsim/start/bspstarthooks.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
> -# IRQ
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/gdbarmsim/irq/irq.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/gdbarmsim/irq/irq-dispatch.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
> -# Cache
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
> -# Shared
> -if shared
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> -endif
> -include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
> -include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
> -include $(srcdir)/../../../../../../bsps/arm/gdbarmsim/headers.am
> diff --git a/c/src/lib/libbsp/arm/gdbarmsim/configure.ac b/c/src/lib/libbsp/arm/gdbarmsim/configure.ac
> index 1ae47dc..0000000
> --- a/c/src/lib/libbsp/arm/gdbarmsim/configure.ac
> +++ /dev/null
> @@ -1,21 +0,0 @@
> -## Process this file with autoconf to produce a configure script.
> -AC_PREREQ([2.69])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-gdbarmsim],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
> -RTEMS_TOP(../../../../../..)
> -RTEMS_SOURCE_TOP
> -RTEMS_BUILD_TOP
> -RTEMS_BSP_LINKCMDS
> -RTEMS_CANONICAL_TARGET_CPU
> -AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> -RTEMS_BSP_CONFIGURE
> -RTEMS_BSP_CLEANUP_OPTIONS
> -AM_CONDITIONAL(shared, test "$RTEMS_BSP" = "armcortexa9")
> -# Explicitly list all Makefiles here
> -AC_CONFIG_FILES([Makefile])
> -AC_OUTPUT
