Release sources
Fri Mar 20 03:57:31 UTC 2020
Hi,
The last snapshot ....
 https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2003/
has a release process bug. The bug is due to the way the sources are collected
and packaged. I end up with two copies of the top level sources, the top level
file and an almost identical copy in `sources`. The ones in sources are wrong
and the top level ones are correct. Having two copies is confusing.
If I remove the copy in `sources` and just have the top level ones you get an
error when building the kernel or libbsd as it first tries `sources`, fails then
tries the top level directory which works. It could be confusing to see an error.
I am proposing all sources are placed in `sources` and we have no top level
sources. I will update the README and documentation.
Only having sources in `sources` is a change from how RTEMS has been released in
the past so I feel this needs to be discussed and approved before I make any
changes.
Thanks
